Kolb landing
pj.ladd(at)btinternet.com
PostPosted: Fri Aug 01, 2014 2:22 am    Post subject: Kolb landing Reply with quote
Hi John,
Not trying to frighten anyone and I don`t believe in the Kolb Quit but you know as well as I do that the techniques for landing a Kolb and a (say) Cessna are different.
If you close the throttle just above the stall at 10 or 15ft in a Cessna its inertia will bring you in.
if you try it in a Kolb she will shed flying speed VERY quickly and unless you are quick, which by definition in this case, you are NOT, she will stall like any other a/c and you do not have enough height to recover.
That means a hard landing at best.
As i said in my post, you should land inches above the ground NOT feet.
Happy flying
Pat
PostPosted: Fri Aug 01, 2014 3:39 am    Post subject: Kolb landing Reply with quote
Happy flying
Pat
[quote] Close the throttle, push the stick forward to maintain airspeed, land the Kolb. john [b]
russk50(at)gmail.com
PostPosted: Fri Aug 01, 2014 4:38 am    Post subject: Kolb landing Reply with quote
PatThink you meant this for John?
More later,
Russ
On Aug 1, 2014, at 6:21 AM, Pat Ladd wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);}
Hi John,
Happy flying
Pat
rickofudall
PostPosted: Sat Aug 02, 2014 3:05 am    Post subject: Kolb landing Reply with quote
All, Here are two photos showing the Kolb Mk III in a full flap approach and round out. Sorry my neighbor didn't get the perfect on-three landing but the photos should give you the idea.
Rick Girard
On Fri, Aug 1, 2014 at 7:38 AM, kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)> wrote:
More later,
Russ
Hi John,
Happy flying
Pat
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
 Filesize:  134.27 KB
 Viewed:  4305 Time(s)
 Filesize:  171.74 KB
Larlaeb
PostPosted: Sat Aug 02, 2014 5:02 am    Post subject: Re: Kolb landing Reply with quote
I'm still a low time pilot in the Kolb, just passed 200 hours in her and I have a little less than 1000 landings now. I try to do 2 or 3 at least every time I fly and I try to vary the type of landing I do each time. Full flaps, no flaps, wheel, three point, over obstacle, stop short etc.
I think the Kolb, at least my Mark III, is a pretty easy airplane to land but it is not easy to land 'perfectly' 3 point power off EVERY TIME at least for me. As has been stated over and over it has to be flown all the way to the ground. You can't just get it in ground effect and let it land on automatic like some I have flown. Small mistakes turn what I think is a perfect landing into an average landing with a small bounce or a little bump.
Leaving a little power on can make it float a little more like a GA plane and I found that easier in the beginning. Now the game is to pull all the power off on the down wind leg, not touch it again and put it where I want it, perfectly soft with as short a roll as possible. Oh yeah, and to walk away. Smile
(That's what I was trying to do in the short field landing video I posted a while back.)
Allan
PostPosted: Sat Aug 02, 2014 5:21 am    Post subject: Kolb landing Reply with quote
Allan/Kolbers:
Homer designed his airplanes for low time pilots. He wanted the aircraft to
sit level, or nearly level on the ground. His reason was to require more
airspeed to take off, prevent pulling off too soon, flying out of ground
effect and stalling. He also wanted them to land faster, thus the level
attitude.
I didn't like this level attitude. I wanted to get the nose of the aircraft
up in a more conventional three point attitude. This helps me get off the
ground a little quicker and land in a three point attitude.
Homer also put most of the weight on the main gear to make his airplanes
handle better on the ground. This works well with one exception, the
tendency to nose over because of the light tail. I overcame this by moving
the main gear 8" forward from the stock position. My MKIII is a now a true
tail dragger. It is more difficult to handle on the ground, but has no
tendency to nose over in most any terrain. There is over 100 lbs on the
tail wheel.
All the mods my Brother Jim and I did to my MKIII seem to be working well.
They have been on this MKIII for more than 22 years and 3,300.0 hours. It
is nice to fly an airplane that satisfies all your needs. Don't think there
is anything else to do to Miss P'fer except maintain and fly her.
Allan, I have seen your landings. They look good.
bump.
away. Smile
while back.)
Allan
