Dual master solenoids
Goto page 1, 2  Next
tomhanaway
PostPosted: Sat Jul 12, 2014 1:15 pm    Post subject: Dual master solenoids Reply with quote
Working my way through Nuckoll's Z-13 wiring diagram.
I'm building an 8-a VFR with single battery, single alternator.
I'm not excited about the use of his "always hot" main bus because of the additional wire runs it would create from the buss mounted close to the rear mounted battery and difficulty accessing fuses for those wires.
I'd like to run all electrical busses from the always hot side of the starter solenoid (always hot when master solenoid is hot).
Given this scenario, it seems that the really significant system weakness is the failure of the master solenoid. I was thinking that a second master solenoid, with a separate wire and switch, wired in parallel at the battery, would address this issue.
Does this make sense or am I missing something obvious (or not so obvious)?
Tom H.
RV-10. Built and sold
RV-8a. Building
PostPosted: Sat Jul 12, 2014 3:14 pm    Post subject: Dual master solenoids Reply with quote
those wires.
That's not a "MAIN BUS" . . . it's the MAIN BATTERY
always-hot with exceedingly limited but often important
tasks in getting power distributed to your airplane.
GA airplanes have had always-hot busses since the
clock and hour-meter fuses were mounted right next
to the battery master contactor in the tail . . . in
Cessnas I worked on in 1965.
Study Z-13 again (or perhaps Z-11 which is a single
alternator version). Also the notes for the z-figures
along with the chapter on system reliability.
Not sure what's driving this . . . The Z-figures are
the culmination of over 45+ years experience in TC
aviation enhanced by 25+ years in OBAM aviation exploiting
the freedoms not enjoyed by TC aviation . . . to craft an
architecture that meets YOUR mission requirements . . .
not those of a bureaucracy most of whom do not build or
fly airplanes.
It's not clear that you understand the philosophy behind
the various architectures and functionality of their
several features.
Suggest you PLAN for Z-13/8 by having all the WIRES
in place to have a second alternator . . . unless you're
going to have a vacuum pump, the consider NOT plugging
a perfectly good source of mechanical energy with a
cover plate.
Print out copies of http://tinyurl.com/7jqypwj one for
each bus. It generally takes three.
List each load services by the various busses along
with their magnitudes and flight configurations that
the loads are expected/necessary.
You may not need a battery bus . . . but get all your
loads defined first . . . then decide what bus
structures are needed.
Do you plan any sort of electronic ignition. The
RV8 is low wing so you no doubt have electric
fuel pumps. Does any of your proposed electrics
need memory keep-alive power? I single alternator,
what's your goal for battery-only endurance? The
load analysis study will let you set necessary battery
size based on predicted loads. There's lot of
sifting of requirements that will drive what
gets powered from which busses.
Go with Z-13/8 with second 4-pound alternator
and your alternator-out endurance deliberations
get a WHOLE LOT easier.
bob.verwey(at)gmail.com
PostPosted: Sat Jul 12, 2014 9:54 pm    Post subject: Dual master solenoids Reply with quote
TOM,
Then you may as well have two of everything.
Remember the cardinal rule..." build in simplicity and lightness"
Bob   Verwey On 12 Jul 2014 11:22 PM, "Tomhanaway" <tomhanaway1(at)gmail.com (tomhanaway1(at)gmail.com)> wrote:[quote] --> AeroElectric-List message posted by: Tomhanaway <tomhanaway1(at)gmail.com (tomhanaway1(at)gmail.com)>
Tom H.
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
tomhanaway
PostPosted: Sun Jul 13, 2014 2:56 am    Post subject: Dual master solenoids Reply with quote
I understand that but it doesn't answer my question.
Is there anything from an electrical point of view that keeps this from working. I.e., the backup master solenoid would have 12 vdc at both terminals whenever the primary master solenoid is turned on even if the aux master solenoid switch is not on. My goal is to have the aux solenoid sitting idle unless activated by a switch.
Tom
On Jul 13, 2014, at 1:50 AM, Bob Verwey <bob.verwey(at)gmail.com (bob.verwey(at)gmail.com)> wrote:
TOM,
Tom H.
MS -
e -
RV-8a. Building
kleh(at)dialupatcost.ca
PostPosted: Sun Jul 13, 2014 3:47 am    Post subject: Dual master solenoids Reply with quote
I don't see a problem with a dual master although I wonder if it really
achieves your goal or achieves it as elegantly as one of the Z
architectures. The failures of contactors that I've seen are failures to
activate not failures during flight. I do agree that any truly essential
system such as engine power should not be tied to a single contactor but
the battery buss and/or essential buss concept seem like a better
solution where applicable. Don't forget that a backup has little value
unless tested regularly. For example, I test my backup EFI during taxi
on every flight and it has always worked perfectly. I happened to test
it in flight yesterday and discovered that it has started to miss at
high power which pretty much means it has been useless dead weight for
some undetermined length of time as I do not often test it at high power
settings.
Ken
Tom
<mailto:bob.verwey(at)gmail.com>> wrote:
> TOM,
> Bob Verwey
> <mailto:tomhanaway1(at)gmail.com>> wrote:
> <tomhanaway1(at)gmail.com <mailto:tomhanaway1(at)gmail.com>>
> for those wires.
> obvious)?
> Thanks,
> Tom H.
kjashton(at)vnet.net
PostPosted: Sun Jul 13, 2014 3:48 am    Post subject: Dual master solenoids Reply with quote
There is no electrical reason why your idea won't work but why do it? Master solenoids don't typically fail in-flight. They typically don't fail at all if installed as Bob suggests, unless the posts are tightened incorrectly and twist the internal contacts. If one does fail, you can find a replacement at a FLAPS. If your engine has magnetos, an inflight failure won't matter. If you are using EIs, you'll probably have ignition power straight off the battery so it still won't matter.
Put the cost and the weight-cost of an additional heavy solenoid, additional foot or so of heavy AWG 2-4 wire, additional panel switch and wiring against the low chance you'll ever need it.
-Kent
Cozy IV
PostPosted: Sun Jul 13, 2014 7:00 am    Post subject: Dual master solenoids Reply with quote
At 06:47 AM 7/13/2014, you wrote:
<kjashton(at)vnet.net>
this from working.
. . . and even if they did, the battery-bus/e-bus
architectures are crafted to keep things comfortable
in the cockpit even if it DID fail . . . in fact,
the germinating idea behind the dual-feedpath e-bus
was to facilitate a deliberate opening of the
battery master contactor as part of load shedding
protocol for battery-only operations.
Suggest you do your own failure mode effects
analysis where you consider the risks for a
failure of any single component of your electrical
system. If you discover a failure that puts
comfortable termination of flight at risk,
then let's talk about it. I'm certain
that with judicious selection of accessories
and distribution of power, you can craft
a system where worries about the battery master
contactor are at the bottom of the risk assessment
list.
BobsV35B(at)aol.com
PostPosted: Sun Jul 13, 2014 7:26 am    Post subject: Dual master solenoids Reply with quote
Just a test .Please excuse my interruption.
Old Bob
In a message dated 7/13/2014 10:01:58 A.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
--> AeroElectric-List message posted by: Kent or Jackie Ashton
this from working.
list.
Bob . . . = Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
PostPosted: Sun Jul 13, 2014 10:21 am    Post subject: Dual master solenoids Reply with quote
Old Bob
Bob,
I'm replying through the List and with a copy
to you directly. Have you sorted your email
marbles out?
Bob . . . [quote][b]
PostPosted: Sun Jul 13, 2014 6:10 pm    Post subject: Re: Dual master solenoids Reply with quote
Schematics do not indicate how wires are routed in an aircraft. They show the logic of a circuit, not necessarily the physical layout. The heavy wire that supplies power to the main power distribution bus can be connected to either end of the wire between the two contactors (main battery and start). Your idea of connecting to the always hot side of the starter contactor is identical (electrically speaking) to Bob's schematic.
Like Bob said, the E-bus circuit addresses this issue. If you would rather backup the main battery contactor, it can be done with an automotive 30 or 40 amp relay at a fraction of the weight. The relay must be disabled during engine cranking, maybe like the attached circuit.
But keep in mind that the more complicated and the more components , the more to go wrong.
Joe
Backup Relay.pdf
 Filename:  Backup Relay.pdf
 Filesize:  164.15 KB
 Downloaded:  739 Time(s)
Joe Gores
tomhanaway
PostPosted: Mon Jul 14, 2014 3:15 am    Post subject: Re: Dual master solenoids Reply with quote
Thanks Joe,
Once I started thinking in terms of a relay, this came pretty close to what I was looking for.
Interesting use of a starter enable/disable switch to ensure no cranking current through relay.
Interesting question ( to me, anyway), are heavy duty continuous service relays any less reliable than mechanical relays? If about the same
reliability, what are the reasons that they aren't used more often for a
master solenoid? As you stated, the weight differential is pretty significant.
Thanks again,
Tom
RV-8a. Building
PostPosted: Mon Jul 14, 2014 4:06 am    Post subject: Re: Dual master solenoids Reply with quote
are heavy duty continuous service relays any less reliable than mechanical relays? If about the same reliability, what are the reasons that they aren't used more often for a master solenoid?
There are several ways that a relay or contactor can fail. The contacts can develop a high resistance, the coil can burn open, springs or other mechanical parts can break, and etc. I do not know which type is more likely to fail. The current carrying capability determines which relay or contactor to use. Starters can draw a few hundred amps initially to get the engine rotating. A 30 amp automotive relay would not last very long carrying that much current.
So why have the starter current go though the master contactor? The starter contactor could be wired directly to the battery. I think the reason is that contactors have been known to fail closed. Having two contactors in series makes sure that the circuit can be opened.
Joe
Joe Gores
PostPosted: Mon Jul 14, 2014 6:45 am    Post subject: Dual master solenoids Reply with quote
"Reliability" is a rather soggy concept.
It can mean different things to most speakers
in a group of conversants. If you
write to Stancore/White-Rogers and ask,
just HOW reliable is your 70-110 contactor?
. . . they MIGHT fire back with a laboratory
study that cites cycle-life of the contactor
under various loads and perhaps environmental
conditions. Write to Tyco about reliability
of their Kilovac contactors and you MIGHT
get another report.
Okay, Tyco's numbers are better than S/W-R
numbers . . . now what?
As I've been explaining in my writing and
presentations for the past 30 years, the
elegant design has little, if any, interest
in those numbers. Lessons-learned in over
a century of building airplanes have demonstrated
that the designer's prime directive is to
reduce risk for a bad day in the cockpit.
To be sure, if money, weight, $time$
to market and cost of ownership were
of no concern, then there are virtually
limitless ways that hedges against risk
can be applied to the system. But applied
without the confidence that comes from
understanding there is a larger risk that
the end-product is burdened with "safety
features" that degrade performance to
far greater degrees than protecting the
airframe and crew.
[img]cid:7.1.0.9.0.20140714094258.04cc69a8(at)aeroelectric.com.2[/img]
My teachers would ask, "Okay, you've selected a
whiz-bang part for that location in the airplane,
make your case for the decision." Had I whipped
out the reliability data sheets for the constellation
of choices and said, "See here, look at THOSE numbers!"
they might have banished me to purchasing support
or perhaps the EMC lab.
The first bit of guidance germane to your decision
resides in lessons-learned. Question: How many
times have pilots experienced a bad day in the
cockpit due to in-flight failure of the battery
master contactor?
I haven't a clue . . . because the incidents have
been so few in numbers and so benign as to become
completely buried in COMPONENT failures that
put the whole SYSTEM at risk . . . The aviation
journals are replete with what I have called
"dark n stormy night" stories . . . most of
which are so lacking in data as to defy understanding
of root cause . . . or more illustrative of human
weaknesses than those of the airplane.
Consider that EVERY contactor is RATED and
TESTED in the lab to perform as advertised
for tens of thousands of cycles at rated lioad.
YOUR battery contactor is going to close/open
once per flight cycle . . . perhaps 100 times
per YEAR and under nearly zero-load conditions.
Were you to conduct laboratory reliability
testing for conditions in YOUR airplane, it's
unlikely that you would ever see a failure.
We HAVE seen some failures here on the List.
Detailed analysis revealed failure due to
a variety of reasons including manufacturing
defects
[img]cid:7.1.0.9.0.20140714094258.04cc69a8(at)aeroelectric.com.3[/img]
moisture ingress, and installation error . . . but in no
case were the failures first detected in flight.
Carrying lessons-learned a step further we can conduct
a failure effects study. You do this by ASSUMING that every
part will fail at some point in time. You then analyze
how that failure will affect system performance. For
failures that pose unacceptable risk, you make some
design changes. Except for things like wing struts
and prop bolts, the elegant design drives more toward
failure TOLERANCE than failure PROOF.
See: http://tinyurl.com/ozum5u9
If your studies for optimal design are driving you
toward the purchase of high-dollar hardware -OR-
adding backup components, then perhaps your confidence
born of lessons-learned and artful conduct of
failure analysis is shaky. I suggest that crafting
any of the Z-Figures chosen to match your mission
profiles and hardware will produce an exceedingly
failure tolerant system. I suggest further that
Z13/8 has more bang for the buck/pound/volume than
systems flying in some pretty sophisticated airplanes.
The very first example of Z13-8 flying in an OBAM
aircraft was in an RV-8 in Connecticut about 25
years ago . . . the father-son build team were
delighted with its performance and confidence
levels.
They could loose a battery master contactor
every few months and not suffer a bad day in
the cockpit . . . but I'll bet that the Model
70 contactor installed day-on is still flying.
 Filesize:  237.27 KB
 Viewed:  21154 Time(s)
 Filesize:  157.93 KB
uuccio(at)gmail.com
PostPosted: Tue Jul 15, 2014 5:59 am    Post subject: Dual master solenoids Reply with quote
It's also a safety issue with some starter configurations. For instance if you had a momentary push button for the starter instead of a key switch, even with the master off you would still be able to push the button and turn the prop.
I have this configuration and as an added safety while the aircraft is stopped and the master needs to be on, I always pull the starter CB.
Sacha
stein(at)steinair.com
PostPosted: Tue Jul 15, 2014 6:53 am    Post subject: Dual master solenoids Reply with quote
Aside from some anecdotal references that are oft repeated at hangar flying
sessions and on the interwebs, have you or do you know of a specific
instance where a master contactor/solenoid of standard design failed
repeatedly? All mechanical things have "been known to fail", but we build
airplanes around the 99th percentile, not the 1th percentile. If you built
a perfectly safe airplane, it would be one that wouldn't leave the
ground....so to that end you design in for the 99th, but also take into
account the 1th percentiles without doing crazy things like putting in two
master contactors or two tachometers (unless of course you have two
batteries, or two busses, etc..). If you are going to put in two of those,
why not two starter buttons, or two circuit breakers for each circuit, or
two throttle cables, or two rudders, or two elevator pushrods, (after all,
those have also been known to fail)? You still do only have one camshaft
and one propeller and one crankshaft and one carb/fuel injector, one brain,
etc..
My point is that the probability of failure of that specific components is
likely less than the probability of other equally as important mechanical
things in your plane. There is no reason to randomly pick one particular
component and focus on it over another when it has not proven to be a weak
point in the entire aerospace vehicle system design.
Just my 2 cents as usual, but one could come up with all sorts of 1th
percentile "possibilities" that are really not worth expending energy, time,
money, weight or complexity on as the return on all of that in actuality
becomes a negative. Remember, adding things for "redundancy" does not
necessarily and automatically translate into reliability - many times it has
the inverse effect (increased complexity = decreased reliability).
Stein
PostPosted: Tue Jul 15, 2014 10:56 am    Post subject: Dual master solenoids Reply with quote
Irrespective of the kind of switch that energizes
the starter, I'm aware of no TC aircraft, or any
OBAM aircraft wired per a Z-figure where this is
the cased. The general rule of thumb for all
airplanes is that opening the battery master
contactor removes ALL power from the aircraft
except for those items wired to a battery bus.
Starters should be dead-in-place with the
battery master off.
How was it that you came to wire your airplane
this way?
PostPosted: Tue Jul 15, 2014 11:35 am    Post subject: Dual master solenoids Reply with quote
Precisely . . .
When opening the seminar segment on
reliability, I like to put a z-figure
up on the screen, point to a component
and ask, "What do you need to do if THIS
part malfunctions?"
At least one participant will suggest
that it be replaced with a 'better part'.
That's the segment where I pose the notion
that the flight SYSTEM consists of an airframe,
pilot, environment and expendable resources.
From the time the wheels break ground until
you're parked at the destination, the design
goal is not break a sweat . . . irrespective
of any component failure.
The last few ideas offered at the end of
the segment suggests that it doesn't matter
if you buy electrical parts from Autozone, $high$
parts from Honeywell or TC aircraft parts from
the Cessna warehouse . . . it is possible to
ARCHITECTURE the electrical system such that
no single component failure will induce an
in-flight sweat.
In the final analysis, you're more likely
to have a bad day in the cockpit driven by
events and conditions far removed from
things electrical. #1 cause of engine
stoppage is fuel starvation. #1 cause
for unplanned arrivals with the earth
are most often based on human factors for dealing
with environment: weather, mountains,
night ops, etc.) As we have studied many
times here on the List . . . mishaps
that included electrical issues were
FIRST driven by lapses in assembly skills,
failure tolerant design or poor maintenance.
See: http://tinyurl.com/ky7szec
In other words, "two parts" or a "better
part" would not have produced a better
outcome.
uuccio(at)gmail.com
PostPosted: Tue Jul 15, 2014 12:34 pm    Post subject: Dual master solenoids Reply with quote
battery master off.
Hi Bob, I was referring to the hypothetical situation that Joe brought up
where the starter contactor would be always hot, i.e. wired to the battery
bus.
this way?
My apologies, I wasn't very clear... My electrical setup is essentially
Z-16, but the starter button is a push button. So whenever I am tinkering
around on the ground and the master needs to be on, I pull the starter CB
just to be safe. Another situation is when my three year old wants to sit
next to me in the a/c and see the panel light up and pretend he's flying the
aircraft... Smile
PostPosted: Tue Jul 15, 2014 3:11 pm    Post subject: Dual master solenoids Reply with quote
aircraft... Smile
Understand . . . thanks!
PostPosted: Tue Jul 15, 2014 5:57 pm    Post subject: Re: Dual master solenoids Reply with quote
bus.
I did not bring that up. I was referring to tomhanaway's post where he wrote, "the always hot side of the starter solenoid (always hot when master solenoid is hot)".
It is much easier to understand each other when talking face to face compared to email or forum postings. Smile
Joe
Joe Gores
Goto page 1, 2  Next
Page 1 of 2
