| bkirkwoo(at)elp.rr.com Guest
				|  Posted: Mon Jun 30, 2014 4:48 am    Post subject: Reduction Gear Problems |   |
				| I want to thank everyone who responded to my question. I replaced the reduction gear with what I hoped would be a serviceable unit and the problem went away. Thanks to everyone!
 ---- BillLeff1(at)aol.com wrote:
  	  | Quote: |  	  | Your problem is the oil transfer rings are worn out in the nose case. This is a common problem. The seal rings on the oil transfer assembly and the
 oil  transfer sleeve are leaking too much oil to properly transfer oil from
 the nose  case to the prop shaft to work the propeller.
 The nose case can be removed and sent out for overhaul or  repair without
 removing the engine. I assume that the engine has about  1200-1400 hours on
 it.
 Central Cylinder is the best place to send it. There is a shop at Opa-Locka
 Florida
 If you have questions call me
 Bill Leff
 937-369-3334
 In a message dated 5/8/2014 2:49:21 P.M. Eastern Daylight Time,
 bkirkwoo(at)elp.rr.com writes:
 The  problem is that the propeller, after the oil is good and warmed up,
 wants to  go to feather at any RPM less than 1500-1800. Oil pressure is good
 at the back  of the engine, have tried different governors, have changed
 props.
 ----  Bill Leff <BillLeff1(at)aol.com> wrote:
 > Central Cylinder Omaha.  What is the problem?
 Bill Leff
 Sent from my Verizon Wireless 4G  LTE DROID
 bkirkwoo(at)elp.rr.com wrote:
 >--> Commander-List  message posted by: <bkirkwoo(at)elp.rr.com>
 >Who do you  recommend for solving problems with the reduction gear on a
 GO-480?
 | |  |  | - The Matronics Commander-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Commander-List
