How to decide if a heat sink is required for a Rect Brid
jskiba(at)icosa.net
PostPosted: Sun Jun 22, 2014 8:09 pm    Post subject: How to decide if a heat sink is required for a Rect Brid Reply with quote
I wanted to have one for each device in case the device eat the diode or the diode eat itself ( I might get power for the diodes from the two regular busses as well instead of the battery busses but then that means I must have a relay energized with just battery power
Here’s a clip but I have attached pdf of what I have thus far on the layout….
 Filesize:  26.44 KB
 Viewed:  956 Time(s)
2014-MAIN-power-dist-N973A_fadec_Model_(1).pdf
 Filename:  2014-MAIN-power-dist-N973A_fadec_Model_(1).pdf
 Filesize:  107.51 KB
 Downloaded:  174 Time(s)
2014-MAIN-power-dist-N973A_fadec_Model_(2).pdf
 Filename:  2014-MAIN-power-dist-N973A_fadec_Model_(2).pdf
 Filesize:  66.3 KB
 Downloaded:  218 Time(s)
