leaking nylo -seal fittings
sarg314(at)gmail.com
PostPosted: Sun Jun 22, 2014 7:30 pm    Post subject: leaking nylo -seal fittings Reply with quote
I have a pretty big leak in my static air system.  I used nylo-seal fittings throughout.   I never know how tight to make them.  How do you know when to stop tightening? I just use my fingers. The leaking fitting is a T screwed into my altimeter. I've tested all the components and when I added the T, I added a leak.
Is there any point in putting teflon tape on the threads to improve the seal?  How about something like a little silicone sealant around base of the fitting after it's screwed in?
Or do I just keep tightening the thing until it seals?
Thanks for any wisdom/experience on this subject.
Tom Sargent
dave.saylor.aircrafters(a
PostPosted: Sun Jun 22, 2014 7:59 pm    Post subject: leaking nylo -seal fittings Reply with quote
Teflon tape on pipe threads (ie, into the back of instruments) will help a lot.  It won't help at all on the B-nuts.  The threads that accept a B-nut are different from the NPTs that go into instruments.
If you didn't use the little plastic inserts that go in the end of the tubes, that makes a huge difference.
I like using a crow's foot to tighten nylon B-nuts.  It's handy in cramped quarters and keeps me from over doing the torque.
--Dave
On Sun, Jun 22, 2014 at 8:29 PM, Thomas Sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
[quote] I have a pretty big leak in my static air system.  I used nylo-seal fittings throughout.   I never know how tight to make them.  How do you know when to stop tightening? I just use my fingers. The leaking fitting is a T screwed into my altimeter. I've tested all the components and when I added the T, I added a leak.
Tom Sargent
t="_blank">http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com
carl.froehlich(at)verizon
PostPosted: Mon Jun 23, 2014 5:30 am    Post subject: leaking nylo -seal fittings Reply with quote
The plastic inserts are required.  I used these on two airplanes and pitot static come out tight as a drum.  Never found a need for tape on the hose fitting side as the threads are not the seal – the nylon ferrule that seats in the fitting is the seal.  I do add some Teflon pipe thread sealant (auto part store stuff) on the pipe thread fittings that screw into instruments and such.
After you break off a nut or two by over tightening you quickly get a sense of “tight enough”.
Carl
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor
Sent: Sunday, June 22, 2014 11:58 PM
To: rv-list(at)matronics.com
Subject: Re: leaking nylo -seal fittings
--Dave
Tom Sargent
t="_blank">http://www.matronics.com/Navigator?RV-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
PostPosted: Mon Jun 23, 2014 8:09 am    Post subject: leaking nylo -seal fittings Reply with quote
I am using the insert on th 1/4" poly tubing. By "insert" I mean the little "sleeve that fits over the tubing, not the other free floating piece that goes inside the fitting.  However, that's not the part that's leaking (I think). The "nut" isn't leaking. it's the NPT part that screws into the instrument.  I'm pretty sure about this.  I should devise an experiment to prove my thinking.
It was my understanding that the free-floating inserts are not necessary except with certain kinds of tubing.  Maybe I misunderstand that. Do you always have to use the insert?
Tom Sargent
vanremog(at)aol.com
PostPosted: Mon Jun 23, 2014 8:23 am    Post subject: leaking nylo -seal fittings Reply with quote
I've found that Loctite PST works well in this application
Sent from my Verizon Wireless 4G LTE DROID
Tom Sargent
PostPosted: Mon Jun 23, 2014 8:42 am    Post subject: leaking nylo -seal fittings Reply with quote
Tom,
I said insert but I should have said "tube support".  They look like this:
[img]cid:ii_146c991e6fc5a49b[/img]
​They fit inside the end of the tube.
You're right, according to a note from McMaster-Carr, they aren't needed for harder tubing​:
"Tube supports are recommended for polypropylene, polyethylene, and nylon tubing with a hardness of Shore A70 or less".
I tubing I prefer is pretty soft, almost rubbery.  I use tube supports anywhere there's a B-nut.
If you have some smooth-jawed vice grips or some other clamp, you can clamp pinch the tubing to isolate various sections as you chase down the leak.
--Dave
On Mon, Jun 23, 2014 at 9:07 AM, Thomas Sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
Tom Sargent
 Filesize:  2.96 KB
 Viewed:  7021 Time(s)
PostPosted: Thu Jun 26, 2014 1:33 pm    Post subject: leaking nylo -seal fittings Reply with quote
Dave:
Yes, that was my main problem. A few of the fittings didn't have the "tube support".  That and some teflon tape on the T's that screwed into the instruments fixed the problem.
On Mon, Jun 23, 2014 at 9:41 AM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)> wrote:
Tom,
--Dave
Tom Sargent
Tom Sargent
 Filesize:  2.96 KB
 Viewed:  7008 Time(s)
PostPosted: Thu Jun 26, 2014 5:26 pm    Post subject: leaking nylo -seal fittings Reply with quote
Yeah, those things seem kind of optional until you spend enough hours with the fuel valve digging into your back, looking for leaks behind the panel. I'm glad that helped.
--Dave
--Dave
On Thu, Jun 26, 2014 at 2:30 PM, Thomas Sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
Dave:
Tom,
--Dave
Tom Sargent
Tom Sargent
 Filesize:  2.96 KB
