lcottrell
Posted: Sun Jun 22, 2014 2:16 pm Post subject: video and new mount |
I got tired of the Jello that I was seeing in my videos, so I decided to copy some of the better mounts that I have seen. The one that interested me was on the wing. I decided to try the wing support tube that is just hanging there to see if I could secure it enough to get a solid mount. You of course need a remote to turn on and off your camera, but it is much nicer than what I had been using. Here is a short video taken with it.
https://vimeo.com/98877897 Password- owyheeflyer
Larry
1.54 MB |
3631 Time(s) |
1.27 MB |
3631 Time(s) |
1.33 MB |
3631 Time(s) |
Posted: Mon Jun 23, 2014 10:39 am Post subject: video and new mount |
Been looking at the camera,,, removed one screw and found the contacts for the switch...I can run 2 wires out and have a remote...or run 4 wires out and plug into a D size battery pack and a remote.... that sounds like a win win... I need to find a good plug On Jun 22, 2014 4:40 PM, "Larry Cottrell" <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:[quote] I got tired of the Jello that I was seeing in my videos, so I decided to copy some of the better mounts that I have seen. The one that interested me was on the wing. I decided to try the wing support tube that is just hanging there to see if I could secure it enough to get a solid mount. You of course need a remote to turn on and off your camera, but it is much nicer than what I had been using. Here is a short video taken with it.
Larry
Posted: Mon Jun 23, 2014 10:40 am Post subject: video and new mount |
I did not see jello. Did you try different rpm's? On Jun 22, 2014 4:40 PM, "Larry Cottrell" <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:[quote] I got tired of the Jello that I was seeing in my videos, so I decided to copy some of the better mounts that I have seen. The one that interested me was on the wing. I decided to try the wing support tube that is just hanging there to see if I could secure it enough to get a solid mount. You of course need a remote to turn on and off your camera, but it is much nicer than what I had been using. Here is a short video taken with it.
Larry
lcottrell
Posted: Mon Jun 23, 2014 1:16 pm Post subject: video and new mount |
There was no jello with the new mount. I am pleased.Larry
On Mon, Jun 23, 2014 at 12:40 PM, B Young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
I did not see jello. Did you try different rpm's? On Jun 22, 2014 4:40 PM, "Larry Cottrell" <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote: | Quote: | I got tired of the Jello that I was seeing in my videos, so I decided to copy some of the better mounts that I have seen. The one that interested me was on the wing. I decided to try the wing support tube that is just hanging there to see if I could secure it enough to get a solid mount. You of course need a remote to turn on and off your camera, but it is much nicer than what I had been using. Here is a short video taken with it.
Larry
tp://forums.matronics.com
