asarangan(at)gmail.com Guest
Posted: Mon Jun 16, 2014 6:17 am Post subject: Noncontact fuel level indicator |
The fuel tank is translucent. One can clearly see the fuel level by
eye. So, it occurred to me why not build a fuel level sensor that
attaches to the outside of the tank? I recently built such a unit with
LED illuminators and detectors, and it works like a charm. It even
shows the waves when the fuel is sloshing around. Only question is,
how does the translucency of the tank change with time? If it becomes
totally opaque in a few years, then this won't work. I can post
further details of the device if anyone is interested.
pete(at)lawless.info Guest
Posted: Mon Jun 16, 2014 6:41 am Post subject: Noncontact fuel level indicator |
Hi Andrew
My tank is 12 years in use and you can still see through it.
Be very interested to see details of your design. I have a flow meter
and a tank float gauge but which would you believe if they disagreed?
Pete
G-RMAC Classic #109
On 16/06/14 15:15, Andrew Sarangan wrote:
kingsnjan(at)westnet.com. Guest
Posted: Tue Jun 17, 2014 1:53 am Post subject: Noncontact fuel level indicator |
Andrew,
What to do about a fuel gauge has been a bone of contention for me. I would
very much appreciate your sharing how you made your device.
Only thing is, can your set-up be accomplished AFTER the fuel tank and
module are installed?
Kingsley in Oz.
Posted: Tue Jun 17, 2014 6:03 am Post subject: Noncontact fuel level indicator |
I will take some photos and write up some details in a few days.
The idea was based on what I accidentally observed one day when
holding a flash light to the fuel tank. When the flash light is held
below the fuel level, the entire fluid lights up. When the flash light
is above the level, the tank lights up. The contrast across the fluid
level is about 10x. This is due to light being trapped above or below
the level. See attached pictures.
So, I made a board with four LEDs in a column, and another board with
10 photodetectors in a column. Using a microcontroller, I am flashing
each LED in sequence, and then computing the liquid level based on the
measured contrast. The output is displayed on a 10-bar display. The
LED board will attach to the aft of the baggage bay bulkhead, with
four holes to allow the light to get through. The detector board has
to attach somewhere on the front side of the tank. This might be the
tricky part because I need to make sure it is secure, but also
removable and does not interfere with the controls.
On Tue, Jun 17, 2014 at 5:52 AM, Kingsley Hurst
Andrew,
Kingsley in Oz.
203.58 KB |
18046 Time(s) |
197.15 KB |
18046 Time(s) |
peterz(at)zutrasoft.com Guest
Posted: Tue Jun 17, 2014 6:37 am Post subject: Noncontact fuel level indicator |
Ingenious! Truly slick and (mechanically) simple and non-intrusive. Patent it, quick!
Would you be amiable to supplying code etc. to avoid duplication of effort?
Cheers and thx!
Pete
A239
On Tue, Jun 17, 2014 at 10:02 AM, Andrew Sarangan <asarangan(at)gmail.com (asarangan(at)gmail.com)> wrote:
[quote]I will take some photos and write up some details in a few days.
<kingsnjan(at)westnet.com.au (kingsnjan(at)westnet.com.au)> wrote:
> --> Europa-List message posted by: "Kingsley Hurst"
> Andrew,
> What to do about a fuel gauge has been a bone of contention for me. Â I would
> Thanks
> Kingsley in Oz.
nigel_graham(at)m-tecque. Guest
Posted: Tue Jun 17, 2014 7:07 am Post subject: Noncontact fuel level indicator |
I did a similar thing some years back when building an alloy tank. I
used a series of solid-state liquid level sensors (data sheet attached)
that incorporate a photo diode and photo transistor moulded into a
polysulphone housing. The domed end uses the simple effect of total
internal reflection to either switch the transistor on or off depending
on whether it is immersed or not.
I mounted mine in tapped bosses on the surface of the tank, but these
could easily be built into a "dip-stick" and mounted from the top of the
plastic tank. Just another variation on a theme.
Nigel
On 17/06/2014 15:02, Andrew Sarangan wrote:
[quote] I will take some photos and write up some details in a few days.
> Andrew,
> Thanks
> Kingsley in Oz.
XP4059_-_Liquid_Level_Sensor.pdf |
71.29 KB |
683 Time(s) |
Fred Klein
Posted: Tue Jun 17, 2014 7:37 am Post subject: Noncontact fuel level indicator |
Andrew…I’m dazzled…you are indeed a very clever fellow…kudos…Fred
> Andrew,
> Thanks
> Kingsley in Oz.
Posted: Tue Jun 17, 2014 7:40 am Post subject: Noncontact fuel level indicator |
Very nice sensor (I would go the paralled 'dipstick' tube route) - thx for the link! I could not find any compatibility tables and wonder if any of the nasties (are there chlorinated solvents?) in auto fuel are a problem.
I guess the key to Andrew's eloquent solution of actually using the tank as the optical refractor is that there is no fuel contact with any sensors, nor any additional plumbing required.
Cheers & thx,
Pete
On Tue, Jun 17, 2014 at 11:07 AM, Nigel Graham <nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)> wrote:
[quote]I did a similar thing some years back when building an alloy tank. I used a series of solid-state liquid level sensors (data sheet attached) that incorporate a photo diode and photo transistor moulded into a polysulphone housing. The domed end uses the simple effect of total internal reflection to either switch the transistor on or off depending on whether it is immersed or not.
I mounted mine in tapped bosses on the surface of the tank, but these could easily be built into a "dip-stick" and mounted from the top of the plastic tank. Just another variation on a theme.
Nigel
[quote] --> Europa-List message posted by: "Kingsley Hurst"
Andrew,
Kingsley in Oz.
Posted: Tue Jun 17, 2014 8:25 am Post subject: Noncontact fuel level indicator |
(since "it's only sofware" .....
 I could see using two banks of LED's and sensors, one for each side of the saddle, which would provide for very easy and quick self-check/fault detection (when above reserve), as well as L/R reserve levels when getting that low on fuel.
That is truly cool.
Pete
On Tue, Jun 17, 2014 at 11:37 AM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
[quote]--> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
On Jun 17, 2014, at 7:02 AM, Andrew Sarangan <asarangan(at)gmail.com (asarangan(at)gmail.com)> wrote:
>> Andrew,
>> Thanks
>> Kingsley in Oz.
wdaniell.longport(at)gmai Guest
Posted: Tue Jun 17, 2014 8:39 am Post subject: Noncontact fuel level indicator |
Yes very cunning indeed. Im Deeply impressed too On 17 Jun 2014 11:30, "Peter Zutrauen" <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:[quote] (since "it's only sofware" .....
That is truly cool.
Pete
>> Andrew,
>> Thanks
>> Kingsley in Oz.
Posted: Tue Jun 17, 2014 9:17 am Post subject: Noncontact fuel level indicator |
One could easily make two sets of these boards and install on both
sides of the saddle.
There is a major caveat to this method - if the tank is full to the
brim, the sensor will not be able to detect the edge, so it will give
an error. Similary, if the level is below the lowest photodetector, it
will read an error. Now, there might be a way to detect those
conditions too, by checking the light intensity and color, but I
didn't go that far.
The chip is Atmel ATTiny40 and the code is in C. I can provide that so
one does not have to redevelop it.
I will post details after this weekend.
On Tue, Jun 17, 2014 at 12:24 PM, Peter Zutrauen <peterz(at)zutrasoft.com> wrote:
that low on fuel.
That is truly cool.
Pete
On Tue, Jun 17, 2014 at 11:37 AM, Fred Klein <fklein(at)orcasonline.com> wrote:
> >> Andrew,
> >> would
> >> Thanks
> >> Kingsley in Oz.
Posted: Tue Jun 17, 2014 10:07 am Post subject: Noncontact fuel level indicator |
Cool! I'll be looking forward to having some fun in C
The Full/empty condition could be accomplished with an intensity check (as you have suggested) in parallel with keeping the recent historical data/trend for context (ie full vs empty)
thx!
Pete
On Tue, Jun 17, 2014 at 1:16 PM, Andrew Sarangan <asarangan(at)gmail.com (asarangan(at)gmail.com)> wrote:
[quote]--> Europa-List message posted by: Andrew Sarangan <asarangan(at)gmail.com (asarangan(at)gmail.com)>
didn't go that far.
On Tue, Jun 17, 2014 at 12:24 PM, Peter Zutrauen <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
> Â I could see using two banks of LED's and sensors, one for each side of the
> that low on fuel.
> That is truly cool.
> Cheers,
> Pete
>> >> Andrew,
>> >> would
>> >> Thanks
>> >> Kingsley in Oz.
tonyrenshaw268(at)gmail.c Guest
Posted: Tue Jun 17, 2014 2:25 pm Post subject: Noncontact fuel level indicator |
Hi Andrew,
Its probably not worth worrying about either of the scenarios, too much or too little fuel. In both cases you know why, so possibly that is irrelevant. It’ll come good when the level drops from full, and there is a really big indicator out the window if the fuel gets too low.
TR
didn't go that far.
> that low on fuel.
> That is truly cool.
> Cheers,
> Pete
>>>> Andrew,
>>>> would
>>>> Thanks
>>>> Kingsley in Oz.
Posted: Tue Jun 17, 2014 2:48 pm Post subject: Noncontact fuel level indicator |
Many thanks Andrew, much appreciated. Oh to have a knowledge of
microprocessors and all that stuff! My only experience with electronics was
in the discrete component age in the early 60's when a flip flop was on a 42
pin module. I thought that was marvellous at the time!!
I await further updates from you.
Cheers
Kingsley
Posted: Wed Jun 18, 2014 2:52 pm Post subject: Noncontact fuel level indicator |
Andrew, since you are writing code you might like to incorporate compensation tables for the shape of the tank so you get a linear scale.
The system I have is a variant of Tony K's that weights the fuel with a 0 ~ 1" pressure transducer. The fuel sloshing and tank shape compensation is done with a PIC Micro. It has worked flawlessly for 10 years.
Cheers, Paul
Posted: Sun Jun 22, 2014 6:13 pm Post subject: Noncontact fuel level indicator |
Regarding the fuel indicator, I made a brief video to show how it
works. Here is the link: https://www.youtube.com/watch?v=zagLfErDOQI
On Wed, Jun 18, 2014 at 6:51 PM, Paul McAllister
Cheers, Paul
Posted: Sun Jun 22, 2014 6:45 pm Post subject: Noncontact fuel level indicator |
An ingenious solution, and perfectly executed. Kudos!
You could sell it easily to the other builders like me, or at least the board layout, and code....(which I'd like to duplicate for each saddle, and add some software error checking etc).
Thanks for the great vid!!
Pete
A239
[quote] On Jun 22, 2014, at 10:12 PM, Andrew Sarangan <asarangan(at)gmail.com> wrote:
> Cheers, Paul
Posted: Sun Jun 22, 2014 7:21 pm Post subject: Noncontact fuel level indicator |
Will be happy to send you the board layout, schematics and the code.
Let me clean it up a bit so it is a more readable.
Pete
A239
>> Cheers, Paul
Fred Klein
Posted: Sun Jun 22, 2014 8:48 pm Post subject: Noncontact fuel level indicator |
Andrew…how outstanding…well done…I salute you for your skill and understanding of a realm in which I fear to tread…Fred
On Jun 22, 2014, at 7:12 PM, Andrew Sarangan <asarangan(at)gmail.com (asarangan(at)gmail.com)> wrote:
[quote]Regarding the fuel indicator, I made a brief video to show how itworks. Here is the link: https://www.youtube.com/watch?v=zagLfErDOQI[b]
rlborger(at)mac.com Guest
Posted: Mon Jun 23, 2014 3:35 am Post subject: Noncontact fuel level indicator |
Andrew,
It is one fantastic idea!
Question: Since you are looking at diffused/scattered light not transmitted light, does it require 2 boards or could the whole thing be done with a single board? LED’s down the left side & detectors down the right. Perhaps a light barrier between the emitters & detectors. Less wiring complication that way?
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs).
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
Cheers, Paul
