genie(at)swissmail.org Guest
Posted: Thu Jun 12, 2014 9:53 am Post subject: Starting an RV-6 with a Lycoming O-320 |
For several months my RV-6 has experienced starting problems. At first
go the engine would hardly turn as there did not seem to be enough power
from the starter motor. After repeated attempts things would
progressively improve until there was enough power to start the engine.
Since the end of last month the starter motor has simply not been able
to provide enough power to start my engine.
I removed the starter motor and had it tested. It jumped to life when
exposed to enough voltage. Therefore this was apparently not the problem.
Measurements initially seemed to indicate that the battery was OK.
However, later it appeared that the battery could not provide enough
tension. I removed it and measured it. It provides almost 11.7 V at
present. I reckon that the battery is, if not the only problem, then one
of the problems.
A fellow aircraft owner told me that he believes that the problem is
with the relay. That is why, according to him, in the past I initially
had problems in starting but after several attempts I succeeded. Could
this in your opinion be the case? Does anyone by chance know where can I
find a replacement relay, which companies make suitable relays and what
their part numbers are?
As for my battery, it is an Odyssey PC 680 by Enersys. When in the
hangar it is always kept under tension by a battery charger. Is this
battery the optimal choice for a Lycoming O-320 powered RV-6 or RV-6A?
Do you know whether any other batteries would be just as good or better?
I have found sources for such a battery.
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
P.S. I have sent this on both the RV-6 and Lycoming lists. Please excuse
me if you receive the same message more than once.
jluckey(at)pacbell.net Guest
Posted: Thu Jun 12, 2014 11:06 am Post subject: Starting an RV-6 with a Lycoming O-320 |
George,
The PC 680 should be fine - lots of RVers use them. However, a resting battery voltage of 11.7 volts is a bad thing. That is essentially a dead battery. A healthy battery should have a resting voltage > 12.5 volts.
I would start with a new battery. If that does not solve the problem we can look at the start solenoid (relay).
Also, be advised that some battery charger/maintainers do not have the proper output for maintaining this type of battery and will actually decrease battery life. There was a thread here on the Aeroelectric List some months ago where BobN analyzed the charge curves of a few battery maintainers and recommended one. I know it was a Schumacher and I think is was model number 1562A (around $20). (somebody please correct me if that's wrong)
-Jeff
On Thursday, June 12, 2014 11:03 AM, George Nielsen <genie(at)swissmail.org> wrote:
--> AeroElectric-List message posted by: George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)>
of the problems.
Thanks.
George Nielsen
RV-6 PH-XGN
me if you receive the same message more than nbsp; --> http://www.matronics.com/Navigator?AeroElectric-List
fvalarm(at)rapidnet.net Guest
Posted: Thu Jun 12, 2014 11:18 am Post subject: Starting an RV-6 with a Lycoming O-320 |
Hi George,
Since no one else has replied yet, I'll offer my thoughts.
It is my understanding that the PC680 does not respond well to constant
charge. I'm not sure if this battery is recoverable, but you can try. You
may find some methods on the net, or someone else may chime in here.
What is the open circuit voltage?
What is the charger's voltage output?
What is the battery charge about an hour after you remove the charger?
How old is it?
Has it bulged, enlarged or deformed in anyway?
Have you contacted the manufacturer?
The PC680 has a reputation as a very good battery for our applications.
However, if you find you need to replace it, consider one of the new LiFePo
such as EarthX and save about 11 LB. I am.
Bevan
Canada
Posted: Thu Jun 12, 2014 2:26 pm Post subject: Starting an RV-6 with a Lycoming O-320 |
At 02:04 PM 6/12/2014, you wrote:
| Quote: | George,
I would start with a new battery. If that does not solve the problem we can look at the start solenoid (relay). |
Try using jumper cables to put a car battery in
parallel with your ship's battery . . . if you see
a marked improvement, then load check the battery.
No improvement, start looking at interconnecting
hardware and wiring.
| Quote: | | Also, be advised that some battery charger/maintainers do not have the proper output for maintaining this type of battery and will actually decrease battery life. There was a thread here on the Aeroelectric List some months ago where BobN analyzed the charge curves of a few battery maintainers and recommended one. I know it was a Schumacher and I think is was model number 1562A (around $20). (somebody please correct me if that's wrong) |
That's the one. I've had good luck with the Battery
Tenders too. I don't recall if I mentioned my disappointment
with the charger-gods at Schumacher with the performance of
an XC75W charger a couple weeks ago
[img]cid:.0[/img]
This 'super whippy' product was supposed to massage any of
the common technologies. In fact, when I tried the Standard
and AGM modes during some battery tests, the thing peaked
out at well over 15 volts . . . only the GEL mode proved to
be a profile I'd want to use with ANY battery. I've still
got it on my list of things to do to forward this data to
Schumacher with some hope of receiving clarification.
77.19 KB |
8680 Time(s) |
toddheffley
Joined: 24 Mar 2010 Posts: 8 Location: Fort Worth Texas
Posted: Fri Jun 13, 2014 5:41 am Post subject: Re: Starting an RV-6 with a Lycoming O-320 |
Boy.
Did I ever suffer hard with the same squawk in a c182. Hope this helps.
I tested the battery voltage WHILE CRANKING with a simple Simpson volt meter. The meter would dip from 12.5ish to 10ish under heavy load.
That seemed resonable.
Then I tested the starter voltage (post of the starter to case of the starter) WHILE CRANKING. It was dipping to 5.5vdc on the compression strokes.
Unreasonable.
I put the meter from the battery + terminal to the starter + terminal.
During cranking there was .75vdc of "drop" from the battery to the starter post.
Seemed resonable.
Then I connected the volt meter from the - terminal of the battery to the case of the starter.
WHILE CRANKING there was 5.5 v of "loss".
Further troubleshooting lead to the fact that the small straps at each lord mount were the only engine ground..... no where near enough.
Big fat ground wire...... big fat smile.
Since then one of my troubleshooting guideposts is........ use HIGH CURRENT to troubleshoot high current failures.
Cautions apply.... you are spinning the meat clever out the front while troubleshooting.......murphy.
Hope it helps
_________________ WWW.toddheffley.com
www.theinterconnectco.com for lighting products
AV-TS.com for Jet Aircraft Test Equipment
rv6awingman(at)gmail.com Guest
Posted: Fri Jun 13, 2014 5:42 am Post subject: Starting an RV-6 with a Lycoming O-320 |
Just 2 weeks ago I replaced a 6 mo old PC680 in my RV-6A with 0-360 Lyc. The engine had started fine the weekend before but now it wouldn't even hold the starter engaged. My panel volt meter showed 8.6v. when resting. I do not use a wall charger as I fly often enough. So I took the battery out and returned to the store where purchased. Later, after they "fully charged it" it was holding voltage at 13.3V yet wouldn't put out half of its CCA rating. Solution was a new battery under warranty replacement.
YMMV
Marty
Time: 03:26:51 PM PST US From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> Subject: Re: Starting an RV-6 with a Lycoming O-320 At 02:04 PM 6/12/2014, you wrote: >George,> >The PC 680 should be fine - lots of RVers use them. However, a>resting battery voltage of 11.7 volts is a bad thing. That is >essentially a dead battery. A healthy battery should have a resting >voltage > 12.5 volts.> >I would start with a new battery. If that does not solve the>problem we can look at the start solenoid (relay). Try using jumper cables to put a car battery in parallel with your ship's battery . . . if you see a marked improvement, then load check the battery. No improvement, start looking at interconnecting hardware and wiring. >Also, be advised that some battery charger/maintainers do not have >the proper output for maintaining this type of battery and will>actually decrease battery life. There was a thread here on the >Aeroelectric List some months ago where BobN analyzed the charge >curves of a few battery maintainers and recommended one. I know it >was a Schumacher and I think is was model number 1562A (around $20). >(somebody please correct me if that's wrong) That's the one. I've had good luck with the Battery Tenders too. I don't recall if I mentioned my disappointment with the charger-gods at Schumacher with the performance of an XC75W charger a couple weeks ago Emacs! This 'super whippy' product was supposed to massage any of the common technologies. In fact, when I tried the Standard and AGM modes during some battery tests, the thing peaked out at well over 15 volts . . . only the GEL mode proved to be a profile I'd want to use with ANY battery. I've still got it on my list of things to do to forward this data to Schumacher with some hope of receiving clarification. Bob
