rmhou(at)yahoo.com Guest
Posted: Wed Jun 04, 2014 3:24 pm Post subject: Comm Radio Transmit Problem |
The Terra 760D comm radio in my Pazmany is getting harder for ATC to hear over time. Last weekend, my home field tower controller couldn't even hear me when I was only 5 miles away.
So I formed a plan to find the issue relating to my comm radio or the antenna. My plan was to remove antenna coax cable from Terra comm and connect it to my Icom portable radio then go flying. If tower controller could hear me over the Icom without issue, the problem most likely is in the Terra comm.
Feeling good about my plan, I went ahead and made the needed connections, including connecting Icom to ship power. I also connected my headset directly to my Icom bypassing intercom. I tested it with ground and got a "loud and clear" reply.
I then started the engine, listened to ATIS, then called ground to taxi. This time the ground controller said he only received a transmit carrier. Thinking it maybe noise from ship power, I connected Icom to its battery pack then call ground, but the ground controller still could not hear me. I then turned the master switch off, called ground again and received a "loud and clear" reply. All of the above were done while the engine was still running.
I think the problem maybe in my charging system, most likely my alternator. But I have no idea what to do next to locate the problem. Any suggestion?
Thanks in advance,
Robin Hou
fherr(at)cfl.rr.com Guest
Posted: Wed Jun 04, 2014 3:50 pm Post subject: Comm Radio Transmit Problem |
Hi Robin,
Not sure about your specific system; but, how old is your main battery?
My radios had some issues until I replaced the four year old (Concorde) battery. Maybe the alternator could not keep the battery supplied with enough volts and enough amps to run the on board system?
Suggestion: swap in a new battery and see if it works.
Francis
Thanks in advance,
Robin Hou
href="http://www.matronics.com/Navigator?Avionics-List">http://www.matronics.com/Navigator?Avionics-List
Kellym
Posted: Wed Jun 04, 2014 4:44 pm Post subject: Comm Radio Transmit Problem |
The other side of the coin could be either alternator diode failed or
the alternator noise filter (capacitor/condenser) failed.
On 6/4/2014 4:49 PM, Francis Herr wrote:
| Quote: | Hi Robin,
supplied with enough volts and enough amps to run _the on board _system?
Francis
Any suggestion?
Thanks in advance,
Robin Hou
KCHD |
