Vans EGT gauge not working...
mburbidg(at)gmail.com
PostPosted: Fri Jun 06, 2014 7:16 pm    Post subject: Vans EGT gauge not working... Reply with quote
My Vans EGT gauge does not work. Not flying yet, but have done engine start. And after a few minutes the EGT gauge is still pegged at 0. The CHT gauge does work. These gauges are hooked to a single cylinder. Its a brand new gauge and sender.
Here's what I've done so far:
1) Verified power and ground to the gauge.
2) Verified continuity in the sender wires between the gauge and the space connectors.
3) Verified that the sender wires are on the correct terminal on the gauge.
I'm not sure what to do next, but I would like to figure some way to determine if the problem is with the gauge, or the sender.
How would I do that?
Michael-
Kellym
PostPosted: Fri Jun 06, 2014 7:45 pm    Post subject: Vans EGT gauge not working... Reply with quote
I don't know much about Van's EGT. However, the analog EGT gauges such
as Alcor did not begin to register until temp got somewhere around
800-900 degrees. You won't get there with taxi power, but might with
some leaning get there at runup power. You don't say what engine it is
one. For carbureted engines it really isn't important. For fuel injected
engines you really need an analyzer for all cylinders.
Michael-
Kelly McMullen
KCHD
PostPosted: Fri Jun 06, 2014 7:56 pm    Post subject: Vans EGT gauge not working... Reply with quote
Carbureted engine. Taxi power only. So maybe it is working.
Michael
On Jun 6, 2014, at 8:44 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
I don't know much about Van's EGT. However, the analog EGT gauges such as Alcor did not begin to register until temp got somewhere around 800-900 degrees. You won't get there with taxi power, but might with some leaning get there at runup power. You don't say what engine it is one. For carbureted engines it really isn't important. For fuel injected engines you really need an analyzer for all cylinders.
> Michael-
racerjerry
PostPosted: Sun Jun 08, 2014 3:50 am    Post subject: Re: Vans EGT gauge not working... Reply with quote
As far as I know, power to simple analog EGT/CHT indicating systems are for internal lighting only.
First of all, it’s much easier to test the EGT system by removing the sender from the exhaust system and heating the tip with a propane torch to see if you get needle movement – need another person in the cockpit to watch gauge. Please use some precautions here so as to not burn your airplane nor anyone elses down. A fire extinguisher AND a handy 5 gal bucket of water along with common sense can work wonders.
If that didn’t work, the next thing to do is reverse the wires and recheck. Yeah, I know, color code, yadda yadda – Reverse the wires, reheat and see if needle moves
If that still don’t work, disconnect wires from the gauge and check for continuity at the wires. By measuring the wires, you are checking the sender and any extension leads and eliminating everything except the gauge.
My Westach setup says sender resistance should be about 2.5 ohms for EGT, but meter lead resistance will add to this, so correct reading will be higher. You are really looking for continuity at this point. Now if all appears to be roughly correct, you could turn your digital meter to the millivolt scale, reheat the EGT probe and watch for a tiny millivolt output within seconds of applying flame.
The gauge itself can be checked for continuity with a DIGITAL ohmmeter (the gauge is so sensitive that an analog meter can burn the darned thing out).
Let me repeat - Test gauge using ONLY a digital ohmmeter
Again, you are just looking for continuity, but Westach says somewhere between 8 & 15 ohms.
Resistance readings may differ as EGT systems may use either J or K type thermocouples (sender), but you are mainly looking for continuity. These things generally either work well or not at all.
Any resistance in the system or any corrosion will generally result in no or very low indication
Jerry King
RnJCurtis(at)charter.net
PostPosted: Sun Jun 08, 2014 7:05 am    Post subject: Vans EGT gauge not working... Reply with quote
First of all, itâ?Ts much easier to test the EGT system by removing the
see if you get needle movement â?" need another person in the cockpit to
If that didnâ?Tt work, the next thing to do is reverse the wires and
recheck. Yeah, I know, color code, yadda yadda â?" Reverse the wires,
If that still donâ?Tt work, disconnect wires from the gauge and check for
gauge.
out).
Just one other thought on this. If you added an extension
wire to the probe MAKE SURE that you used the proper wire.
If it is a "J" type, Red and White wires, be certain that you use
the red and white thermocouple extension wires. Use of other
wires can give you gross errors.
Roger
PostPosted: Sun Jun 08, 2014 8:53 am    Post subject: Vans EGT gauge not working... Reply with quote
At 06:50 AM 6/8/2014, you wrote:
--> AeroElectric-List message posted by: "racerjerry" <gki(at)suffolk.lib.ny.us>
Van's line of analog instruments are built on
a common frame of circuitry used to position
pointers over approx 250 degrees of arc on
the dial.
[img]cid:.0[/img]
An exemplar instrument (ammeter) was examined
in our shop some years back . . .
http://tinyurl.com/mpx8hze
This particular device was found to be rather sensitive to
strong fields of radio frequency energy in
the cockpit . . .
Not true . . . the non-electronic instruments designed
to read millivolt levels DIRECTLY from a heated thermocouple
have VERY low winding resistance as matter of necessity . . .
as panel instruments they are generally designed for
full scale indication with only tens of millivolts
applied to the terminals at TENS of milliamps. "Self powered"
instruments of yesteryear were often calibrated assuming
thermocouple lead wires long enough to reach to the extreme
engine locations on a large airplane. Lead wires for closer
engines could be shortened and the lost-resistance
compensated for by inserting a "thermocouple spool
resistor" in one lead.
The resistor was shipped with some too-large value (about 10 ohms
as I recall). The installing technician could remove the
cover and peel off turns of wire on the spools underneath
the cover until the desired calibration was achieved.
The input terminal to a Van's EGT will be considerably
higher resistance. Signal conditioners inside the instrument
are designed for insensitivity to total loop resistance
of the thermocouple signal . . . this is goes to the
goal of allowing thermocouples to be extended by any
practical length without concern for instrument
calibration as described above.
 Filesize:  37.08 KB
 Viewed:  6099 Time(s)
