Posted: Tue Jun 03, 2014 2:35 am Post subject: Off Delay Cabin Light |
The July 2014 issue of Kitplanes Magazine has an article by Jim Weir describing a circuit to delay turning off a light after the master switch is shut off.
http://www.kitplanes.com/issues/31_7/builder_spotlight/aero_lectrics_july_2014_21035-1.html
There is no power wire connected to Vcc pin 8 of the 555 IC. Was a wire inadvertently left off or will the circuit work as drawn?
Joe
49.17 KB |
11701 Time(s) |
_________________ Joe Gores |
ceengland7(at)gmail.com Guest
Posted: Tue Jun 03, 2014 4:24 am Post subject: Off Delay Cabin Light |
Perhaps it's been fixed; the online version has the connection.
On Tue, Jun 3, 2014 at 5:35 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
[quote]--> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=424276#424276
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sun Jun 15, 2014 8:20 am Post subject: Re: Off Delay Cabin Light |
I checked the printed paper issue and the online issue and they are both incorrect. The 555 should be wired to Positive of the keep-alive bus. Likewise the op amp should be eliminated and a 0.01 uF capacitor installed in the trigger line.
It plain to see that Jim Weir loves op amps. I prefer simpler designs and hope to publish one here soon, using no ICs and only six basic parts. It will do a "slow-fade dim-out".
ps: it is entirely possible that the Cmos 555 will operate with no power connection. Cmos circuits are known to do that since their power requirements are almost zero. But I don't think it was done on purpose.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Sun Jun 15, 2014 9:31 am Post subject: Off Delay Cabin Light |
| Quote: | ps: it is entirely possible that the Cmos 555 will operate with no
Yeah, did a delayed off circuit mucho moons ago
using schmidt-trigger cmos gate array driving
power MOSFET . . . supported the timer with
a big tantalum to keep the time active after
the 'control' signal went low.
Works good.
rnjcurtis(at)charter.net Guest
Posted: Sun Jun 15, 2014 10:05 am Post subject: Off Delay Cabin Light |
Eric,
It might be nice to consider designing this so that
it can be turned on and off normally while the
master is on and then come on for a delayed
period when the master is shut off.
Just a thought before the design gets finalized.
Roger
Eric M. Jones
Posted: Wed Jun 18, 2014 2:10 pm Post subject: Re: Off Delay Cabin Light |
| Quote: | | I prefer simpler designs and hope to publish one here soon, using no ICs and only six basic parts. It will do a "slow-fade dim-out". |
As promised, here is a basic Sexy Slow-Fadeout Cabin Light that is very rugged and very simple. I uses only six basic parts.
The main high-current switch is a LM395 Indestructible Power Transistor, but any number of other NPN power transistors would do just fine. The timer stays on for about R x C seconds, which here is 32 seconds. You can change this as you like preferably with a higher-value resistor (because it's easier).
The transistor needs some heatsinking if you want it to dim a very big bunch of LEDs. But some experimenting will determine what you need.
Two notes:
1) The previous "De-Slumpifier" also works well for this task, and you don't need any "keep-alive" bus.
2) Cree sells 200/lumen per watt white leds now, so don't be stuck with the antiques ones if you can use these.
Lamp Fade Out Timer.pdf |
80.38 KB |
627 Time(s) |
113 Brentwood Drive
(508) 764-2072
RnJCurtis(at)charter.net Guest
Posted: Wed Jun 18, 2014 3:05 pm Post subject: Off Delay Cabin Light |
Eric,
my computer says Page not found when I try to open the attachment.
Roger
Posted: Wed Jun 18, 2014 3:21 pm Post subject: Re: Off Delay Cabin Light |
Thanks Eric, the download worked for me.
Eric M. Jones
Posted: Thu Jun 19, 2014 5:26 am Post subject: Re: Off Delay Cabin Light |
Rumen asked two things that I should have mentioned.
The mysterious resistor is the LED current-limiting resistor. Since I don't know what LEDs you are using I can't specify it, but basically the resistor is:
R=((Vbus ) -- LED Voltage drop--1.2V) /amps you want the LEDs to run at.
This should work at 28V too. with a 35V capacitor.
You can use an amazing number of LEDs here in series/parallel, but when they turn off and the final appearance is difficult to predict without a bench test. So plan on that.
113 Brentwood Drive
(508) 764-2072
Posted: Thu Jun 19, 2014 6:28 am Post subject: Off Delay Cabin Light |
On 6/18/2014 6:21 PM, user9253 wrote:
Joe Gores
Heads up;
The link does not work if access is attempted from an email. It does
work if access is attempted from the forum.
I normally read Matt's lists via email, & couldn't load the link. I
clicked on the 'read the topic online' link, let that page load in my
browser, and then downloaded the drawing using the link in the browser page.
Charlie
| Quote: | The mysterious resistor is the LED current-limiting resistor. Since I
resistor is:
Eric,
another thing you might consider is connecting the
capacitor to the common on the switch and be able
to select either +12V or Ground. This would give
you the ability to use it as a delayed turn off or have
the option of instant shut off. No extra components,
just rewire the switch.
Roger
Posted: Thu Jun 19, 2014 8:14 am Post subject: Re: Off Delay Cabin Light |
A diode may be required in the main 12 Volt wire. If the light is on and then the master switch is shut off, other aircraft loads will be in parallel with R1 and short it to ground, thus no delay. If the light switch is turned on after the master switch is shut off, then there is no power available to turn on the transistor.
Here is the desired the desired functionality as I see it:
If the light switch is on and the master is on, then the light should stay on.
If the light switch is on, when the master is turned off, the light should stay on for a while and then shut off automatically.
If the master has been off and then the light switch is turned on, the light should come on for a while and then shut off automatically.
If the light switch is off, the light should be off.
Perhaps a new microprocessor-controlled product with the above features would sell.
Posted: Thu Jun 19, 2014 8:15 am Post subject: Off Delay Cabin Light |
At 06:21 PM 6/18/2014, you wrote:
The LM395 is an interesting part for linear operations
but it's not a very good switch. The full-ON saturation
voltage for this part is about 1.5 volts. An alternative
on Eric's theme would use a simple MOS-Fet . . .
http://tinyurl.com/mtnd86d
In the full-ON state, voltage drop across the FET
would be quite low . . . millivolts. When given
command of the cabin light during the delay-OFF
operation, the light would stay full-ON until the
transistor begins to loose conduction as the gate
voltage falls. Assuming conductivity over a gate voltage
decay from 4 to 2 volts, the time constants shown on
the diagram will offer delay on the order of 1 to 2
minutes. Your results may vary . . . fiddle with the
size of the 1M resistor to achieve your design goals.
Bigger resistor - longer delay.
I can't imagine any LED cabin light needing more than
a couple hundred mA of operating current. The LED dome
lights in my truck only run 120 mA and are plenty
bright. At these current levels, no heat-sinking for
the FET is necessary . . . bolting it to the box
that houses the assembly will be plenty of heatsink
for up to several amps of controlled lamp load.
The only time the transistor dissipates significant
energy is during the dimming interval. All other times
it is full-OFF or full-ON and dissipates no significant heat.
