Fred Klein
Posted: Sun Jun 01, 2014 3:31 pm Post subject: SkyYiew antenna |
I’ve been advised that a garmin instrument technician sez that it is optimal to have the gps antenna a good distance (he said 18 inches) away from other gps antennas as well as the electronics and instruments.
Anyone flying w/ SkyView SV-250-GPS module installed?…if so, I’m curious as to where you’ve installed your SV-250 module, and if performance is acceptable; if not, where are you planning to relocate it…?…
thanx,
Fred
tonyrenshaw268(at)gmail.c Guest
Posted: Sun Jun 01, 2014 4:57 pm Post subject: SkyYiew antenna |
Hi Fred,
With that Dynon Skyview GPS EFIS setup, what are you considering for a location?? Underside of instrument panel coaming, or in the roof?
Tony R.
On 2 Jun 2014, at 9:30 am, Fred Klein <fklein(at)orcasonline.com> wrote:
thanx,
Fred
Fred Klein
Posted: Sun Jun 01, 2014 6:36 pm Post subject: SkyYiew antenna |
Tony…I came within an ace of mounting it on the top of the instrument panel module, and am just now beginning to consider other options…I’m loathe to mount it on the exterior of the roof…it may fit within the space of the roof and an overhead panel I’ve placed in the cockpit ceiling between the doors…I’d prefer not to mount it back behind the “D” panel…hmmmmm…Fred
On Jun 1, 2014, at 5:56 PM, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Hi Fred,
Tony R.
> thanx,
> Fred
Posted: Sun Jun 01, 2014 7:01 pm Post subject: SkyYiew antenna |
Hi Fred,
In the roof between the doors would probably be easy, and unless the GPS antenna is thicker than I imagine, it should fit. On the top of the instrument panel, I meant mounted on the underside though. Is that an option?
TR
| Quote: | On 2 Jun 2014, at 12:36 pm, Fred Klein <fklein(at)orcasonline.com> wrote:
> Hi Fred,
> Tony R.
>> thanx,
>> Fred
rehn(at)rockisland.com Guest
Posted: Sun Jun 01, 2014 7:11 pm Post subject: SkyYiew antenna |
Fred
I have had a panel mounted Garmin GPS at the top of my radio stack with the remote gps antenna mounted just behind it over the radio stack under the top of instrument panel. Another ADS-B on top of the tray with GPS. Also a remote GPS moving map suction cup mounted to the windscreen port side. Never had a problem with any of them. Great reception from all. Run them together.
I am visiting you soon, been flying nearly every day!
Jerry
| Quote: | On Jun 1, 2014, at 7:36 PM, Fred Klein <fklein(at)orcasonline.com> wrote:
> Hi Fred,
> Tony R.
>> thanx,
>> Fred
Fred Klein
Posted: Sun Jun 01, 2014 7:44 pm Post subject: SkyYiew antenna |
Tony…the SV-250-GPS is a little puck which is 3/4” thick, plus it has a wire directly out it’s underside which is set in mastic…this will need about a quarter inch to bend around, so an inch space should do the trick…leave it to me to have made my overhead panel a bit concave so it will be tight...thanks for the idea…Fred
On Jun 1, 2014, at 8:00 PM, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Hi Fred,
TR
>> Hi Fred,
>> Tony R.
>>> thanx,
>>> Fred
Trevpond(at)aol.com Guest
Posted: Mon Jun 02, 2014 3:15 am Post subject: SkyYiew antenna |
Hi Fred,
My Skyview antenna is under the instrument panel coaming on the left hand side. Garmin Antenna for the 695 is on the right hand side. Never had any problems and always get perfect signals on both the instruments.
best regards
Trev
G-LINN
In a message dated 02/06/2014 02:15:31 GMT Daylight Time, tonyrenshaw268(at)gmail.com writes:
| Quote: | --> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com>
Hi Fred,
Tony R.
| Quote: | --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com>
thanx,
Fred
the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
fireflier
Posted: Mon Jun 02, 2014 4:59 am Post subject: SkyYiew antenna |
Hi Fred
I have got my gps module mounted into a recess on the tip of my instrument panel. I have also got my garmin 296 gps antenna mounted in a similar position.
I don't have any problems with them being mounted here or have any problems with them being located close to each other.
See photos attached showing mine incorporated into the top of my instrument panel.
Kind regards
Donald
G-PUPY ( awaiting LAA paperwork to allow test flying)
On 2 Jun 2014, at 00:30, Fred Klein <fklein(at)orcasonline.com> wrote:
thanx,
Fred
119.1 KB |
9384 Time(s) |
133.69 KB |
9384 Time(s) |
_________________ Fireflier |
Fred Klein
Posted: Mon Jun 02, 2014 5:17 am Post subject: SkyYiew antenna |
Donald…thanks for the reassurance…and the pixs…very sweet installation…would love to see a pix of your panel itself…good luck w/ your test flying…Fred
On Jun 2, 2014, at 5:58 AM, Donald Cameron <fireflier(at)btinternet.com (fireflier(at)btinternet.com)> wrote:
[quote]I have got my gps module mounted into a recess on the tip of my instrument panel. I have also got my garmin 296 gps antenna mounted in a similar position. I don't have any problems with them being mounted here or have any problems with them being located close to each other. [b]
fireflier
Posted: Mon Jun 02, 2014 5:26 am Post subject: SkyYiew antenna |
budyerly(at)msn.com Guest
Posted: Mon Jun 02, 2014 9:44 am Post subject: SkyYiew antenna |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Fred,
Have mounted Garmin, Dynon, Grand Rapids GPS antennas inside the panel. The postage stamp style (dynon/grt/aftermarket for handheld 496) work best mounted to a hat shapped aluminum mount reduxed to the top inside of the panel. I find the postage stamp type work best mounted to a small thin metal bracket or signal reception degrades... Grounding of the metal makes no difference.
Garmin IFR antennas are mounted under the top above the space between the radio stack and instruments. No metal backing necessary. I use fiberglass C sections on each side (actually just wrapped the Garmin with glass with release tape to make it replaceable and used the provided screw holes )...
Some Rules:
The antenna cannot be mounted under any metal, carbon fiber. Avoid metalic paint (metal flake) on the panel.
If using fans in the top, obviously keep them to the sides of the antenna.
Make sure you use good quality coax.
Mount the antenna solid so it doesn't vibrate.
If you install a marker beacon home made antenna in the panel, keep it clear by about 6 inches as it swallows waves of its own.
I've put the GRT antenna 8 inches from the Garmin antenna and they both work fine. The GRT hat section metal is a bit wider than the postage stamp and the vertical part of the hat blocks the Garmin from direct line of sight. They play nicely together.
Never had any problems with these simple rules.
Anytime you mount something to the top of the instrument panel it will reflect on the windscreen. You shouldn't paint the Garmins or postage stamp types. So the only help is to put a piece of black cloth over the white antenna. Some of the postage stamps are a satin black and aren't too bad but you sure do see it in the reflection of the panel top on the screen.
If fans are installed, paint the fan flat black and cover with fiberglass screens installed on the panel, painted to match the panel color or flat black.
Panel top should be painted a dark color (dark brown, flat black, dark gray) to keep light reflections on the windscreens to a minimum.
I paint my panels with SEM interior lacquer color paint, coat with their flat clear but lacquer chips so... I use Polyurethane paint over the SEM interior lacquer color paint with flatener added. Then letter the panel. Then coat with another layer of flat clear. SEM makes a clear hotrod flat paint that works well. Polyurethane holds up well to the stuff we throw in the tray, or other stuff we flop on top of the panel. The flat can be wiped clean without streaking and can be touched up nicely if gouged. No reflection problems. Stay away from enamel and lacquer flat finishes as they don't hold up to wear and tear and often look funny after wiping the dust off with cleaner.
Now that I have the wife flying with me, military gray/ flat black is out of my paint inventory. We have 12AY in nice tan (face) and browns (panel) that are soothing and comfortable and match the leather and fabrics in the cockpit giving a uniformity to the texture and feel. (I've been watching too many decorating shows lately.) You get awards for nice paint and stuff, but watch the reflections and wearability or you'll never see traffic with the sun at 12 o'clock...
Bud Yerly
Fred Klein
Posted: Mon Jun 02, 2014 7:11 pm Post subject: SkyYiew antenna |
Bud…thank you for your comprehensive reply to my questions…I keep a special file of your thorough and detailed posts…especially helpful to a novice since my bird is tending towards having a high degree of novelty.
How I value this forum,
Fred
On Jun 2, 2014, at 10:43 AM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
[quote]Have mounted Garmin, Dynon, Grand Rapids GPS antennas inside the panel.
Some Rules:
Posted: Tue Jun 03, 2014 4:20 am Post subject: SkyYiew antenna |
Fred
I think my wordy answers take too much computer space.
One of the reasons for using a metal inverted hat is to limit direct RF from the radio stack. Orient it laterally. Its worked so far.
Bud
Sent from my Verizon Wireless 4G LTE DROID
Fred
[quote] Have mounted Garmin, Dynon, Grand Rapids GPS antennas inside the panel.
Some Rules:
| Quote: | http://www.matronics.com/Navigator?Europa-List
onics.com
ww.matronics.com/contribution
Fred Klein
Posted: Tue Jun 03, 2014 6:31 am Post subject: SkyYiew antenna |
Bud…because of concerns for available space within the instrument module, I’ve opted to locate my SV-250-GPS puck in my overhead console, midway (in two axes) between the door hinges, hopefully avoiding any potential RF interference problems.
I appreciate being alerted to both the RF issue as well as the visual reflection issue had I just plunked the puck down on the top surface of the module (which I was about to do) before receiving various listers’ comments and recommendations.
F.
On Jun 3, 2014, at 5:19 AM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
| Quote: | One of the reasons for using a metal inverted hat is to limit direct RF from the radio stack. Orient it laterally. Its worked so far.
davidjoyce(at)doctors.org Guest
Posted: Tue Jun 03, 2014 8:58 am Post subject: SkyYiew antenna |
Fred, Coming late into this thread, for what it is worth,
I have two GPS aerials in the panel overhead between the
doors - one for a Garmin 496 and the other for the built
in GPS in my EFIS. I have a very thin plywood panel
filling that gap and they are fixed to the panel, which
also houses the headset sockets. The aerial wires run one
up each side of the windscreen. They have worked
faultlessly for 12 years and unlike most of my friends I
have never run out of GPS signal at any time.
I would strongly endorse the warning of not having
anything on top of the panel that will give reflections.
Regards, David Joyce, G-XSDJ
On Tue, 3 Jun 2014 08:19:15 -0400
Bud Yerly <budyerly(at)msn.com> wrote:
| Quote: | Fred
Bud
Fred
>inside the panel.
> Some Rules:
Posted: Wed Jun 04, 2014 3:34 am Post subject: SkyYiew antenna |
Excellent place. Just more wire.
I put as much as possible in the panel so as to be able to test the entire panel, less autopilot servos, on the bench. Just add power and my com dongle, and play with it. IFR instrument certs are a snap normally, however, I am amazed how resistant com shops are to doing a panel removal, and bench work. Local avionics guys love my panels, others are confused.
Drawback is the panel has 10 pounds of crap in a 5 pound bag. Bit tight on an IFR panel.
Bud
F.
[quote] One of the reasons for using a metal inverted hat is to limit direct RF from the radio stack. Orient it laterally. Its worked so far.
onics.com
