woxofswa
Posted: Tue May 13, 2014 4:56 pm Post subject: Matco parking brake valve fail |
As I was setting the parking brake today, my left foot went to the firewall with a squirt sound and there were tiny droplets of brake fluid all over my shoes.
I've got Bonaco lines so I knew they didn't fail. After wiping everything up I discovered that the leak was in the valve itself right at the bottom where the axle pin for the valve lever seats. When I pressed down hard it blew out with a force.
Anybody have a similar issue or suggestions? I called Matco at 4:30 ish but there was no answer
It is going to be a metric PITA to change out that valve.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
fdombroski
Posted: Wed May 14, 2014 5:12 am Post subject: Re: Matco parking brake valve fail |
Myron, the Matco valve has o-rings that have a history of leaking. Look up at the valve on the firewall and I suspect you will find the origin of the leak. If so, you will need to pull the valve and replace the o-rings or send it to Matco for a mod if it is the older model.
Cheers,
Frank
johngoodman
Posted: Wed May 14, 2014 6:24 am Post subject: Re: Matco parking brake valve fail |
That isn't good.... Does it only leak when it's set? The reason I ask is if the plane is still flyable to get it home.
John
_________________ #40572 Phase One complete in 2011 |
davidsoutpost(at)comcast. Guest
Posted: Wed May 14, 2014 11:03 am Post subject: Matco parking brake valve fail |
Mine leaked pretty good and it was brand new. I ended up replacing the O rings and that took care of the problem.
Sent: Wednesday, May 14, 2014 10:24:41 AM
Subject: Re: Matco parking brake valve fail
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net>
John
http://forums.matronics.com/viewtopic.php?p=423280#423280
woxofswa
Posted: Wed May 14, 2014 2:30 pm Post subject: Re: Matco parking brake valve fail |
Getting home was a trick because I could only turn right on the ground, but figured that the home ramp was big enough to do a right 270 if I needed to go left. Thankfully, it worked out.
This morning I did one of the most physically challenging things of the entire build which was worm myself under the panel around the stick and prop up on a kidney braced with a rib with both arms intertwined into the cables and rudder pedals, disregarding the sweat and brake fluid seeping into my eyes, to remove the lines from the devil spawned valve and join the cable ends together with spare male male through wall fittings I just happened to have . Luckily with both legs extended scorpion tail style out the door opening I was able to move the one that still had bloodflow as a counterbalance to my twisted spine.
Expecting a friend coming by I get a phone call so I manage to flex my man boob enough to push my phone up high enough to pluck the phone out of my shirt pocket with my teeth and drop it on the footwell floor. The caller ID says Van's, so I contort enough to tap answer with my elbow only to be asked by Van's Chevrolet in Scottsdale if it was a convenient time to discuss my future automotive needs.
Mesa, AZ
Flew May 10 2014 |
jeff(at)westcottpress.com Guest
Posted: Wed May 14, 2014 3:11 pm Post subject: Matco parking brake valve fail |
Where's the "Like" button Myron?
I've been under the panel for the last 2 months finishing things up. You've described it perfectly.
Jeff Carpenter
40304
On May 14, 2014, at 3:30 PM, woxofswa wrote:
Getting home was a trick because I could only turn right on the griund, (except high speed) but it worked out. This morning I did one of the most physically challenging things of the entire build which was worm myself under the panel around the stick and prop up on a kidney braced with a rib with both arms intertwined into the cables and rudder pedals, sweat and brake fluid seeping into my eyes, to remove the lines from the devil spawned valve and join the cable ends together with spare male male through wall fittings I just happened to have . Expecting a friend coming by I get a phone call so I manage to flex my man boob enough to push my phone up high enough to pluck the phone out of my shit pocket with my teeth and tap answer with my elbow only to be asked by my local Chevy dealer if it was a convenient time to discuss my future automotive needs.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear. FWF complete.
http://forums.matronics.com/viewtopic.php?p=423292#423292
sean(at)braunandco.com Guest
Posted: Wed May 14, 2014 4:37 pm Post subject: Matco parking brake valve fail |
Excellent!
Lenny Iszak
Posted: Thu May 15, 2014 4:25 am Post subject: Re: Matco parking brake valve fail |
Haa, love the vivid description of what I call airplane yoga...
btw Matco sells a supposedly better valve now that looks like this
http://static.veracart.com/matco/item_images/set_1/3579/lg.jpg
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
dhmoose
Posted: Thu May 15, 2014 6:14 am Post subject: Re: Matco parking brake valve fail |
| woxofswa wrote: | Getting home was a trick because I could only turn right on the ground, but figured that the home ramp was big enough to do a right 270 if I needed to go left. Thankfully, it worked out.
Expecting a friend coming by I get a phone call so I manage to flex my man boob enough to push my phone up high enough to pluck the phone out of my shirt pocket with my teeth and drop it on the footwell floor. The caller ID says Van's, so I contort enough to tap answer with my elbow only to be asked by Van's Chevrolet in Scottsdale if it was a convenient time to discuss my future automotive needs. |
I've never laughed that hard at a post before! Excellent description. I think it was even funnier since I know exactly what you're talking about since I've been there, done that When I installed the valve, I remember thinking, "This would be a serious PITA if I need to service this later". I'm now hoping I don't ever have to replace my valve! Thanks for the laugh.
_________________ David Halmos
RV-10
Flying!
Portland, OR |
bobw
Posted: Thu May 15, 2014 6:26 am Post subject: Matco parking brake valve fail |
Myron,
Thanks for the laugh. I let my personal trainer look at this and she is developing a list of exercises that might help me. If it had been me I'd had to have had a 2nd person there to "extract" me!!
Bob Wilson
_________________ Bob Wilson
bob@rjw.cc |
