curts63
Joined: 04 Dec 2013 Posts: 30 Location: New Ringgold, PA
Posted: Thu May 15, 2014 4:26 pm Post subject: Equipping experimental for IFR |
I"m new to owning a plane and trying to learn. I bought a used experimental plane. The panel includes an MGL Voyager EFIS, Backup airspeed, Backup altimeter, Garmin 430W, Garmin GTX-327, Garmin 240 audio panel, and a Navworx ADS-B.
The Voyager has the horizon, slip skid ball, compass, altimeter, airspeed, OAT, clock, timer, oil temp, oil pressure, RPM, CDI, glideslope, autopilot, and more.
My question is, what is the required equipment for IFR and what testing has to be done prior to filing and flying?
Any insight and guidance is greatly appreciated.
Thanks, Curt
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Kellym
Posted: Thu May 15, 2014 7:02 pm Post subject: Equipping experimental for IFR |
The answer is in your operating limitations. Normally you have to meet
the requirements of 91.205(d). You have to have altimeter and static
system certified to meet IFR standards. If you have an encoder, it has
to meet the correspondence standards to the altimeter.
You need two way communication radio and at least 1 navigation method.
In most circumstances you will need a Mode A/C or Mode S transponder and
it has to be certified. The only nav radio that has to be certified is
the GPS.
On 5/15/2014 5:26 PM, curts63 wrote:
Thanks, Curt
http://forums.matronics.com/viewtopic.php?p=423326#423326
KCHD |
curts63
Posted: Fri May 16, 2014 3:48 am Post subject: Re: Equipping experimental for IFR |
Ok, thanks. In the case of the pitot static and transponder, they get tested every 24 months. Is this test different for VFR versus IFR?
For the Garmin 430W, I've heard that this requires a ground test and flight test? Is this something that needs to be repeated on a standard interval?
Is it required to have a backup instruments to the EFIS ? I know it's the better practice to have those, but are they required in experimental?
Curt
bakerocb
Posted: Fri May 16, 2014 5:08 am Post subject: Equipping experimental for IFR |
5/16/2014
Hello Curt, You wrote: “.... trying to learn.”
I really appreciate it when an EAB (Experimental Amateur Built) aircraft builder or owner comes out with an attitude like that – way to go!
Some time back I created the attached document to help answer questions like yours. It has been published in Kitplanes magazine.
Please let me know if you have any further questions.
‘OC’ Baker
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
Time: 05:27:36 PM PST US
Subject: Avionics-List: Equipping experimental for IFR
Thanks, Curt
ABEA_Minimum_Inst_Requirements_10.doc |
35.5 KB |
802 Time(s) |
Kellym
Posted: Fri May 16, 2014 7:25 am Post subject: Equipping experimental for IFR |
Yes, the IFR altimeter/static test involves checking every 1000 ft up to
max altitude you want.
No on repetition of the 430. See AC 20-138A
No backups required for experimental, just Part 23. Good idea to plan
what type of backup you want.
On 5/16/2014 4:48 AM, curts63 wrote:
Curt
http://forums.matronics.com/viewtopic.php?p=423340#423340
KCHD |
bakerocb
Posted: Fri May 16, 2014 8:43 am Post subject: Equipping experimental for IFR |
5/16/2014
1) “Does it have to be field tested/certified prior to IFR flight .....?”
a) Let’s take the “certified” part first. This extract:
“Fly WAAS Approaches
GNS 430W comes with built-in WAAS navigation capabilities. It is approved to
fly LPV “glideslope” approaches without reference to ground-based navaids of
any kind. Featuring an advanced 15-channel receiver capable of five position
updates per second, GNS 430W meets the FAA's stringent TSO C146a standards
for WAAS "sole means" navigation — providing vertical and lateral approach
guidance into thousands of U.S. airports previously inaccessible in IFR
conditions.”
copied from a Garmin page shows that the 430W is fully compliant with TSO
C146a for “sole means” navigation including precision approaches. No further
certification in the field is needed.
b) Regarding field testing: There are no provisions in the federal
regulatory system for the FAA to field test the avionics installation in
your EAB aircraft. One may turn to an FAA approved MRO (Maintenance and
Repair Organization) for such field testing, but that organization is
obligated to comply with some regulatory provisions established for type
certificated aircraft which do not apply to your EAB. In the MRO's misguided
attempts to comply with type certificated aircraft criteria in regard to
your EAB you can wind up with a real (and expensive) mess on your hands.
So my recommendation is that you use an FAA approved MRO for the bench
testing and repair of your individual avionics components when required, but
do not attempt to have them field test any EAB entire avionics installation.
b) “.... does it need to be certified on an ongoing interval,...”
No regulatory recertification for the 430W is required, but there are the
issues of navigation data base and software updates:
a) Navigation Data Base Updates: This can be an ongoing chore / expense
depending upon how you approach it. The ultimate (and most expensive)
navigation data base update solution is to have a Jeppesen subscription that
provides one an appropriate geographic navigation data base update every 26
days that you must download with your computer onto the navigation data base
card for your 430W and then install in the unit. An alternative is to call
Jeppesen to order and install a one time navigation data base download when
you see the need.
b) Software Updates: If you poke around digitally inside your 430W you will
discover an amazingly large number of different software programs that
control the various aspects of that box. You can write down the identity,
including the version, of each of those software programs and carry it off
to a nearby qualified Garmin dealer / servicing facility. They can check
their Garmin files to see if there are any available updates to those
software programs. Those updates will fall into categories such as mandatory
(in Garmin’s opinion) or sort of nice to have. Use your judgment as to
whether you want to go to the effort / expense to have any software updates
done.
'OC'
Sent: Friday, May 16, 2014 9:23 AM
To: 'Owen Baker '
Subject: RE: Equipping experimental for IFR
Owen, Thank you for the equipment list, that helps with what’s needed for
flight rules. The one outstanding question is with the Garmin 430W. Does
it have to be field tested/certified prior to IFR flight and does it need to
be certified on an ongoing interval, like the transponder?
Sincerely,
Curt Stein
Sent: Friday, May 16, 2014 9:08 AM
To: curt.stein(at)verizon.net; avionics-list(at)matronics.com;
aeroelectric-list(at)matronics.com
Subject: Equipping experimental for IFR
5/16/2014
‘OC’ Baker
plane.
OAT,
more.
to
Thanks, Curt
bakerocb
Posted: Fri May 16, 2014 1:51 pm Post subject: Equipping experimental for IFR |
5/16/2014
1) "There are no mandatory tests like you would see in the VOR area where
you're required to check the accuracy?"
I am aware of no regulatory mandatory requirement to check the GPS accuracy
performance of a Garmin 430W prior to filing and flying IFR. You may wish to
check into the subject of RAIM (Receiver Autonomous Integrity Monitoring).
2) "So in conclusion, the 430w does not need any kind of test prior to using
it in IFR conditions?"**
As you imply in 1 above, if you are using the VOR capability of the 430W for
IFR navigation then you must comply with 14 CFR 91.171.
3) "You don't need a signed flight manual supplement to go along with the
POH?"
Here you are treading into the area of trying to super impose regulatory
requirements established by the FAA for type certificated aircraft onto the
far thinner regulatory arena that EAB aircraft operate in. Where is the
regulation that requires a POH for an EAB aircraft? Where is the regulation
that says who is authorized to sign the flight manual supplement for an EAB
aircraft POH?##
4) "I really appreciate you taking the time to educate me."
It is my pleasure, sir.
5) "Thanks again for your assistance."
You are welcome any time.
'OC'
**PS: I would recommend extensive practice under VFR in VMC conditions with
your aircraft's avionics installation before venturing into IFR under IMC
conditions.
##PS: I am not saying that a good POH / supplement is not needed for safe
flight in EAB aircraft, just that the FAA does not mandate those items by
regulations and it is up to the builder / pilot of the EAB aircraft to
create what is needed for safe flight for him and his aircraft.
Sent: Friday, May 16, 2014 3:26 PM
To: 'Owen Baker '
Owen,
So in conclusion, the 430w does not need any kind of test prior to using it
in IFR conditions? There are no mandatory tests like you would see in the
VOR area where you're required to check the accuracy? You don't need a
signed flight manual supplement to go along with the POH?
I do know about the monthly nav data updates from Jeppesen. I did purchase
the expensive annual update package for my intended area of flying.
Thanks again for your assistance. I really appreciate you taking the time
to educate me.
Curt
Kellym
Posted: Fri May 16, 2014 6:16 pm Post subject: Equipping experimental for IFR |
I strongly recommend following the guidance of AC 20-138A (available for
download from FAA) when installing a certified GPS in an OBAM
experimental aircraft.
Item 22 on pg 37 is Installed performance-ground tests. Ensures there
are not interference issues with other installed avionics.
Item 23 on pg 39. Installed performance - flight test. Again,
suggestions to ensure flight guidance, especially for approaches is as
expected.
Not regulatory, but highly recommended. The AC also has some guidance on
flight manual supplements.
Generally not a big deal, unless you plan on having someone other than
yourself fly the plane.
On 5/16/2014 2:50 PM, Owen Baker wrote:
5/16/2014
where you're required to check the accuracy?"
accuracy performance of a Garmin 430W prior to filing and flying IFR.
You may wish to check into the subject of RAIM (Receiver Autonomous
using it in IFR conditions?"**
430W for IFR navigation then you must comply with 14 CFR 91.171.
the POH?"
regulatory requirements established by the FAA for type certificated
aircraft onto the far thinner regulatory arena that EAB aircraft
operate in. Where is the regulation that requires a POH for an EAB
aircraft? Where is the regulation that says who is authorized to sign
the flight manual supplement for an EAB aircraft POH?##
'OC'
with your aircraft's avionics installation before venturing into IFR
under IMC conditions.
safe flight in EAB aircraft, just that the FAA does not mandate those
items by regulations and it is up to the builder / pilot of the EAB
aircraft to create what is needed for safe flight for him and his
aircraft.
To: 'Owen Baker '
Owen,
using it in IFR conditions? There are no mandatory tests like you
would see in the VOR area where you're required to check the accuracy?
POH?
purchase the expensive annual update package for my intended area of
flying.
time to educate me.
Curt
KCHD |
tim2542(at)sbcglobal.net Guest
Posted: Fri May 16, 2014 7:53 pm Post subject: Equipping experimental for IFR |
The Garmin 430W install manual has a checkout procedure as well.
FWIW, I do know the local avionics shop here has a pilot they use to shoot various approaches in VFR to verify all is well. I don't know that it's required, but it seems only prudent to do so.
Tim
| Quote: | On May 16, 2014, at 7:15 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
I strongly recommend following the guidance of AC 20-138A (available for download from FAA) when installing a certified GPS in an OBAM experimental aircraft.
Item 22 on pg 37 is Installed performance-ground tests. Ensures there are not interference issues with other installed avionics.
Item 23 on pg 39. Installed performance - flight test. Again, suggestions to ensure flight guidance, especially for approaches is as expected.
Not regulatory, but highly recommended. The AC also has some guidance on flight manual supplements.
Generally not a big deal, unless you plan on having someone other than yourself fly the plane.
> 5/16/2014
> 1) "There are no mandatory tests like you would see in the VOR area where you're required to check the accuracy?"
> I am aware of no regulatory mandatory requirement to check the GPS accuracy performance of a Garmin 430W prior to filing and flying IFR. You may wish to check into the subject of RAIM (Receiver Autonomous Integrity Monitoring).
> 2) "So in conclusion, the 430w does not need any kind of test prior to using it in IFR conditions?"**
> As you imply in 1 above, if you are using the VOR capability of the 430W for IFR navigation then you must comply with 14 CFR 91.171.
> 3) "You don't need a signed flight manual supplement to go along with the POH?"
> Here you are treading into the area of trying to super impose regulatory requirements established by the FAA for type certificated aircraft onto the far thinner regulatory arena that EAB aircraft operate in. Where is the regulation that requires a POH for an EAB aircraft? Where is the regulation that says who is authorized to sign the flight manual supplement for an EAB aircraft POH?##
> 'OC'
> **PS: I would recommend extensive practice under VFR in VMC conditions with your aircraft's avionics installation before venturing into IFR under IMC conditions.
> ##PS: I am not saying that a good POH / supplement is not needed for safe flight in EAB aircraft, just that the FAA does not mandate those items by regulations and it is up to the builder / pilot of the EAB aircraft to create what is needed for safe flight for him and his aircraft.
> From: Curt
> To: 'Owen Baker '
> Owen,
> So in conclusion, the 430w does not need any kind of test prior to using it in IFR conditions? There are no mandatory tests like you would see in the VOR area where you're required to check the accuracy? You don't need a signed flight manual supplement to go along with the POH?
> I do know about the monthly nav data updates from Jeppesen. I did purchase the expensive annual update package for my intended area of flying.
> Thanks again for your assistance. I really appreciate you taking the time to educate me.
> Curt
bakerocb
Posted: Sat May 17, 2014 5:49 am Post subject: Equipping experimental for IFR |
5/17/2014
Hello Curt Stein, You wrote:
1) “In the case of the pitot static and transponder, they get tested every
24 months. Is this test different for VFR versus IFR?”
The answer to your question is found in 14 CFR Sections 91.411 and 91.413 that require these inspections, and the related Appendices E and F of Part 43. (All available at the FAA web site.)
A) 91.411 applies to any operation under IFR in controlled airspace.
B) 91.413 is a bit more complicated. Please see that section and its referenced section 91.215 for details.
C) It is unfortunate that the term “pitot static and transponder checks” has come into common use when describing the tests required by 91.411 and 91.413. A review of those sections and the relevant appendicies of Part 43 shows that no test of the pitot system is required, but that extensive and detailed tests of the static system and transponder are required to include the altimeter viewed by the pilot, and the automatic altitude reporting system which consists of the encoder and the transponder.
I guess that we are just stuck with that unfortunate common terminology, but I strongly urge all EAB builders and pilots to become familiar with the actual requirements of the regulations, including the technicians and organizations that are permitted / required to perform the tests involved.
2) “Is it required to have a backup instruments to the EFIS ? I know it's the better
practice to have those, but are they required in experimental?”
The regulatory requirements for EAB instruments have been covered in our previous exchange postings and the attached document.
‘OC’
Time: 04:49:40 AM PST US
Subject: Re: Equipping experimental for IFR
Curt
35.5 KB |
702 Time(s) |
