Posted: Sat May 10, 2014 1:55 pm Post subject: Europa Crash in Lübeck/Germany |
Graham, Are you sure you are not thinking about a
variometer rather than an ASI? You can compare your aSI
with a GPS readout and the two closely parallel each other
(allowing for wind) i would not expect significant lag on
an ASI. But quite apart from that the SmartASS is so
effective (as no doubt are the better forms of AOA system)
because it gives you phased warnings in unignorable form
that you are departing from your chosen safe approach
speed, alerting you long before you get to the stall. You
might wonder what an approach speed has got to do with an
EFATO sort of incident, but if she (the nice lady inside
the SmartASS) is set for an approach speed of 60kts then
she wakes up automatically in any phase of flight if you
get down to within a few percent of 60kts, and gets very
aggravated long before you get anywhere near 40 kts.
Regards, David Joyce
On Sat, 10 May 2014 22:28:31 +0100 (BST)
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> wrote:
| Quote: | Tim
don't think so , the ASI won't move (or shouldn't!)
until the aircraft has accelerated, or worse slowed down
and that takes many seconds.
When it says "stall speed!" you.ve already stalled. Not
a lot of use.
Graham
Sent: Saturday, 10 May 2014, 14:31
Subject: Re: Re:
Hi Graham.
I think you may have put the decimal point in the wrong
place. I appreciate what you are suggesting but 20
seconds ?
I bet the real figure is much less than a second.
Mind you how would you measure the lag , my ASI seems to
move at the speed of light at times.
On 10 May 2014 13:19, GRAHAM SINGLETON
Or an AoA meter as primary attitude/speed instrument.
The ASI is always 20 seconds too late.
>Very sad, I met Manfred while he was building. A very
>nice man and a nice Europa.
>Graham
>________________________________
> From: David Joyce <davidjoyce(at)doctors.org.uk>
>To: europa-list(at)matronics.com
>Sent: Saturday, 10 May 2014, 12:36
>Subject: Re: Europa Crash in Lübeck/Germany
>I strongly suspect that this another case where a
>SmartASS or the equivalent might have saved them both.
>David Joyce, G-XSDJ
>arget="_blank">http://www.matronics.com/Navigator?Europa-List
tp://forums.matronics.com
_bla====
g-fizy
Posted: Sat May 10, 2014 11:40 pm Post subject: Re: Europa Crash in L�beck/Germany |
hi david ,do you have the web address in the smartass device
regards jim
pete(at)lawless.info Guest
Posted: Sun May 11, 2014 12:30 am Post subject: Europa Crash in Lübeck/Germany |
Jim
http://www.smartavionics.com/
But note from the website
"September 2013 - The SmartASS and the Airspeed Monitor have now been
discontinued (their replacement is currently being developed and, if all
goes to plan, it will be available in Q1 2014)."
Pete
