sarg314(at)comcast.net Guest
Posted: Sun Jun 25, 2006 2:31 pm Post subject: vetterman exhaust, RV-6A with 0-360 |
I'm trying to get my exhaust to fit with the cowl - clearance between
heat muff (on the right side of plane) and the lower cowl is an issue.
When I get the pipes twisted around so that they
1) give me the best clearance between heat muff & cowl and ehxhaust pipe
& engine mount
2) exit the cowl scoop pretty well parallel to the long axis of the
plane as seen from looking up laying underneath it,
the right one is angled down a lot more than the left one. Left one
(which has lots of clearance) is about 25 deg. rel. to bottom of
fuselage, right one is about 40 deg. Is this normal?
The end of the right pipe sticks down about 2.5" below the ram scoop
while the left one stick down about 1.5". My recollection is that RV's
usually have some assymmetry in this respect.
Or, have I just got it adjusted wrong?
Tom Sargent
FLYaDIVE(at)aol.com Guest
Posted: Sun Jun 25, 2006 2:46 pm Post subject: vetterman exhaust, RV-6A with 0-360 |
In a message dated 6/25/06 6:33:24 PM Eastern Daylight Time,
sarg314(at)comcast.net writes:
| Quote: | 2) exit the cowl scoop pretty well parallel to the long axis of the
Tom Sargent
Tom:
You are correct. I have the same problem ... right one is lower than the
left. I also have been fighting CO in the cabin. I tried what I believe is very
thing ... Until I came up with a solution. I added extensions with a
downward bend and a baloney cut to the exhaust. This reduced the CO to ZERO.
But, the right side is still lower than the left.
Barry
"Chop'd Liver"
Posted: Sun Jun 25, 2006 3:19 pm Post subject: vetterman exhaust, RV-6A with 0-360 |
FLYaDIVE(at)aol.com wrote:
> Tom Sargent
Tom:
Barry
"Chop'd Liver"
Barry:
Interesting. Which way was the cut? Was it horizontal or vertical?
Tom S.
Posted: Sun Jun 25, 2006 3:43 pm Post subject: vetterman exhaust, RV-6A with 0-360 |
In a message dated 6/25/06 7:21:12 PM Eastern Daylight Time,
| Quote: | Barry:
Tom S.
Tom:
HORIZONTAL and parallel to the ground in a S&L flight ... I'm an RV-6
I really had to get the exhaust down and into the air-stream. It was being
sucked in at points I could not find. I did seal off the flap area, wing root,
and added a scupper in the tail. NO great improvement. But when I added the
extensions .. WOW Z E R O CO!
Barry
"Chop'd Liver"
c.ennis(at)insightbb.com Guest
Posted: Mon Jun 26, 2006 4:58 pm Post subject: vetterman exhaust, RV-6A with 0-360 |
Tom,
I used piccalo pipes, extends the exhaust and makes the exhaust "song' a
bit more tolerable.
Charlie,
RV-6A
