ronko(at)att.net Guest
Posted: Mon May 05, 2014 7:04 am Post subject: [Pulsar-Aviators] Nose gear failure |
Having done modification last year, I still have about 7 inches left over (you only need about 3-1/2") from the Aircraft Spruce purchase of 4130 STEEL TUBE 1X.188 1FT
Part #: 03-06800-1 to make this modification (along with your own 5/8" bolt, etc.). $5 plus shipping cost, its yours. Add another $5 and I'll include 2 brand new belleville washers.
Ronko
To: pulsar-list(at)matronics.com; Pulsar-Aviators(at)yahoogroups.com
Sent: Saturday, May 3, 2014 8:42 AM
Subject: [Pulsar-Aviators] Nose gear failure
Clarke Coulter just reported his nose gear failed on take off. His landing was uneventful but the plane did sustain damage. His nose gear is the Aerodesigns gear with the spindle shaft welded inside a collar. Since the failure is occurring inside the collar, there is no way to inspect.
If you have one of these nose gears you should look on the forum to see what modifications others have done to make this area stronger and easy to inspect. It could save you from having to rebuild your aircraft.
__._,_.___
Reply to sender ([email]GREGSMI(at)aol.com?subject=Re%3A%20Nose%20gear%20failure[/email]) • Reply to group ([email]Pulsar-Aviators(at)yahoogroups.com?subject=Re%3A%20Nose%20gear%20failure[/email]) • Start a New Topic • Messages in this topic (1)
Visit Your Group
Unsubscribe ([email]Pulsar-Aviators-unsubscribe(at)yahoogroups.com?subject=Unsubscribe[/email]) • Terms of Use
[img]http://geo.yahoo.com/serv?s=97359714/grpId=13031253/grpspId=1705786083/msgId=6113/stime=1399124546[/img] [img]http://y.analytics.yahoo.com/fpc.pl?ywarid=515FB27823A7407E&a=10001310322279&js=no&resp=img[/img] __,_._,___
#yiv9035144893 #yiv9035144893 -- #yiv9035144893ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #yiv9035144893 #yiv9035144893ygrp-mkp hr { border:1px solid #d8d8d8;} #yiv9035144893 #yiv9035144893ygrp-mkp #yiv9035144893hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #yiv9035144893 #yiv9035144893ygrp-mkp #yiv9035144893ads { margin-bottom:10px;} #yiv9035144893 #yiv9035144893ygrp-mkp .yiv9035144893ad { padding:0 0;} #yiv9035144893 #yiv9035144893ygrp-mkp .yiv9035144893ad p { margin:0;} #yiv9035144893 #yiv9035144893ygrp-mkp .yiv9035144893ad a { color:#0000ff;text-decoration:none;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ygrp-lc { font-family:Arial;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ygrp-lc #yiv9035144893hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ygrp-lc .yiv9035144893ad { margin-bottom:10px;padding:0 0;} #yiv9035144893 #yiv9035144893actions { font-family:Verdana;font-size:11px;padding:10px 0;} #yiv9035144893 #yiv9035144893activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #yiv9035144893 #yiv9035144893activity span { font-weight:700;} #yiv9035144893 #yiv9035144893activity span:first-child { text-transform:uppercase;} #yiv9035144893 #yiv9035144893activity span a { color:#5085b6;text-decoration:none;} #yiv9035144893 #yiv9035144893activity span span { color:#ff7900;} #yiv9035144893 #yiv9035144893activity span .yiv9035144893underline { text-decoration:underline;} #yiv9035144893 .yiv9035144893attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #yiv9035144893 .yiv9035144893attach div a { text-decoration:none;} #yiv9035144893 .yiv9035144893attach img { border:none;padding-right:5px;} #yiv9035144893 .yiv9035144893attach label { display:block;margin-bottom:5px;} #yiv9035144893 .yiv9035144893attach label a { text-decoration:none;} #yiv9035144893 blockquote { margin:0 0 0 4px;} #yiv9035144893 .yiv9035144893bold { font-family:Arial;font-size:13px;font-weight:700;} #yiv9035144893 .yiv9035144893bold a { text-decoration:none;} #yiv9035144893 dd.yiv9035144893last p a { font-family:Verdana;font-weight:700;} #yiv9035144893 dd.yiv9035144893last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #yiv9035144893 dd.yiv9035144893last p span.yiv9035144893yshortcuts { margin-right:0;} #yiv9035144893 div.yiv9035144893attach-table div div a { text-decoration:none;} #yiv9035144893 div.yiv9035144893attach-table { width:400px;} #yiv9035144893 div.yiv9035144893file-title a, #yiv9035144893 div.yiv9035144893file-title a:active, #yiv9035144893 div.yiv9035144893file-title a:hover, #yiv9035144893 div.yiv9035144893file-title a:visited { text-decoration:none;} #yiv9035144893 div.yiv9035144893photo-title a, #yiv9035144893 div.yiv9035144893photo-title a:active, #yiv9035144893 div.yiv9035144893photo-title a:hover, #yiv9035144893 div.yiv9035144893photo-title a:visited { text-decoration:none;} #yiv9035144893 div#yiv9035144893ygrp-mlmsg #yiv9035144893ygrp-msg p a span.yiv9035144893yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #yiv9035144893 .yiv9035144893green { color:#628c2a;} #yiv9035144893 .yiv9035144893MsoNormal { margin:0 0 0 0;} #yiv9035144893 o { font-size:0;} #yiv9035144893 #yiv9035144893photos div { float:left;width:72px;} #yiv9035144893 #yiv9035144893photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #yiv9035144893 #yiv9035144893photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #yiv9035144893 #yiv9035144893reco-category { font-size:77%;} #yiv9035144893 #yiv9035144893reco-desc { font-size:77%;} #yiv9035144893 .yiv9035144893replbq { margin:4px;} #yiv9035144893 #yiv9035144893ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #yiv9035144893 #yiv9035144893ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #yiv9035144893 #yiv9035144893ygrp-mlmsg table { font-size:inherit;font:100%;} #yiv9035144893 #yiv9035144893ygrp-mlmsg select, #yiv9035144893 input, #yiv9035144893 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #yiv9035144893 #yiv9035144893ygrp-mlmsg pre, #yiv9035144893 code { font:115% monospace;} #yiv9035144893 #yiv9035144893ygrp-mlmsg * { line-height:1.22em;} #yiv9035144893 #yiv9035144893ygrp-mlmsg #yiv9035144893logo { padding-bottom:10px;} #yiv9035144893 #yiv9035144893ygrp-msg p a { font-family:Verdana;} #yiv9035144893 #yiv9035144893ygrp-msg p#yiv9035144893attach-count span { color:#1E66AE;font-weight:700;} #yiv9035144893 #yiv9035144893ygrp-reco #yiv9035144893reco-head { color:#ff7900;font-weight:700;} #yiv9035144893 #yiv9035144893ygrp-reco { margin-bottom:20px;padding:0px;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ov li a { font-size:130%;text-decoration:none;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ov li { font-size:77%;list-style-type:square;padding:6px 0;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ov ul { margin:0;padding:0 0 0 8px;} #yiv9035144893 #yiv9035144893ygrp-text { font-family:Georgia;} #yiv9035144893 #yiv9035144893ygrp-text p { margin:0 0 1em 0;} #yiv9035144893 #yiv9035144893ygrp-text tt { font-size:120%;} #yiv9035144893 #yiv9035144893ygrp-vital ul li:last-child { border-right:none !important; } #yiv9035144893
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
Eclat2
Joined: 06 Sep 2013 Posts: 13 Location: Minneapolis, Minnesota, USA
Posted: Mon May 05, 2014 12:21 pm Post subject: [Pulsar-Aviators] Nose gear failure |
I've created a folder in the Pulsar-Aviators Files section titled:
Pulsar XP - Nose Gear Modifications
http://tinyurl.com/lmf5zxh
There are three files in it:
... SkyStar's Pulsar III Nose Gear Design for Comparison
3) Pulsar XP - Nose Gear Modification - Smith-Hartunian, Koval.doc
The first is just an exploded parts diagram of the SkyStar Pulsar III
nose gear design for comparison. Something supporting a similar
weight FWF package without breaking.
I believe the second file is the modification drawing done by Bob
Hartunian and Greg Smith that Herbert inquired about.
The third is a Word.doc I threw together from clippings of posts on
Pulsar-Aviators about the Greg Smith/ Bob Hartunian modification,
and the similar but different mod done by Ron Koval. It's a rough
1st Draft. I've not designed anything, and don't claim to have any
answers, but I'm hoping Greg, Bob and Ron, and anyone else who has
done a similar modification will proof read it and offer additional
content. With enough input, perhaps we can come up with a go-to
document that owners can reference when, or hopefully before the need
arises.
I'll do the keyboard work to put together the Word.doc, if that's
what it takes. But I need some input... like, "All" the input.
If you suggest a change or addition, then flesh it out. Don't
suggest a vague idea like you think I'm going to design it. Won't
happen. I'll try to collate the document to include the good design
work and execution of others, "IF" they're okay with that; but I'm
in no position to design an aircraft landing gear. If I did, you
wouldn't want it on your plane!
In that Word.doc, I included a few questions that came to mind before
I even started writing. Let's start there, plus anything else you
think of.
1) Are all new 4130 steel parts to be used without additional heat
treating/ stress relieving? Bob?
2) The Pulsar XP nose gear design used a alternating stack of 6
Belleville Spring Washers, sandwiched between two thrust washers. I
don’t see the Belleville washers documented in the Smith/ Hartunian
design, but Ron Koval at least mentions them (ie, says he has extras
for sale). Are the Belleville washers still used in either or both
of those designs? For now, I’ve included them in the "Materials"
lists.
2) Skystar’s Pulsar III nose gear design appears to use two “top
hat” bushings in the vertical “Sleeve” (boss/ trunnion), one top and
one bottom. Do your designs do anything about friction other than a
little lubrication?
3) Any thoughts on a recommended torque value to use when assembling
the new pivot?
Tim Engel
Subj: [Pulsar-Aviators] Nose gear failure
way to inspect.
aircraft.
