rv7a.builder(at)yahoo.com Guest
Posted: Sun Apr 27, 2014 4:39 am Post subject: Amp meter jumps when transmitting |
Hello Group,
I have a Vans amp meter installed in my RV-7A. When I activate the PTT on the Garmin GNC300XL the amp meter jumps to full scale. I disconnect the antenna coax from back of the radio and hit the PTT and the amp meter needle stays still. I turn off the radio and bring my handheld into the cockpit and hit the transmit button from 2 feet away and a very slight movement in the amp meter is detected. Bringing the handheld closer to the amp meter will make the needle jump more when the PTT is activated. I think I have determined this to be a RF inference problem. My questions are 1) Will the amp meter eventually be damaged by these extreme movements? 2) Is there a fix? 3) Am I alone here or have others experience this phenomena?
Thanks. John. RV-7A Just about ready to fly
Posted: Sun Apr 27, 2014 5:42 am Post subject: Amp meter jumps when transmitting |
At 07:35 AM 4/27/2014, you wrote:
Hello Group,
I bought a Van's ammeter some years ago to
explore it's vulnerabilities to strong RF.
See pictures here:
http://tinyurl.com/mpx8hze
I discovered that no only was the instrument
devoid of any firewall for RF interference,
it was even directionally sensitive!!! See
pictures
http://tinyurl.com/m4xlj2u
http://tinyurl.com/kvo4vwk
Just waving the hand-held from side to side
would produce behaviors in the pointer error
that mimicked the motion of the antenna.
extreme movements?
No
2) Is there a fix?
Probably, but labor intensive and clumsy on
a finished instrument. It would have been FAR
better that the manufacturer demonstrated
a knowledge of DO-160 in the first place.
No doubt there are many others. Since it's
a transient event that affects the display
only while talking, it's a cosmetic behavior.
You might consider just 'living' with it.
With one caveat . . . make sure that your coax
connectors are good at both ends of the feedline . . .
it wouldn't hurt to do an SWR check. The
phenomenon you're observing MIGHT be the
result of a very RF-Hot cockpit due to loss
of shield ground on either end of the coax.
But it your antenna system is golden, then
there are no risks for just ignoring it.
I wrote to Van's about this condition . . . never
heard back from them. It no doubt affects
their entire line of instruments with
electronic signal conditioning.
Posted: Sun Apr 27, 2014 6:10 am Post subject: Amp meter jumps when transmitting |
Thanks Bob for that great analysis. John.
On Sunday, April 27, 2014 6:57 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Hello Group,
See pictures here:
pictures
extreme movements?
No
2) Is there a fix?
http://www.matronics= -->
deej(at)deej.net Guest
Posted: Sun Apr 27, 2014 6:51 am Post subject: Amp meter jumps when transmitting |
On 4/27/2014 8:35 AM, rv7a.builder wrote:
| Quote: | I disconnect the antenna coax from back of the radio and hit the PTT
Just as an aside, it is generally a bad idea to activate a transmitter
with no antenna attached. There is a good chance of damaging the
transmitter by doing this.
fyi
-Dj
Dj Merrill - N1JOV - VP EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
Posted: Sun Apr 27, 2014 7:21 am Post subject: Amp meter jumps when transmitting |
Thanks for telling me that. I won't try that again. What actually happens that could damage the transmitter? Thanks. John
On Sunday, April 27, 2014 8:10 AM, Dj Merrill <deej(at)deej.net> wrote:
--> AeroElectric-List message posted by: Dj Merrill <deej(at)deej.net (deej(at)deej.net)>
fyi
-Dj
Glastar Flyer N866RH - http://deej.net/gNavigator?AeroElectric-List" target="_blank">http://www.matronics.com/Navsp; -->
kdb.rv10(at)gmail.com Guest
Posted: Sun Apr 27, 2014 9:07 am Post subject: Amp meter jumps when transmitting |
I saw this problem years ago also. Their electronic manifold pressure gauge has same issue. I replaced the MP with a non-electric version. The rest of my instruments are from an EFIS. No problems with this configuration.
K. Belue
RV-10
On Apr 27, 2014, at 8:41 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
Hello Group,
See pictures here:
pictures
No
2) Is there a fix?
Posted: Sun Apr 27, 2014 9:55 am Post subject: Amp meter jumps when transmitting |
At 09:50 AM 4/27/2014, you wrote:
transmitter with no antenna attached. There is a good chance of
damaging the transmitter by doing this.
Back in the days of germanium output transistors
(yes Martha, there WERE germanium devices capable
of several watts at VHF) it was considered poor
form if not instant death to one's output transistors
to key a transmitter into an open circuit.
Modern output devices are much more rugged. Further,
transmitters at-risk for high SWR damage are fitted
with automatic shut-down circuits for protection.
Posted: Sun Apr 27, 2014 2:53 pm Post subject: Amp meter jumps when transmitting |
On 4/27/2014 11:21 AM, rv7a.builder wrote:
| Quote: | Thanks for telling me that. I won't try that again. What actually
Hi John,
I am sure someone else on here can explain the technical details
better than I, but the simple version is that if the transmitter does
not have circuitry built in to protect against it, it can blow some of
the parts in the final amplifier stage of the transmitter. Hopefully
someone else can chime in with more details of exactly how and why.
There is probably a good chance that a modern solid state radio has
this protection built in, but unless one knows for sure, there is no
reason to take the expensive chance that it doesn't. I'd be more
concerned with the older radios, but in general it is just good practice
to make sure that you have an antenna or a dummy load attached to the
antenna port before keying up the transmitter. My personal choice is to
make sure there is an antenna attached before even powering a radio on,
regardless of whether I am going to key the transmitter part.
-Dj
henador_titzoff(at)yahoo. Guest
Posted: Sun Apr 27, 2014 4:24 pm Post subject: Amp meter jumps when transmitting |
Dj, John,
Here's what happens when a transmitter hurls RF energy down a transmission line. First, the transmission line has a characteristic impedance. Impedance is almost like a resistance except it's comprised of a mixture of capacitor reactance, inductive reactance and resistance. Reactances have currents and voltages that are 90 degrees out of phase. This means they don't "burn" up any of the energy, whereas resistance has voltage and current in phase and does burn up energy. Check out the attached picture from Wiki, which shows how the capacitance, inductance and resistances are modeled as lumped components. Ideally, the series and parallel resistances are zero. In practice they're not but designers try to minimize them to decrease attenuation.
When this energy traveling down the transmission line reaches the end, what happens? If there's a resistor there that is equal to the transmission line's characteristic impedance, then ideally all of the energy is dissipated in that resistor as heat, since the voltage and current waves are in phase. If an antenna that is matched to the line is there, the power is magically transferred to the atmosphere, because the antenna's job is to match the impedance of the cable to free space impedance, which is 376 Ohms. It isn't really magic, at least mathematically, but one has to understand Maxwell's and Gaussian's laws to know how this happens and why free space impedance is 376 Ohms.
So let's say the end of the transmission line is open or doesn't match the impedance. In the open case, the energy has nowhere to go except to be transmitted right back to where it came from. Let's say the transmitter's transistors are generating voltage waves that are 10V peak to peak. This means that the designer has to choose components that can handle this voltage plus some, say another 10V, in order to provide longevity and reliability. When the reflected energy arrives at the transmitter output, the two waves (one going and one coming) can add up to a worst case number of 20V peak to peak if the phasing is correct. This comes very close to exceeding the design limitation of the transmitter transistors. If the designer specs the transistors to less than 20V, then the two added waves' peak voltage could very well destroy the transistors and/or other components. The designer could add transorbers or some other devices designed to limit the voltage build up at the transmitter to keep it from malfunctioning, but it's up to the designer and his design specs.
Also, the transmitter has an impedance of its own, and for maximum power transfer it should equal the line's impedance. When the reflected wave comes back, if there is a slight mismatch between the transmitter and line impedances, there will be some power dissipation at the transmitter but some of the power (wave) will reflect back to the end of the line. This means there are several waves on the line, but each reflection decreases in amplitude because of losses along the line and at the ends. All of these waves have to be added or subtracted to find the real voltages at the ends.
So the bottom line is can the transmitter handle the reflected waves such that when they add up, the end voltage doesn't damage the transmitter components, which of course have maximum voltage and power limits. I add power in there because power causes heat and components can only handle so much maximum temperature.
Hope this helps.
Henador Titzoff
| Quote: | From: Dj Merrill <deej(at)deej.net> To: aeroelectric-list(at)matronics.com Sent: Sunday, April 27, 2014 6:52 PM Subject: Re: Amp meter jumps when transmitting
--> AeroElectric-List message posted by: Dj Merrill <deej(at)deej.net (deej(at)deej.net)>On 4/27/2014 11:21 AM, rv7a.builder wrote:> Thanks for telling me that. I won't try that again. What actually > happens that could damage the transmitter? Thanks. JohnHi John, I am sure someone else on here can explain the technical details better than I, but the simple version is that if the transmitter does not have circuitry built in to protect against it, it can blow some of the parts in the final amplifier stage of the transmitter. Hopefully someone else can chime in with more details of exactly how and why. There is probably a good chance that a modern solid state radio has this protection built in, but unless one knows for sure, there is no reason to take the expensive chance that it doesn't. I'd be more concerned with the older radios, but in general it is just good practice to make sure that you have an antenna or a dummy load attached to the antenna port before keying up the transmitter. My personal choice is to make sure there is an antenna attached before even powering a radio on, regardless of whether I am going to key the transmitter part.-Dj-- Dj Merrill - N1JOV - VP EAA Chapter 87Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/Glastar Flyer N866RH - http://www.matronics.com/Navigator?AeroElectric-Listhttp://www.matronics.com/contribution</==================
33 KB |
6013 Time(s) |
Posted: Sun Apr 27, 2014 4:45 pm Post subject: Amp meter jumps when transmitting |
| Quote: | So the bottom line is can the transmitter handle the reflected waves
I'm aware of no supplier to aviation that does not
consider the rare but possible failure of a coax
connection . . . it's common practice to build
in protection, robustness or a combination of the
two.
Posted: Sun Apr 27, 2014 5:49 pm Post subject: Amp meter jumps when transmitting |
This is very true, Bob, but I would also like to add that the possibility of an open in the connectors and coax is more common than "rare." Most of these failures occur during build, which are accidental, corrosion or failure to tighten down connectors correctly.
While aviation suppliers will consider the rare but possible failure you mention below, there are several scenarios where this is not true. One scenario is the supplier receiving counterfeit parts that do not meet specs. Another scenario is a shady buyer ordering the wrong parts and a faulty lot is manufactured and shipped. Manufactured lots vary from lot to lot, and some lots may sneak through that do not meet specifications but work well until "something happens." In particular, this business of counterfeit parts has been plaguing manufacturing for at least two decades now.
Henador Titzoff
| Quote: | From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Sunday, April 27, 2014 8:44 PM
two.
Bob . . = --> http://www.matronics.com/Navigator?AeroElectric-Le great content also available via p; -Matt Dralle, Li==========
Posted: Sun Apr 27, 2014 6:51 pm Post subject: Amp meter jumps when transmitting |
| Quote: | >Manufactured lots vary from lot to lot, and some lots may sneak
"something happens." In >particular, this business of counterfeit
Forgive me my friend but we're reaching WAAaaayyyy down into
the worry bucket with this line of reasoning. Once
you open that door . . . where do the caveats end?
Cracked magneto rotors? Contaminated fuel? Bogus rivets?
The world is indeed fraught with risks. Nonetheless,
the vast majority of misadventures in every
venue have nothing to do with parts that fail
to meet published requirements. Adding such
worries to the knowledge base is potential misdirection
of valuable attention from much greater risks.
Posted: Mon Apr 28, 2014 12:26 pm Post subject: Amp meter jumps when transmitting |
You're right that I'm going down a road fraught with all sorts of relatively low risk items. Just trying to explain why an open transmission line might kill a transmitter that's otherwise designed to survive it. I hope my explanation of why the voltage could theoretically double at the transmitter helped explain to some how this phenomenon happens.
Henador Titzoff
[quote] From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Sunday, April 27, 2014 10:50 PM
of valuable attention from much greater ronics.com/Navigator?AeroElectric-List" target="_blank">http://www.matronm/" = -->
Posted: Mon Apr 28, 2014 12:34 pm Post subject: Amp meter jumps when transmitting |
On 04/28/2014 04:22 PM, Henador Titzoff wrote:
| Quote: | You're right that I'm going down a road fraught with all sorts of
phenomenon happens.
Henador Titzoff
Your explanation helped me, and matched my limited understanding of how
it works, as well as allowing me to learn more.
Thank you!
-Dj
