schmoboy
Posted: Tue Apr 08, 2014 8:42 am Post subject: VP-200 Noise on Softkey Push |
For those with the VP-200 in their bird...
I am getting a small burst of static over the intercom when I press one
of the four soft keys on the display. I do NOT get the same static when
I press the far right knob.
All audio tones generated by the VP-200 are coming across fine and I
have no other devices causing static.
Has anyone else come across this?
-Sean #40303
rv10flyer(at)live.com Guest
Posted: Tue Apr 08, 2014 8:57 am Post subject: VP-200 Noise on Softkey Push |
No static from the VP when pressing buttons. It has started to not always
move to the next mode of flight (when it should), with no changes from me
however. May be a call to Chad (at) VP is in order.
Pascal
Posted: Tue Apr 08, 2014 9:14 am Post subject: VP-200 Noise on Softkey Push |
I think I remember seeing that in the early days. They came out with a little chip that went inline with the audio circuit, if I'm not mistaken, that helped or took care of that. I'd call VP.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Apr 8, 2014, at 12:34 PM, Sean Stephens <sean(at)stephensville.com> wrote:
I am getting a small burst of static over the intercom when I press one of the four soft keys on the display. I do NOT get the same static when I press the far right knob.
All audio tones generated by the VP-200 are coming across fine and I have no other devices causing static.
-Sean #40303
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27557 Location: Livermore CA USA
schmoboy
Posted: Tue Apr 08, 2014 10:38 am Post subject: VP-200 Noise on Softkey Push |
I had a feeling that it might be intended. The "kkrrssh" sure sounds
like a static "pop", which lead me to believe I messed up the audio
wiring somehow.
I wonder if that sound is just a sound file somewhere on the system and
it could be replaced?
-Sean
| Quote: | Matt Dralle <mailto:dralle(at)matronics.com>
April 8, 2014 at 1:15 PM
My VP-200's make a "kkrrsssh" sound whenever I press any of the 5
chicklette buttons. That's by design. I told Marc it should be a
"click", but he preferred "kkrrssh". Whatevs...
Matt
Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full
Flyer Mode
dmaib@me.com
Posted: Tue Apr 08, 2014 10:50 am Post subject: VP-200 Noise on Softkey Push |
Mine has always done that.
| Quote: | On Apr 8, 2014, at 11:34 AM, Sean Stephens <sean(at)stephensville.com> wrote:
-Sean #40303
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
johngoodman
Posted: Tue Apr 15, 2014 9:32 am Post subject: Re: VP-200 Noise on Softkey Push |
Mine has always done it, as well. I just assumed it was something Marc did.
