When are diodes needed?
teblejw
PostPosted: Tue Apr 08, 2014 7:32 pm    Post subject: When are diodes needed? Reply with quote
In adapting Z-07 and/or Z-19, I'm confused about the use and purpose of diodes. As I understand them, diodes allow current to flow in one direction, with a small voltage drop, but not in the opposite direction, except for a small leakage. The voltage drop times the forward current yields a power loss that results in heat, which may need to be dissipated to keep the heat from damaging the diode or other nearby equipment. The power lost may also be an issue in a battery-only situation after loss of an alternator, for example. O.K. so far?
Pairs of diodes are used in Z-19 for the two battery feeds for the main fuel pump, for example. When both feeds are on, this would keep a "good" battery from feeding a "bad" one. Is that the primary purpose? In Z-07, only one feed to the bus with the fuel pump has a diode because judicious switching can isolate either battery. Correct? Is there something more that I'm missing? For example, if I'm not concerned about one battery "feeding" another, do I still need diodes to "smooth" the feed to a bus from two different batteries? Thanks.
Tom
PostPosted: Wed Apr 09, 2014 6:54 am    Post subject: Re: When are diodes needed? Reply with quote
It is unlikely that a battery will be bad enough that the other "good" battery would feed it. A more important reason for isolating the two fuel pump circuits in Z-19 is to prevent alternator charging current from back-feeding through small wires and fuses intended to carry only the fuel pump load.
There is more than one version of Z-07. Looking at revision 5, the diode in the "Engine B" wire prevents engine starting current and main bus load current from flowing through the "Engine B" wire from the Aux battery.
I do not know what you mean by diodes "smoothing" the feed.
Joe
Joe Gores
teblejw
PostPosted: Wed Apr 09, 2014 9:06 am    Post subject: When are diodes needed? Reply with quote
Thanks Joe,
I now understand the potential problem with feeding through small wires and fuses. Embarrassed that I missed it. "Smoothing" was not really what I should have said. I have been told that, when two supplies through diodes are connected to a component, the diodes ensure that the one with the higher voltage supplies the current. As the voltage in that one drops, the transition to the other is seamless. True? Without the diodes, I have two batteries in parallel, which yields an average voltage, assuming similar internal resistances. Not clear to me the advantage of one over the other.
Thanks again for your help.
Tom
Sent: Wednesday, April 9, 2014 8:54 AM
Subject: Re: When are diodes needed?
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=421822#421822
_-========================;
PostPosted: Wed Apr 09, 2014 10:18 am    Post subject: Re: When are diodes needed? Reply with quote
It is true that a load will draw current from whichever source has the higher voltage.
Joe
Joe Gores
jluckey(at)pacbell.net
PostPosted: Wed Apr 09, 2014 12:17 pm    Post subject: When are diodes needed? Reply with quote
Joe,
Not sure how to answer without a little more context. Can you give us a sketch of the circuit in question?
In the mean time, maybe this will help:
Crude diode symbol: ->|
Current will flow thru the diode (left to right) in the following circuit:
5 volts 4 volts
Current will NOT flow backward (right to left) thru the diode in the following circuit:
4 volts 5 volts
The diode acts as a "check-valve" and prevents current from flowing backwards
Hope this helps
-Jeff
Sent: Wednesday, April 9, 2014 11:18 AM
Subject: AeroElectric-List: Re: When are diodes needed?
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=421830#421========================http://www.matronics.com/N= --> [quote][b]
Bob McC
PostPosted: Wed Apr 09, 2014 12:38 pm    Post subject: When are diodes needed? Reply with quote
Yes.
[b]All else being equal if you connect both a 12V and a 6V source in parallel to a single load without any other intervening components then the 12V source will supply the load and the 6V source will sit idly by doing nothing.
Bob McC[/b]
Date: Wed, 9 Apr 2014 11:18:58 -0700
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=421830#421830
&gt Archive Search & Download, 7-Day Browse, Chat, FAQ,
&gt --> http://www.matronics.com/Navigator?AeroElectric-List
Bob McC
Falco #908
(just starting)
bob.verwey(at)gmail.com
PostPosted: Wed Apr 09, 2014 11:56 pm    Post subject: When are diodes needed? Reply with quote
Is there a practical application for this?
On 09/04/2014, Bob McCallum <robert.mccallum2(at)sympatico.ca> wrote:
Yes.
nothing.
Bob McC
> From: fransew(at)gmail.com
> To: aeroelectric-list(at)matronics.com
> higher voltage.
> Joe
> Joe Gores
Best...
Bob Verwey
wschertz(at)comcast.net
PostPosted: Thu Apr 10, 2014 4:13 am    Post subject: When are diodes needed? Reply with quote
I believe that the 12V source will try to charge the 6V source, overcharging the 6V battery if a diode is not present.
From: Bob McCallum (robert.mccallum2(at)sympatico.ca)
Sent: Wednesday, April 09, 2014 3:37 PM
Subject: RE: Re: When are diodes needed?
Yes.
Bob McC[/b]
Joe
Joe Gores
Bob McC
PostPosted: Thu Apr 10, 2014 5:06 am    Post subject: When are diodes needed? Reply with quote
Yes absolutely ! (assuming the sources are batteries. If they are diode isolated power supplies (alternators)  the original statement stands)
I wasn't suggesting that this was a practical thing to do. Mearly that the higher voltage source will supply the load. Normally we would be talking paralleled batteries or a battery and an alternator. In either case the higher voltage source will supply the load. All else being equal, the lower voltage source will be idle until the system voltage sags to equal the lower. (even this is an oversimplification, but hopefully gets the idea across. The higher of two paralleled differing voltages will be supplying the loads, including attempting to raise the lower voltage source. That's the basis of how a charging system works)
Bob McC
Subject: Re: AeroElectric-List: Re: When are diodes needed?
Date: Thu, 10 Apr 2014 07:12:02 -0500
Yes.
Bob McC[/b]
Joe
Joe Gores
Bob McC
Falco #908
(just starting)
