flying-nut(at)cfl.rr.com Guest
Posted: Mon Apr 07, 2014 3:15 pm Post subject: Need help with FloScan re-location from tunnel to engine |
Just returned from SnF so this may be 'old news'. I have an abundance of fittings for the stainless-braid covered teflon hose, so I cut my Vans hose to put my floscan in the middle. First sign of disaster is that the Vans hose is purple, not white, and second is that the hole in the 'cone' is too small for the purple hose. Crap. Now I have 'lost' the 90* fitting that attaches to the fuel servo. My local hydraulics shop tried to put a fitting on the purple hose and failed.
Linn
On 4/2/2014 8:29 AM, Bill Watson wrote:
[quote] Thanks Geoff. The idea of taking the existing hose and having it cut and refitted makes sense.
Bill "at 431.9 and flying" Watson
On 4/2/2014 10:27 AM, Geoff Combs wrote:
[quote] <![endif]--> <![endif]-->
Carlos
If I remember correctly I took my original line and had them cut it and add the new fittings as need and then
Cut to the new lengths.
There is a place nearby that does all types of custom hoses.
Geoff
Geoff Combs
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal, Winchester, Ohio 43110
614-834-5227
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Carlos Trigo
Sent: Tuesday, April 01, 2014 4:46 AM
Subject: RE: Need help with FloScan re-location from tunnel to engine compartment
Geoff
I don’t have the engine nearby, so I can’t confirm what I am going to ask.
You installed the “red cube” in the fuel line between the throttle body and the fuel spider, right? Is that fuel line included with the engine?
I’m asking because it seems that fuel line is not included in the FF kit from Van’s.
Do you happen to have the specifications (diameter, lenght and fittings) of those 2 fuel lines to which the red cube is attached to?
Carlos
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Geoff Combs
Sent: terça-feira, 1 de Abril de 2014 14:15
Bill
Here are some pictures that might help. 430 hrs and working great
Geoff Combs
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Bill Watson
Sent: Sunday, March 30, 2014 4:47 PM
Subject: Re: Need help with FloScan re-location from tunnel to engine compartment
Thanks, that helps.
Regarding the 90 degree fitting; the 90degree fitting shown on your old hose is the "full flow" type according to Don(at)Airflow, and that's okay. The fitting you want to avoid is the 90 degree fitting where there is no curve. That type of fitting will impede the free flow of fuel. (I'm just repeating what Don told our class a few weeks ago).
On 3/30/2014 1:57 PM, Deems Davis wrote:
Yes,
I went through the same thing after talking to Don (at) Airflow, I have the Floscan and "mounted " it (at) the front corner of the engine case http://deemsrv10.com/album/Sec%20FF4%20Fuel%20System/slides/DSC04976.html. I used a mounting bracket fabbed out of alu similar to: http://deemsrv10.com/album/Sec%20FF4%20Fuel%20System/slides/DSC04980.html. I ordered 2 new hoses to replace this: http://deemsrv10.com/album/Sec%20FF4%20Fuel%20System/slides/DSC04978.html. The hose the connects the servo and the flow scan has a right angle fitting where it connects to the floscan. There is a caution some where about avoiding that, but the configuration works flawlessly with no fluctuations.
On Sun, Mar 30, 2014 at 9:34 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote: [quote]
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Thanks!
It looks like the transducer is 'unmounted' in this case and just supported by the fuel hoses. I'm thinking of doing the same. Anyone with experience using a fuel hose supported Flowscan?
(do not archive)
On 3/29/2014 2:04 PM, Ben Westfall wrote: [quote]
--> RV10-List message posted by: "Ben Westfall" <rv10(at)sinkrate.com (rv10(at)sinkrate.com)>
Bill,
Mark Cooper's blog has some pics and a description of his mounting in the
similar location.
http://myrv10factory.wordpress.com/2012/12/10/red-cube-relocation-garmin-gtn
-750-tx-fixed-par100ex-music-limitations-and-afs-screen-tweaks/
-Ben
