Bing 54
williamtsullivan(at)att.n
PostPosted: Mon Apr 07, 2014 1:57 am    Post subject: Bing 54 Reply with quote
It's been a while since I looked in my Bing 54, so I have to ask. What is the proper installation of the sieve sleeve in the carb bowl? Bottom of the jet, or slid all the way up?
      Bill Sullivan
            Windsor Locks, Ct.
            Kolb Firestar, 447
rickofudall
PostPosted: Mon Apr 07, 2014 6:29 pm    Post subject: Bing 54 Reply with quote
William, The screen should sit in the well cast into the float bowl as a final coarse filter to keep crap out of the main jet.
Rick Girard
On Mon, Apr 7, 2014 at 4:53 AM, william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)> wrote:
        Bill Sullivan
        Windsor Locks, Ct.
        Kolb Firestar, 447
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
54x2.pdf
 Filename:  54x2.pdf
 Filesize:  405.26 KB
 Downloaded:  403 Time(s)
PostPosted: Mon Apr 07, 2014 7:16 pm    Post subject: Bing 54 Reply with quote
Thanks. I'll check tomorrow. It didn't look right.
Sent: Monday, April 7, 2014 10:29 PM
Subject: Re: Bing 54
Rick Girard
            Bill Sullivan
            Windsor Locks, Ct.
      Kolb Firestar, 447
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
PostPosted: Mon Apr 07, 2014 7:18 pm    Post subject: Bing 54 Reply with quote
Rick, I was under the impression the main jet well screen was an air dam to prevent air bubbles from entering the main jet well that could lean out the mixture.
Rick Girard
