larkrv10(at)gmail.com Guest
Posted: Mon Mar 31, 2014 12:34 pm Post subject: Bonaco brake lines |
Hey all, a question for those who have used the Bonaco lines.
I'm about to install the brake lines that run from the calipers, up the gear legs to the bottom of the fuse. Looking at the AN822-4D caliper fitting, it appears it will face forward, and the line will run up the leg on the forward side? Any other options?
Second question, what did you use to secure the brake line to the gear leg? The lines do have the anti-chafe covering. I was thinking self fusing tape?
Thx, Rick
#40956
Southampton, Ont
rene(at)felker.com Guest
Posted: Mon Mar 31, 2014 12:54 pm Post subject: Bonaco brake lines |
I used friction tape. I think it was called out in the plans. I first used plans built hard lines but changed to the Bonaco lines after I developed a leak in one of the hard lines.
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark
Sent: Monday, March 31, 2014 2:34 PM
Subject: Bonaco brake lines
Thx, Rick
#40956
Southampton, Ont
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
Posted: Mon Mar 31, 2014 3:07 pm Post subject: Bonaco brake lines |
Same for me, one of my per-plans lines failed at about 1000 hours.
I used fusion tape around the legs for anti-chafe, then zip ties to attach the flex lines.
Dave Saylor
831-750-0284 CL
On Mon, Mar 31, 2014 at 1:53 PM, Rene Felker <rene(at)felker.com (rene(at)felker.com)> wrote:
Rene' Felker
N423CF
[url=tel:801-721-6080]801-721-6080[/url]
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rick Lark
Thx, Rick
#40956
Southampton, Ont
0 12345 67
8
AirMike
Posted: Wed Apr 02, 2014 3:39 pm Post subject: Bonaco brake lines |
These are an awesome product. After messing around with the soft aluminum lines, I bit the bullet and bought the Bonaco lines. They are great for both fuel and brakes. I used flex silicone tape for securing the lines. It is impervious to fuel, grease, oil, heat, and has ok anti chafe properties.
_________________ See you OSH '18
Q/B - sold. |
Posted: Wed Apr 02, 2014 4:32 pm Post subject: Bonaco brake lines |
Hey Airmike, I'm having trouble locating self fusing tape here in S. Ontario. Can you tell me where you purchased the silicone tape?
Thx, Rick
| Quote: | On Apr 2, 2014, at 7:39 PM, "AirMike" <Mikeabel(at)Pacbell.net> wrote:
See you OSH '14
Q/B - flying 4 yrs.
http://forums.matronics.com/viewtopic.php?p=421508#421508
Posted: Wed Apr 02, 2014 4:43 pm Post subject: Bonaco brake lines |
Amazon has it. I think they call it F-4 tape.....
Rene' Felker
N423CF
801-721-6080
Posted: Wed Apr 02, 2014 5:07 pm Post subject: Bonaco brake lines |
Aha, I see it. Thanks Rene, I will order some.
Regards, Rick
[quote] On Apr 2, 2014, at 8:42 PM, "Rene Felker" <rene(at)felker.com> wrote:
Rene' Felker
N423CF
801-721-6080
rv10flyer
Posted: Sun Apr 06, 2014 8:07 pm Post subject: Re: Bonaco brake lines |
Black electrical tape secures my Bonaco flex lines nicely. I don't have oil or fuel in my gear legs.
_________________ Wayne G. |
