Firewall pass throughs - fuel lines
wdaniell.longport(at)gmai
PostPosted: Wed Mar 19, 2014 10:15 am    Post subject: Firewall pass throughs - fuel lines Reply with quote
Dear all
the instructions for electrical stuff are straightforward so no problem there.
What about the fuel lines?  How have the group passed these through the firewall?  I thought of passing them underneath the firewall perhaps... tied to the engine frame rather than actually through.
I am using automotive injection tubing and I know that fuel lines have to have heat shield forward of the firewall.
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
rparigoris
PostPosted: Wed Mar 19, 2014 12:16 pm    Post subject: Firewall pass throughs - fuel lines Reply with quote
Hi Will
Here is how I did it
http://www.europaowners.org/main.php?g2_itemId=86925
Ron Parigoris [quote][b]
PostPosted: Wed Mar 19, 2014 4:43 pm    Post subject: Firewall pass throughs - fuel lines Reply with quote
Ron thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
On Wed, Mar 19, 2014 at 3:11 PM, <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)> wrote:
Hi Will
Ron Parigoris
arget="_blank">http://www.matronics.com/Navigator?Europa-List
tp://forums.matronics.com
Fred Klein
PostPosted: Wed Mar 19, 2014 5:15 pm    Post subject: Firewall pass throughs - fuel lines Reply with quote
On Mar 19, 2014, at 11:09 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Will…I too used automobile injection hose aft…here’s how I penetrated the firewall and transitioned to SS jacketed flex hose forward…Good luck, Fred
[img]cid:774CD721-B7EA-4F84-8D08-D8038EE3BCBB[/img]
 Filesize:  38.61 KB
 Viewed:  4637 Time(s)
PostPosted: Fri Mar 21, 2014 5:35 am    Post subject: Firewall pass throughs - fuel lines Reply with quote
Fred thanks
I guess I was hoping for a straight connection without the fittings...but that looks really neat.
Will
William Daniell
LONGPORT
+57 310 295 0744
On Wed, Mar 19, 2014 at 8:10 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
Will&hellip;I too used automobile injection hose aft&hellip;here&rsquo;s how I penetrated the firewall and transitioned to SS jacketed flex hose forward&hellip;Good luck, Fred
 Filesize:  38.61 KB
 Viewed:  4614 Time(s)
Fred Klein
PostPosted: Fri Mar 21, 2014 7:05 am    Post subject: Firewall pass throughs - fuel lines Reply with quote
On Mar 21, 2014, at 6:32 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Will…bear in mind that mine is for a non-Rotax engine installation…the 90 degree fittings worked best.
Note that the fittings are aluminum Aeroquip…I’ve received a comment from one lister cautioning me against using aluminum fittings FWF on all fuel and oil lines, recommending brass (at the least) and preferably steel.
Such a practice was news to me…additional comments welcome and invited.
Fred
davidjoyce(at)doctors.org
PostPosted: Fri Mar 21, 2014 9:44 am    Post subject: Firewall pass throughs - fuel lines Reply with quote
Fred, Any sort of fitting adds weight and leakage
possibility. Going straight through the firewall with the
hoses immobilised on both sides, with the passage sealed
by silicone adds nil weight ,no leakage possibility and
works in the sense that having already replaced hoses
twice on a five year life basis, the pipes showed no sign
of chafing wear. Why complicate things?
Regards, David.
On Fri, 21 Mar 2014 08:01:29 -0700
Fred
Fred Klein
PostPosted: Fri Mar 21, 2014 3:00 pm    Post subject: Firewall pass throughs - fuel lines Reply with quote
On Mar 21, 2014, at 10:43 AM, David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
Any sort of fitting adds weight and leakage possibility. Going straight through the firewall with the hoses immobilised on both sides, with the passage sealed by silicone adds nil weight ,no leakage possibility and works in the sense that having already replaced hoses twice on a five year life basis, the pipes showed no sign of chafing wear. Why complicate things?
David,
Thanks for the description of your installation as well as your report of trouble-free operation over a ten year period…yours is simplicity itself, and I salute you for it while I also admit to envy of your accumulating all the hours of airtime which you have while my kit remains in my workshop.
I suspect that one person’s “complication” may be another’s sense of “proper kit”, both being subjective assessments for dealing w/ the task at hand, whatever it may be…and...a reflection of one’s “comfort zone”.
In my case, I recall a sense of discomfort at the thought of simply running a rubber hose w/ fuel under high pressure through the firewall…I was also keen on matching the FWF SS jacketed fuel line which my engine supplier had already used connecting the injector rails…the firewall seemed like the logical place for the transition, and the weight of the aluminum fittings was not a detriment for me.
As my fuel lines are under high pressure for a fuel-injected engine with the pumps located aft, I paid little attention to the build manual references to routing of the low pressure fuel lines for the Rotax engine, relying instead on an old dog-eared copy of an EAA publication, “Firewall Forward” by Tony Bingelis.
What I’ve done made perfect sense to me at the time the work was being done…
Fred
PostPosted: Fri Mar 21, 2014 3:26 pm    Post subject: Firewall pass throughs - fuel lines Reply with quote
Fred, One thing I should have mentioned is that I have the
Singleton firewall mod, which replaces the stainless steel
with a thickish heat resistant fibreglass. That is of
course a whole lot less likely to traumatise a rubber hose
than stainless steel, but if I had the stainless steel
original firewall I would still be tempted to try to make
holes with a turned smooth edge or to get a large grommet
so as to still avoid extra connectors. But that is all
largely irrelevant, I guess with your fuel injected, high
pressure system!
Regards, David Joyce, G-XSDJ
On Fri, 21 Mar 2014 13:59:28 -0700
David,
in my workshop.
Fred
