M-14P can not reach max rpm
LinJun
PostPosted: Fri Mar 14, 2014 2:41 am    Post subject: M-14P can not reach max rpm Reply with quote
My M-14P can not reach 2950rpm for 2 month, sometime the high rotate speed was around 2840rpm, sometime around 2600rpm. Are there anybody ever had this problem? Or know how to fix this problem? Thank you.
BTW, the governor o-ring has problem, sometime oil leaked from control axes.
dsavarese0812(at)bellsout
PostPosted: Fri Mar 14, 2014 3:46 am    Post subject: M-14P can not reach max rpm Reply with quote
Assuming the blade angles have not been changed and no one has tried to adjust the position of the arm (other than maybe the high pitch stop) it sounds like your prop governor may be the problem.
If you replace the prop governor, the proper adjustment procedure is in the M14P maintenance manual. I've attached it for your convenience.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 3/14/2014 5:41 AM, LinJun wrote:
--> Yak-List message posted by: "LinJun" <jxlinjun(at)163.com> (jxlinjun(at)163.com)
http://forums.matronics.com/viewtopic.php?p=420330#420330
M14_Prop_Governor_Adjustment_Procedure.pdf
 Filename:  M14_Prop_Governor_Adjustment_Procedure.pdf
 Filesize:  342.62 KB
 Downloaded:  471 Time(s)
LinJun
PostPosted: Sat Mar 15, 2014 4:25 am    Post subject: Re: M-14P can not reach max rpm Reply with quote
Thank you Dennis,
I did not changed propeller angles, and have removed the limit stop, but the problem was still there. I also wonder if the governor got problem,but I have no backup governor.
Jun
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
--> Yak-List message posted by: "LinJun" <jxlinjun> (jxlinjun(at)163.com)
PostPosted: Sat Mar 15, 2014 5:28 am    Post subject: M-14P can not reach max rpm Reply with quote
Yes, that is certainly possible since you said the governor on your engine was exhibiting a leak around the shaft. I'm sure you can purchase a governor from one of the parts suppliers. Maybe someone on the list has a used/serviceable governor they would like to sell?
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
Thank you Dennis,
Jun
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com (http://www.yak-52.com)
Skype - Yakguy1
--> Yak-List message posted by: "LinJun" (jxlinjun(at)163.com (jxlinjun(at)163.com))
http://forums.matronics.com/viewtopic.php?p=420330#420330 (http://forums.matronics.com/viewtopic.php?p=420330#420330)
http://forums.matronics.com/viewtopic.php?p=420369#420369
