clr(at)redingaviation.com Guest
Posted: Thu Mar 13, 2014 1:47 pm Post subject: spliting 2 wires at a dsub connector |
In the sprit of the comic books that Bob has put together which have proven so valuable
I need to split a shielded wire into 2 pins on on a DSUB. I am sure that what I did would be an acceptable approach but is there a better way?
this is a 2 conductor shielded wire. I have already added a pigtail using a solder sleeve
thanks for the help
I striped off a 1/4 inch strip of insulation about 1 1/2 inches back from the pin
I [img]cid:37A4A777-BAA1-4976-82BC-EDD67F3CDB41(at)home[/img]
following Bob’s comic book on splicing wires i teased out a couple of strands of the wire to be joined
[img]cid:EBF15593-B0E3-40D1-BD4A-3EC3183C63DD(at)home[/img]
Wrapped and soldered
[img]cid:F98E29ED-F00A-4BC3-A4DA-E9CB10CC7324(at)home[/img]
added shrink wrap and crimped on the pin
[img]cid:4F612A8E-59EB-4674-BBF3-753D96D26E1C(at)home[/img]
44.36 KB |
6145 Time(s) |
37.67 KB |
6145 Time(s) |
42.12 KB |
6145 Time(s) |
43.44 KB |
6145 Time(s) |
Posted: Sat Mar 15, 2014 4:47 am Post subject: spliting 2 wires at a dsub connector |
Jay
On Mar 15, 2014, at 4:47 AM, "Jay Hyde" <jay(at)horriblehyde.com (jay(at)horriblehyde.com)> wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
That’s a perfectly acceptable way to do it; I have used that method many times without any problems.
Jay
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Craig Reding
Sent: 13 March 2014 11:46 PM
Subject: spliting 2 wires at a dsub connector
thanks for the help
I <image001.jpg>
<image002.jpg>
<image003.jpg>
<image004.jpg>
| [quote][b]
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sat Mar 15, 2014 10:27 am Post subject: Re: spliting 2 wires at a dsub connector |
For frequencies above about a MHz, this shouldn't be done, since the insulation itself carries the signal. See attached.
By the way. I ran across a paper that recommended wire-nuts for connecting multiple wires. Is there some reason not to do this?
Dabbling with Electricity.pdf |
248.25 KB |
473 Time(s) |
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
mrspudandcompany(at)veriz Guest
Posted: Sat Mar 15, 2014 12:53 pm Post subject: spliting 2 wires at a dsub connector |
The main reason that I could see is the
added bulk of the wire nuts might make
it difficult to impossible to add a cover
to the connector.
Roger
Posted: Sat Mar 15, 2014 7:03 pm Post subject: spliting 2 wires at a dsub connector |
At 01:27 PM 3/15/2014, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net>
For frequencies above about a MHz, this shouldn't be done, since the insulation itself carries the signal. See attached. |
I'd like to see the physics of this explained.
Yes, there is a skin-effect that pushes the current
flow to the surface of the conductor
http://tinyurl.com/n2h9ljy
. . . but carried on the insulation?
| Quote: | | By the way. I ran across a paper that recommended wire-nuts for connecting multiple wires. Is there some reason not to do this? |
Wire nuts? Like this?
[img]https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcQXzKyBUMrYyTLEqk2edXnJN1carV57AtODBP94Gcm4gGEicPc1[/img]
Not recommended for aircraft
Bob . . . [quote][b]
Posted: Sat Mar 15, 2014 7:04 pm Post subject: spliting 2 wires at a dsub connector |
thanks for the help
<snip>
Works good, lasts a long time . . .
Posted: Sat Mar 15, 2014 8:40 pm Post subject: spliting 2 wires at a dsub connector |
Bob, Thank you very much for all of your lessons!
On Mar 15, 2014, at 10:59 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
> thanks for the help
<snip>
