Door latch
pmdental(at)btinternet.co
PostPosted: Sat Mar 08, 2014 12:55 pm    Post subject: Door latch Reply with quote
Hi guys & gals, Thanx for your help regarding door fitting - coming along
nicely. Got a problem with the door latch. as you can see in the attatched
photo. With the inner handle in the fully closed position, the outer handle
is cocked up at 40 degees to the horizontal ??? I'm assuming it should be
horizontal - streamlined into the airflow. I followed the instructions to
the letter & as you can only ever change the positions of the handles by 90
degrees, whats gone wrong ??? Any ideas please Paul Munford trigear kit 625.
Thankyou
 Filesize:  33.58 KB
 Viewed:  2844 Time(s)
PostPosted: Sat Mar 08, 2014 1:08 pm    Post subject: Door latch Reply with quote
Hi all. Thanx for you help with door fitting - coming along nicely. As you
can see I've got a problem with the doorlatch ? Despite following the
instructions to the letter, when the inner handle is in the fully closed
position the outer handle is cocked up at 40 degrees ??? I'm assuming it
should be horizontal into the airflow ?? BUT you can only alter the handle
positions by 90 degees. Any ideas / Thankyou Paul Munford, Kit 625 trigear
 Filesize:  33.58 KB
Richard Wheelwright
PostPosted: Sat Mar 08, 2014 1:10 pm    Post subject: Door latch Reply with quote
You may have fixed the anchor nut on the wrong side of the Handel ???
[quote] On 8 Mar 2014, at 20:54, "Paul & Vanessa Munford" <pmdental(at)btinternet.com> wrote:
Hi guys & gals, Thanx for your help regarding door fitting - coming along nicely. Got a problem with the door latch. as you can see in the attatched photo. With the inner handle in the fully closed position, the outer handle is cocked up at 40 degees to the horizontal ??? I'm assuming it should be horizontal - streamlined into the airflow. I followed the instructions to the letter & as you can only ever change the positions of the handles by 90 degrees, whats gone wrong ??? Any ideas please Paul Munford trigear kit 625. Thankyou
Richard Wheelwright
G-IRPW
First Flight 24th July 2013
craigb(at)onthenet.com.au
PostPosted: Sat Mar 08, 2014 1:41 pm    Post subject: Door latch Reply with quote
Try swapping the handles
grahamsingleton(at)btinte
PostPosted: Sat Mar 08, 2014 3:06 pm    Post subject: Door latch Reply with quote
try turning the handle over, (inside face to outside) You nned to take the anchor nut off, so have a look and think about it
first!
Graham
From: Paul & Vanessa Munford <pmdental(at)btinternet.com>
Sent: Saturday, 8 March 2014, 20:54
Subject: Fw: Door latch
PostPosted: Sun Mar 09, 2014 7:28 am    Post subject: Door latch Reply with quote
As ever, you guys are great !!! You were right, - by swapping handles, everything fell into place (wish I had a brain ???!!!). Thanx again. Paul Munford. Trigear kit 625
