gerf(at)gerf.com Guest
Posted: Thu Jun 22, 2006 9:02 pm Post subject: Labelling the panel - what's 'legal' |
My switches are bunched together quite tightly, to get the
labels into place I want to abbreviate some of the labels - is
this 'legal' ?
Here are some examples:
ALT/BATT
L.MAG
R.IGN
FUEL PMP
POSN/STRB
LNDG LGHT
__g__
Gerry Filby gerf(at)gerf.com
Tel: 415 203 9177
dan(at)rvproject.com Guest
Gary.A.Sobek
Posted: Fri Jun 23, 2006 4:22 am Post subject: Labelling the panel - what's 'legal' |
Gerry:
Your aircraft is insected IAW FAA Order 8130.2F (Change 1 is latest as of
June 23, 2006).
http://tinyurl.com/zrmzs
FAA Order 8130.2F PAR 147(c) require cockpit instruments marked properly,
needed placards installed and placed for easy reference. All system controls
properly marked, CB's clearly marked, and function as intended. (from page
154-155)
Do not forget that you can use TWO (2) rows of names over the switches.
ie:
Left Fuel LND
Mag Pump Light
I know of no regulation that says you cannot use an abbeiviation. Your
operating limitations will require that you inspect the markings at each
condition inspection.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
1,869 + Flying Hours So. CA, USA
http://www.rvdar.com
khorton01(at)rogers.com Guest
Posted: Fri Jun 23, 2006 4:01 pm Post subject: Labelling the panel - what's 'legal' |
On 23 Jun 2006, at 08:20, RV6 Flyer wrote:
Gerry:
as of June 23, 2006).
properly, needed placards installed and placed for easy reference.
All system controls properly marked, CB's clearly marked, and
function as intended. (from page 154-155)
switches.
ie:
Left Fuel LND
Mag Pump Light
Your operating limitations will require that you inspect the
markings at each condition inspection.
Many Transport Category aircraft use abbreviations on switch labels.
I would make sure that the abbreviations were well documented in your
POH.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
