tonyrenshaw268(at)gmail.c Guest
Posted: Sat Mar 08, 2014 5:48 am Post subject: Instrument panel Fairing |
Gidday,
I'm experimenting with an idea to incorporate a Flood panel light system, using dimmable LEDs. I don't want to see them, so I need to hide them in the instrument panel coaming, and to do that I need to thicken it. I'm interested if anyone else has done that, and I wouldn't mind making mine capable of accommodating an energy absorbing material, like a rubber hemispherical section. Below is the start of this little experiment with a foam buildup that I will sand back against the original panel, but thicken the coaming, and hopefully embed my LEDs within, so I can't see them. I also thought of incorporating either an annunciator bulge in the middle, or a Caution/warning light in the same spot. I'd like to request input especially from not too tall pilots (I'm 5'9"_175cm) as to the max thickness I could make the coaming without obscuring the top instruments.
Thanks.
Tony Renshaw
Johannesburg, then home..Sydney.
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
93.98 KB |
1286 Time(s) |
Fred Klein
Posted: Sat Mar 08, 2014 9:01 am Post subject: Instrument panel Fairing |
On Mar 8, 2014, at 5:47 AM, Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)> wrote:
| Quote: | | I'm experimenting with an idea to incorporate a Flood panel light system, using dimmable LEDs. I don't want to see them, so I need to hide them in the instrument panel coaming, and to do that I need to thicken it. I'm interested if anyone else has done that, and I wouldn't mind making mine capable of accommodating an energy absorbing material, like a rubber hemispherical section. |
Tony…see pixs below…I made the lip w/ 2 thicknesses of 3/8” dense but flexible white foam…not energy-absorbing…after rounding off, foam covered w/ 1 layer BID...I also extended the sunshade over the com panel and found that a 36” strip of LEDs was perfect and is bonded w/ silicone to the “back face” of the lip or valence which hides the lights from the pilot & passenger’s eyes.
For “energy-absorbing”, you might try some of that slotted round closed cell neoprene foam pipe insulation…just a thought…
Good luck,
Fred
[img]cid:2755CBAA-A102-4D2E-914E-684C57582ED3[/img]
[img]cid:6E02F205-06FE-4A68-9830-FF50D00E216D[/img]
[img]cid:655EBE18-FACB-4402-A017-862646A77C80[/img]
[img]cid:64CBE411-8AAF-4951-B799-5564A7B4F9A2[/img]
43.4 KB |
1282 Time(s) |
48.88 KB |
1282 Time(s) |
95.62 KB |
1282 Time(s) |
58.41 KB |
1282 Time(s) |
