Oil Thermostat
Richard Wheelwright
PostPosted: Sun Feb 16, 2014 11:27 am    Post subject: Oil Thermostat Reply with quote
Oil Thermostat
I'm considering fitting the Oil thermostat supplyed by Conair in the UK (Approved LAA Mod) My Question is. After removing my cowl and considering the best location to mount the thermostat, Does anyone have any pictures of a suggested location. As the thermostat is quite large with the hose connections fitted to it.
Thank you in advance
Richard Wheelwright
G-IRPW
fireflier
PostPosted: Sun Feb 16, 2014 11:58 am    Post subject: Oil Thermostat Reply with quote
Hi Richard
I have recently fitted the oil thermostat as part if my build. I have mounted mine on the starboard footwell as per the photo. Im not sure if this picture is off the thermostat in its final position as I had to move it up from its first location, so that it didn't kink the oil hose going to the oil cooler.
I will be going to the aircraft shortly to do some other bits, so can take more photos for you if you want?
Kind regards
Donald
On 16 Feb 2014, at 19:27, "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk> wrote:
Oil Thermostat
Richard Wheelwright
G-IRPW
http://forums.matronics.com/viewtopic.php?p=418802#418802
 Filesize:  100.83 KB
 Viewed:  9633 Time(s)
Fireflier
aircraftspecialty(at)gmai
PostPosted: Sun Feb 16, 2014 12:11 pm    Post subject: Oil Thermostat Reply with quote
We are just about to release a thermostasis install kit for the Rotax 912 engine. We include the thermostasis unit, an fittings for it and the 4 required hoses.
The cost is going to be $680usd for the complete package
If anyone would like more information, please email me at steve(at)aircraftspecialty.com
Have a nice weekend
Steve
On Feb 16, 2014, at 13:27, "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk> wrote:
Oil Thermostat
Richard Wheelwright
G-IRPW
Richard Wheelwright
PostPosted: Sun Feb 16, 2014 12:44 pm    Post subject: Re: Oil Thermostat Reply with quote
Donald,
That looks like a good position. I can see that you may have had to re-fit the Stat higher as joining to the cooler would ba a problem. I would be interested in some more pictures of your final installationn to the cooler without kinking the pipes and allowing slow bends.
Richard Wheelwright
Richard Wheelwright
G-IRPW
First Flight 24th July 2013
fireflier
PostPosted: Sun Feb 16, 2014 1:02 pm    Post subject: Oil Thermostat Reply with quote
Hi Richard
It seemed the best location to me at the time off installation.
I had also considered putting it on the side of the starboard footwell, however as I have incorporated the cabin heater mod my cabin air inlet is on the side so space is limited.
I'm at the aircraft at the moment so will drop the from lower cowl before i finish tonight and take a few more photos for you.
Kind regards
Donald
On 16 Feb 2014, at 20:44, "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk> wrote:
Donald,
Richard Wheelwright
Richard Wheelwright
G-IRPW
http://forums.matronics.com/viewtopic.php?p=418812#418812
Fireflier
Richard Wheelwright
PostPosted: Sun Feb 16, 2014 1:24 pm    Post subject: Oil Thermostat Reply with quote
Donald,
Thank you.
Richard Wheelwright
On Sunday, 16 February 2014, 21:11, Donald Cameron <fireflier(at)btinternet.com> wrote:
--> Europa-List message posted by: Donald Cameron <fireflier(at)btinternet.com (fireflier(at)btinternet.com)>
Hi Richard
Kind regards
Donald
On 16 Feb 2014, at 20:44, "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)> wrote:
[quote] --> Europa-List message posted by: "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)>
Donald,
Richard Wheelwright
Richard Wheelwright
G-IRPW
matronics.com/Navigator?Europa-List" target="_blank">http://www.matronics= -->
Richard Wheelwright
G-IRPW
fireflier
PostPosted: Sun Feb 16, 2014 1:47 pm    Post subject: Oil Thermostat Reply with quote
Fireflier
fireflier
PostPosted: Sun Feb 16, 2014 1:53 pm    Post subject: Oil Thermostat Reply with quote
Hi Richard
Photos emailed to you email account as it appears my reply is too big an attachment to show on the forum.
Kind regards
Donald
On 16 Feb 2014, at 21:23, Richard Wheelwright <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)> wrote:
[quote]Donald,
Thank you.
Richard Wheelwright
On Sunday, 16 February 2014, 21:11, Donald Cameron <fireflier(at)btinternet.com (fireflier(at)btinternet.com)> wrote:
Hi Richard
Kind regards
Donald
Donald,
Richard Wheelwright
Richard Wheelwright
G-IRPW
courier new,courier">http://www.matronics.com/Navigator?Europa-List
cs.com
matronics.com/contribution
Fireflier
Richard Wheelwright
PostPosted: Sun Feb 16, 2014 2:09 pm    Post subject: Oil Thermostat Reply with quote
Donald,
The Photos are great, and just what I wanted, This helps a lot, Is it possible for you to take a picture down the back of the engine to where the pipes go to the Cooler?
Richard Wheelwright
On Sunday, 16 February 2014, 22:02, Donald Cameron <fireflier(at)btinternet.com> wrote:
Hi Richard
Kind regards
DonaldSent from my iPhone
[quote]Donald,
Thank you.
Richard Wheelwright====================
--> Europa-List message posted by: Donald Cameron <fireflier(at)btinternet.com (fireflier(at)btinternet.com)>Hi Richard It seemed the best location to me at the time off installation. I had also considered putting it on the side of the starboard footwell, however as I have incorporated the cabin heater mod my cabin air inlet is on the side so space is limited. I'm at the aircraft at the moment so will drop the from lower cowl before i finish tonight and take a few more photos for you. Kind regardsDonaldSent from my iPhoneOn 16 Feb 2014, at 20:44, "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)> wrote:> --> Europa-List message posted by: "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)>> > Donald,> That looks like a good position. I can see that you may have had to re-fit the Stat higher as joining to the cooler would ba a problem. I would be interested in some more pictures of your final installationn to the cooler without kinking the pipes and allowing slow bends.> > Regards> Richard Wheelwright> > --------> Richard Wheelwright> G-IRPW> First Flight 24th July 2013> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.php?p=418812#418812> > > > > matronics.com/Navigator?Europa-List" target="_blank">http://www.matronics= --> [/url]
[url=http://www.matronics.com/contribution]
cs.com
http://www.matronics.com/Nave="rect" target="_blank" href="http://forums.matronics.com/">http://ff="http://www.matronics.com/contribution">http://www.matronics.com/contri===============
Richard Wheelwright
G-IRPW
fireflier
PostPosted: Sun Feb 16, 2014 2:55 pm    Post subject: Oil Thermostat Reply with quote
Hi Richard
Yes not a problem i will take some photos of the pipes going to the cooler tomorrow. Im sorry never got your reply until I got back home from the plane.
Kind regards
Donald
On 16 Feb 2014, at 22:09, Richard Wheelwright <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)> wrote:
[quote]Donald,
Richard Wheelwright
On Sunday, 16 February 2014, 22:02, Donald Cameron <fireflier(at)btinternet.com (fireflier(at)btinternet.com)> wrote:
Hi Richard
Kind regards
Donald,
Thank you.
cs.com
cs.com
Fireflier
mau11(at)orange.fr
PostPosted: Sun Feb 16, 2014 9:56 pm    Post subject: Oil Thermostat Reply with quote
Hello, do you have pictures of it?
Many Thanks
Michel AUVRAY
Have a nice weekend
Steve
> Oil Thermostat
> Richard Wheelwright
> G-IRPW
PostPosted: Sun Feb 16, 2014 10:30 pm    Post subject: Oil Thermostat Reply with quote
Here are a few pictures of the top of the engine with the mounting location. We will provide thy thermostasis units as well as the 4 required hoses and the 4 AN fittings for the thermostasis unit.
All fittings on the hoses are stainless steel. In addition all hoses are conductive Teflon and are pressure tested and fire sleeved.
We are finalizing details of the install kit now.
Have a great week
Steve
Many Thanks
Michel AUVRAY
> Have a nice weekend
> Steve
> Sent from my iPhone
>> Oil Thermostat
>> Richard Wheelwright
>> G-IRPW
 Filesize:  136 KB
 Viewed:  9604 Time(s)
 Filesize:  136 KB
