lee.logan(at)gulfstream.c Guest
Posted: Thu Jun 22, 2006 12:24 pm Post subject: Comant VOR/GS antennas |
Is it possible to mount blade antennas under the fiberglass wingtips on an
otherwise all aluminum aircraft and get good electronic performance? They
would be separated by the wingspan of the aircraft which would be a wider
distance than is typical on a vertical fin installation, for example, but
otherwise could/would be horizontal and in the same plane. Could be
mounted on a plate against the outboard rib and oriented fore and aft, aft
of the nav/strobe/landing light complex.
Gotta be something here I don't know about?!!
Lee...
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Thu Jun 22, 2006 2:51 pm Post subject: Comant VOR/GS antennas |
| Quote: | Is it possible to mount blade antennas under the fiberglass wingtips on an
If I understand your question correctly then yes, I believe that Bob Archer
used to offer a Nav antenna for this exact configuration.
Paul
