Mike Whisky
Posted: Tue Feb 11, 2014 1:51 pm Post subject: Fuel consumption test results |
Hi I just copied my request from VAF here as well to seek your feedback:
I did fuel consumption test runs with 55%, 65% and 75% at 3000 ft and 6000ft as well as 9500 ft (55% & 65%). What did you guys measure or is there a chart to see fuel consumption over altitude for different power settings?
This is how I did it.
1) Set power e.g. 2300 RPM, 20.7 MAP which gives me 55% HP
2) Autopilot alt hold e.g.. 3000ft
2) I lean slowly about .2 gal/2min until the last EGT peaked and runs about 15F LOP stayed with this setting to record speeds and fuel flow. (My injection nozzle restrictors still have a gami spread of about 0.9 gal).
My results are (TAS in kt):
55% pwr
3000 ft 9.11 gal/h 134 TAS
6000 ft 9 gal/h 140 TAS
9000 ft 9.25 gal/h ? 154 TAS
65% pwr
3000 ft 10.7 gal/h 144 TAS
6000 ft 10.57 gal/h 157 TAS
9500 ft 10.4 gal/h 160 TAS
75% pwr
3000 ft 12.4 gal/h 162 TAS
6000 ft 12.28 gal/h 167 TAS
thanks
Michael
_________________ RV-10 builder (flying)
#511 |
Posted: Tue Feb 11, 2014 4:25 pm Post subject: Fuel consumption test results |
I do have a power chart, but those numbers look pretty normal to me. It would be good to note your map, rpm and density altitude with those numbers if possible. You should be able to get the peak spread down to 0.2gph.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | On Feb 11, 2014, at 4:51 PM, "Mike Whisky" <rv-10(at)wellenzohn.net> wrote:
My results are:
55% pwr
65% pwr
75% pwr
thanks
Michael
RV-10 builder (flying, test phase)
#511
http://forums.matronics.com/viewtopic.php?p=418550#418550
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Feb 11, 2014 5:21 pm Post subject: Re: Fuel consumption test results |
Michael, those numbers look like just what I would expect to see. There are charts in the Lycoming manual. I believe you can find it online.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
rv10flyer(at)live.com Guest
Posted: Tue Feb 11, 2014 5:36 pm Post subject: Fuel consumption test results |
I have mine from .4 to .1 depending on the altitude and power setting. If
you work on the LOP ops Airflow suggests doing it above 12GPH (2400 and
24MAP) the plane moved into yellow territory when I do this but for the
short time I did it I was able to get a decent idea of a real spread. I than
did it at 55-60% and checked to see if the same EGT order followed. With
that call Don and airflow and give him your results, he should be able to
get you started. Additionally Tim's webpage has a great writeup on how he
went from .9 down to 0.
Posted: Tue Feb 11, 2014 5:59 pm Post subject: Fuel consumption test results |
Here is a data run after I did my last nozzle adjustment. The table lists
fuel flow when each cylinder peaked. The numbers in () are the nozzle size
for each cylinder. Air Flow Performance provides nozzles in .0005"
increments. The nozzles fit Bendix, Precision and AFP injectors. Data
taken solo, full fuel.
Altitude RPM MP #1 (.028) #2 (.029) #3 (.027)
#4 (.027) #5 (.029) #6 (.0275) Spread TAS
6500 2350 23.3 12.8 12.9 12.9
12.9 12.8 12.9 0.1 180
5500 2340 23.3 12.3 12.3 12.4
12.4 12.2 12.3 0.2 176
3000 2270 21 9.8 9.8 9.8
9.8 9.8 9.8 0.0 142
4500 2200 20.8 9.1 9.1 9
9 9 9.1 0.1 154
4500 2200 19.9 9.1 9.1 9.1
9.1 9.4 9.3 0.3 150
Typical cross country cruise is above 6500', 2350 RPM, WOT and ~20 degrees
LOP. I plan for 168kts TAS. Fuel burn is of course dependent on altitude
but is typically 10.5 - 11.5GPH (pilot, passenger and some bags).
Of interest, the fuel flow spread (first to peak, last to peak) on the new
from Van's stock IO-540 was 1 GPH (standard injectors were all the same
size: .028"). At that spread LOP was a real rough engine. Now LOP is as
smooth as ROP.
Carl
Posted: Tue Feb 11, 2014 6:59 pm Post subject: Fuel consumption test results |
Some engines run LOP easier than others, but tuning the injectors helps a lot. Airflow recommends putting a new set of 0.025" nozzles to start he process for better atomization of fuel (up to 260hp in the 540, 0.026" over 260HP). I have done this process with at least 8 engines all with very good results. I usually do the tuning at the power setting that the owner likes to use for cruise. I now stock nozzles to help people do all of the tuning in a short visit. This and dynamic balancing are the best ways to get your engine running as smoothly as possible, no matter what the power setting, and both LOP and ROP.
Jesse
[quote] On Feb 11, 2014, at 8:58 PM, "Carl Froehlich" <carl.froehlich(at)verizon.net> wrote:
9.8 9.8 9.8 0.0 142
9 9 9.1 0.1 154
9.1 9.4 9.3 0.3 150
smooth as ROP.
Carl
Mike Whisky
Posted: Thu Feb 13, 2014 11:57 am Post subject: Re: Fuel consumption test results |
Thank you all for your feedback.
I am currently running all cylinders on .045 nozzles from Airflowperformance and did send my data to Don. He is sending me now some nozzles to reduce the spread.
Michael
#511 |
Posted: Thu Feb 13, 2014 12:26 pm Post subject: Fuel consumption test results |
I hope you mean 0.025" nozzles.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | On Feb 13, 2014, at 2:57 PM, "Mike Whisky" <rv-10(at)wellenzohn.net> wrote:
Michael
#511
http://forums.matronics.com/viewtopic.php?p=418669#418669
Mike Whisky
Posted: Fri Feb 14, 2014 1:12 am Post subject: Re: Fuel consumption test results |
Jesse my RPM is limited to 2500 due to noise regulations
Therefore Don suggested .024 nozzles
Mike
#511 |
Posted: Fri Feb 14, 2014 7:01 am Post subject: Fuel consumption test results |
Let us know how the whole rejetting works out.
Mike Whisky
Posted: Sun Feb 16, 2014 12:25 am Post subject: Re: Fuel consumption test results |
Sure will do. So far I did test flights at different altitudes and power settings . It world like this: I noted EGTs from .5 gal fuel flow before the first cylinder peaks in .2gal steps down untilgbar all EGTs peaked. The data I sent to Don at airflow performance and he suggested to try first a .025 In # 5, a .0245 in #6
and maybe cylinder #2, and a .0235 in #1. I will update the data once I have installed and tested the nozzles.
Michael
#511 |
Rv10flyer(at)live.com Guest
Posted: Sun Feb 16, 2014 8:38 am Post subject: Fuel consumption test results |
I can use some education here. If Lycoming is putting in .0280 and some are taking the restrictor down to .025, what does that do to WOT on takeoff? Is the 22-23 gph still being seen on takeoffs to cool the CHT?
Why wouldn't lycoming just put .025 restrictors in to start with?
Pascal
On Feb 16, 2014, at 12:25 AM, "Mike Whisky" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)> wrote:
[quote]--> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
Michael
#511
http://forums.matronics.com/viewtopic.php?p=418780#418780
http://www.matronics.com/Navigator?RV10-List================================================
http://www.mat==================================================
Kelly McMullen
Posted: Sun Feb 16, 2014 11:29 am Post subject: Fuel consumption test results |
I suspect the effort is to have the pressure to the injectors be a bit higher for better atomization, however, I think it is a valid question, especially if it changes the minimum pressure needed to develop full power. IIRC that is somewhere around 15 psi in stock form.
On Sun, Feb 16, 2014 at 9:37 AM, PReid <Rv10flyer(at)live.com (Rv10flyer(at)live.com)> wrote:
| Quote: | I can use some education here. If Lycoming is putting in .0280 and some are taking the restrictor down to .025, what does that do to WOT on takeoff? Is the 22-23 gph still being seen on takeoffs to cool the CHT?
Pascal
| Quote: | --> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
Michael
#511
| | Quote: |
get="_blank">http://www.matronics.com/Navigator?RV10-List
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
Dick Sipp
Posted: Sun Feb 16, 2014 1:59 pm Post subject: Fuel consumption test results |
This is what Don had me do as well saying at the time that the .028 to .025 trade off is around 260HP and is done for better spray patterns. We also checked for adequate takeoff fuel flow; I don’t remember the exact number but I think it was appox. 23-25 gph. I usually see at least 25 gph.
Dick Sipp
530 hours
Sent: Sunday, February 16, 2014 2:29 PM
Subject: Re: Re: Fuel consumption test results
Pascal
mber
Michael
#511
| | Quote: |
