Empennage SBs
vanremog(at)aol.com
PostPosted: Sun Feb 09, 2014 10:45 pm    Post subject: Empennage SBs Reply with quote
Might I suggest as you all go about your SB inspections, that you report back to the lists with your a/c type, TTA, inspection results (no cracks, cracks, extensive cracks) and your flying profiles (no aero, mild aero, hard aero) to help us understand the overall fleet condition and assess the airframe life of these designs under the normal range of conditions. Some of you are quite easy on these airframes while others I'm sure are yank and bankers.
As for my RV-6A situation at 1130 TTA, no cracks or distress found in either the horizontal stab or elevator, with a history of mild to no aerobatics, a few dozen hours in mountain wave conditions during cross countries and only one time to +6gs during botched maneuver.
-GV
n81jg(at)aol.com
PostPosted: Sun Feb 09, 2014 10:57 pm    Post subject: Empennage SBs Reply with quote
RV7A 781JG
466 hrs
No aero
No cracks HS or E
On Feb 9, 2014, at 10:41 PM, vanremog(at)aol.com (vanremog(at)aol.com) wrote:
[quote] Might I suggest as you all go about your SB inspections, that you report back to the lists with your a/c type, TTA, inspection results (no cracks, cracks, extensive cracks) and your flying profiles (no aero, mild aero, hard aero) to help us understand the overall fleet condition and assess the airframe life of these designs under the normal range of conditions. Some of you are quite easy on these airframes while others I'm sure are yank and bankers.
-GV
rice737(at)msn.com
PostPosted: Mon Feb 10, 2014 1:39 am    Post subject: Empennage SBs Reply with quote
RV8   N64PR
400 hours, light acro.
No Cracks found, but also no relief holes(indents) either.  Same with my friends RV6 slow build 9 still building), not relief recesses(indents).
Subject: Re: Empennage SBs
Date: Sun, 9 Feb 2014 22:57:02 -0800
To: rv-list(at)matronics.com
RV7A  781JG
466 hrs
No aero
No cracks HS or E
-GV
igator?RV-List"" target="_blank">http://www.matronics.com/Navigator?RV-List
quot;" target="_blank">http://forums.matronics.com
tribution"" target="_blank">http://www.matronics.com/contribution
sheldonb(at)frontiernet.n
PostPosted: Mon Feb 10, 2014 3:21 am    Post subject: Empennage SBs Reply with quote
RV6A 707 hrs 0-360 w/sensenich fp. No acro or grass/dirt strips. No cracks hs or elev.
Sheldon N858SB
carl.froehlich(at)verizon
PostPosted: Mon Feb 10, 2014 3:53 am    Post subject: Empennage SBs Reply with quote
RV8A N716RV
700 hours, mild aerobatics. No cracks or other issues found on HS or elevator.
Carl
On Feb 10, 2014, at 1:57 AM, Jack <n81jg(at)aol.com (n81jg(at)aol.com)> wrote:
[quote]RV7A 781JG
466 hrs
No aero
No cracks HS or E
-GV
FisherPaulA(at)johndeere.
PostPosted: Mon Feb 10, 2014 4:57 am    Post subject: Empennage SBs Reply with quote
RV-7A N18PF
435 hours (first flight August 2009)
No cracks
No aerobatics
(yes, I baby it!)
- Paul
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of vanremog(at)aol.com
Sent: Monday, February 10, 2014 12:42 AM
Subject: Empennage SBs
…snip…
[quote] [b]
gene.lee(at)gte.net
PostPosted: Mon Feb 10, 2014 6:24 am    Post subject: Empennage SBs Reply with quote
RV7A finished 2005
O-360, CS Prop
1051 hrs
Very Little light Aero
No cracks HS or E
Sent: Monday, February 10, 2014 12:41 AM
-GV
http://forums.matronics.com[/url]         - List Contribution Web generous  Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â  -Matt http://www.matronics.com/c=[/b] [/quote]
HCRV6(at)comcast.net
PostPosted: Mon Feb 10, 2014 11:43 am    Post subject: Empennage SBs Reply with quote
RV-6 N16CX
1140 hours
O-360A1A
Catto two blade (composite, wood/glass)
Very mild acro, some grass
Numerous horrible landings
No cracks
Harry Crosby
…snip…
mr.sun
PostPosted: Mon Feb 10, 2014 11:51 am    Post subject: Empennage SBs Reply with quote
700 hour 2004 RV7 light acro.  No cracks.
2300 hour, friend's RV6, light acro, lots of instruction, no cracks
Greg On Feb 10, 2014 1:43 AM, "Paul Rice" <rice737(at)msn.com (rice737(at)msn.com)> wrote:[quote] RV8   N64PR
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
RV7A  781JG
466 hrs
No aero
No cracks HS or E
-GV
Greg RV-7
sarg314(at)gmail.com
PostPosted: Mon Feb 10, 2014 12:03 pm    Post subject: Empennage SBs Reply with quote
I did the inspections and could see no problems, though I should mention that since my airplane was painted before It was flown, it was painted in pieces (55 to be exact). So my elevators and H.S. have color coat on top of the primer virtually everywhere that is visible.  That urethane paint is pretty tough and flexible. There could be a crack in the aluminum without it showing through urethane, couldn't there?
N811WT
IO-360-B2B
3-blade Catto prop.
125 hrs.
No problems visible.
Tom Sargent
ceengland7(at)gmail.com
PostPosted: Mon Feb 10, 2014 2:29 pm    Post subject: Empennage SBs Reply with quote
N811WT
IO-360-B2B
3-blade Catto prop.
125 hrs.
Tom Sargent
Unfortunately, the SB says to remove paint/primer so you can see the
cracks, if they are there.
Q:
Inspection: Remove the Empennage fairing. Carefully inspect for cracks
emanating from
the stress relief notch at the inboard end of the forward horizontal
stabilizer spar flanges.
(see Figure 1 and figure 3). Clean the area and remove any paint,
overspray or primer
that could hide a crack. Cracks may be very small and hard to detect.
