Electrical architecture with aux battery
PostPosted: Wed Feb 05, 2014 9:43 am    Post subject: Electrical architecture with aux battery Reply with quote
Attached is a circuit with a brownout battery (non cranking). It will be kept charged through a diode when the E-Bus alternate feed is off. The aux battery will be connected in parallel with the main battery when both aux battery switch and the E-Bus switch are turned on (expected normal operation after engine start). This circuit is not for my plane. I offer it for discussion and comments.
Joe
Z-11 Modified 2.pdf
 Filename:  Z-11 Modified 2.pdf
 Filesize:  85.58 KB
 Downloaded:  496 Time(s)
Joe Gores
PostPosted: Wed Feb 05, 2014 12:49 pm    Post subject: Electrical architecture with aux battery Reply with quote
There is a way to avoid charging the aux
battery through a diode and eliminate one
switch.
http://tinyurl.com/7ro5yuc
PostPosted: Wed Feb 05, 2014 2:17 pm    Post subject: Re: Electrical architecture with aux battery Reply with quote
Bob,
I had looked at Z-10/8 but neglected to notice that your circuit uses one less switch than mine. I should have known better than to try and improve on your architecture. Very Happy
Thanks for the reply.
Joe
Joe Gores
PostPosted: Wed Feb 05, 2014 2:44 pm    Post subject: Re: Electrical architecture with aux battery Reply with quote
When the alternator is off or has failed, the extra switch in my circuit would allow powering the E-bus by only one battery at a time. I do not know if that is an advantage or not. The more complicated a system is, the greater the chance for pilot error.
Joe
Joe Gores
