rparigoris
Posted: Tue Feb 04, 2014 11:09 am Post subject: Small Connector for Ray Allen Trim Servo Cables? |
Hi Valin
We were going to use D-sub connector with no shell, use Goop to hold wires to connector and heat shrink together (this was one of Bobs ideas, I am pretty sure he has instructions for this).
Since we have an inspection cover close to the servo, insteads of using a connector we just stagger soldered wires and heat shrunk, leaving a service loop to allow us to unsolder if servo ever needed replacement or removal.
In addition we marked on a white piece of heat shrink which wires you would want to connect to a 9 volt battery to jog to a somewhat neutral position to get you home in the event the pitch circuit failed.
Details:
http://www.europaowners.org/main.php?g2_itemId=30484
Ron Parigoris [quote][b]
