jluckey(at)pacbell.net Guest
Posted: Sun Feb 02, 2014 3:39 pm Post subject: Analyze This |
Listers,
Attached find a schematic (some people call them ladder diagrams) of a design for the electrical system for my RV-7A. Below is a list of design goals, pros and cons. Please take a look and provide engineering feedback.
TIA
Electrical Systems Design Goals:
1. fault tolerant - able to tolerate failure of any single component and fly for 45 min.
2. easy to operate
3. no avionics brown-out on engine start
4. easy to repair
5. comprised of standard, readily-available components
6. cost effective
Pros:
1. simplified operation - only 2 master switches
2. simplified design - single buss
3. no brown-out on engine start
4. automatic fail-over - no pilot interaction required; avionics won't reset
In the event a battery system suffers a failure, either an open circuit or a ground fault, the faulty
system simply stops providing power to the buss and the remaining good system continues to
provide electricity without interruption.
Cons:
1. buss-isolation power diodes may require heat sinks
2. some energy wasted as heat thru power diodes
PowDist01.pdf |
38.18 KB |
870 Time(s) |
Posted: Sun Feb 02, 2014 5:57 pm Post subject: Analyze This |
At 05:38 PM 2/2/2014, you wrote:
| Quote: | Listers,
The alternator's b-lead is two diode-drops
removed from the regulator bus sense lead so
expect the b-lead to run 2-drops higher voltage
than the regulator's set-point. With the battery
tapped in between the two diodes, you'll want to
adjust the regulator for a BATTERY voltage of
14.2V
This will peg the b-lead at 14.2+diodeV and
the bus at 14.2-diodeV.
Current limiters are not generally recommended
or demonstrated as useful in battery feeders.
Posted: Sun Feb 02, 2014 7:44 pm Post subject: Analyze This |
Sent: Sunday, February 2, 2014 5:56 PM
Subject: Re: Analyze This
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | Listers,
14.2V
Roger that
If the prove to be problematic, it is very easy to bypass them
thanks bob
sp; -================
Posted: Mon Feb 03, 2014 8:01 am Post subject: Re: Analyze This |
The 60 amp fuse protects battery A from an alternator short circuit, but there is no fuse to protect battery B. Either relocate the 60 amp fuse to the alternator side of the diodes or else add a second 60 amp fuse.
A single shunt could be located in the alternator B lead and eliminate the ammeter selector switch. Or a 3 position selector switch and a third shunt could measure alternator output. Battery current shunts will carry very little current most of the time except after engine start. There have been lots of discussions about the best location for a shunt or if it is actually needed. It is a matter of personal preference.
Joe
_________________ Joe Gores |
Posted: Mon Feb 03, 2014 10:41 am Post subject: Re: Analyze This |
When the alternator fails, there should be a way to shut off the alternator field to conserve battery energy. Either a pullable circuit breaker or an independent switch.
Joe
Posted: Mon Feb 03, 2014 10:59 am Post subject: Analyze This |
both of those things are on the drawing...
Thx for reviewing,
-Jeff
Sent: Monday, February 3, 2014 10:41 AM
Subject: AeroElectric-List: Re: Analyze This
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=418036#418036
Posted: Mon Feb 03, 2014 4:02 pm Post subject: Re: Analyze This |
Suppose the alternator shorts to ground and the 60 amp fuse blows. Is there a chance that a 100 amp current limiter will also blow?
Joe
Posted: Mon Feb 03, 2014 6:32 pm Post subject: Analyze This |
I would say it's highly unlikely. The 100 amp might warm up but the 60 should hit its melting point before the 100. I don't know how the resistance of a fuse that's in the process of blowing changes. If its resistance goes up, it would begin to limit the current for a few milliseconds until it clears.
-Jeff
Sent: Monday, February 3, 2014 4:02 PM
Joe
Joe Gores
http://forums.matronics.com/viewtopisp; -================
Posted: Tue Feb 04, 2014 6:31 pm Post subject: Re: Analyze This |
Most aircraft are wired so that starter motor current comes from the battery, through the master contactor, then through the starter contactor to the starter motor. Then if the starter contactor sticks closed, the pilot can break the circuit by shutting off the master switch. I modified Jeff's circuit (attached).
Joe
Starter_Circuit.pdf |
3.14 KB |
480 Time(s) |
Posted: Tue Feb 04, 2014 9:02 pm Post subject: Analyze This |
I chose the "non-traditional" approach because:
1. Contactor sticking is exceedingly rare
2. I did not want cranking to be dependent on 2 contactors
3. It allows for more choices when selection a master relay
Sent: Tuesday, February 4, 2014 6:31 PM
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=418101#418101
http://forums.matronics.com//files/starter_circuit_194.pdf
sp; - MATRONICS WEB FORUMS -
sp; -->
peter(at)sportingaero.com Guest
Posted: Sat Feb 08, 2014 1:09 am Post subject: Analyze This |
Jeff,
I would like a little explanation of the basic operation. I'm assuming both master switches on all the time, both batteries are the same, throw one battery away each year.
If alternator fails no simple load shedding is available, pilot must select items individually (or have a check-list of what to switch off). You're now wasting 2 amps (1 or each battery contactor).
Think about the information you want the 2 shunts to provide, will the do that, is there a better (simpler) way? As you already have the power indicators, I would put the shunt in the alternator to bus feed. Agree with comment about fusing (or current limiting) feed to batt B. I thought a current limiter was better placed in the alternator output?
I'm unsure what the 'K-...' means
2 batteries will provide way more than 45 minutes operation on battery power, even with a very full panel and no load shedding. Therefore system grossly exceeds design goal resulting in more cost/weight than required. Where does 45 minutes come from? FAR-23 requires 30 minutes, alternatively assume half or full fuel endurance.
No simple load shedding appears available - meets goal 2 (but perhaps goal 1 & 2 are actually, survive any failure for 45 minutes with no pilot interaction)
System seems more complex/costly than a 2 bus system would be. Seems that goals 1 & 2 are weighted much more highly than the others?
Its your airplane, build the system that meets your needs.
Regards, Peter
On 02/02/2014 23:38, Jeff Luckey wrote:
[quote] Listers,
TIA
2. easy to operate
4. easy to repair
6. cost effective
Pros:
Cons:
Posted: Sat Feb 08, 2014 10:52 am Post subject: Analyze This |
Peter,
Thanks for taking the time to review the drawing. I really appreciate the insightful comments.
My responses are mixed-in with you questions.
Thx again,
-Jeff
Sent: Saturday, February 8, 2014 1:08 AM
Subject: Re: AeroElectric-List: Analyze This
Jeff,
Yes - both masters on for normal ops. In addition,
at start-up by turning-on each master individually and
watching the power indicators & volt meter you can
confirm that isolation diodes are functioning properly.
See comment re load shedding below. My master
relays draw 200 mA each.
I'm using a zero-center ammeter. With the shunt in
its current location it provides info on the health of
the battery charging system when everything is
working properly.
When the alternator fails, it automatically becomes
a load meter to aid the pilot in load-shedding. Exactly
the info you want, exactly when you need it.
There are fuses in alternator output leads.
An over-voltage protection module will prevent alternator
run-away.
With the shunt in the alternator output, in the case that the
alternator fails, you get no information about system load and
that's when you need it the most in order to do
effective load-shedding.
'K' is an industry standard abbreviation for relay/contactor
That would depend upon battery selection and system load.
I did not provide any info on this for my airplane.
45 minutes is my personal preference.
I prefer to be in control of load-shedding based upon the
situation. I don't like the idea of having it predetermined
by what is wired to an E-buss.
If I'm day VFR I may want to turn-off lots of things. If
I'm preparing for an Instrument approach, I may decide
not to turn-off anything.
Perhaps simplicity/complexity is in the eye of the beholder.
I think a single buss is simpler than multiple busses with
inter-connection/bypass relays.
The buss-isolation diode units cost ~$20 each. I'm willing
to spend the extra $40.
Regards, Peter
[quote] Listers,
TIA
2. easy to operate
4. easy to repair
6. cost effective
Pros:
Cons:
Posted: Mon Feb 10, 2014 1:56 pm Post subject: Analyze This |
Its not me who needs the answers ...
On 08/02/2014 18:50, Jeff Luckey wrote:
[quote] Peter,
Thx again,
-Jeff
From: Peter Pengilly <peter(at)sportingaero.com> (peter(at)sportingaero.com)
Jeff,
working properly.
run-away.
Regards, Peter
| Quote: | Listers,
TIA
2. easy to operate
4. easy to repair
6. cost effective
Pros:
Cons:
Posted: Tue Feb 11, 2014 5:26 pm Post subject: Analyze This |
Great Peter. If you have any further questions, I'm happy to provide answers...
Sent: Monday, February 10, 2014 1:54 PM
[quote] Peter,
Thx again,
-Jeff
Jeff,
working properly.
run-away.
Regards, Peter
| Quote: | Listers,
TIA
2. easy to operate
4. easy to repair
6. cost effective
Pros:
Cons:
http://www.matronics.com/Navigattarget="_blank" href="http://forums.matronics.com/">http://forums.matro --> [b]
