Cj6 engine run in
Jacquescj6
PostPosted: Wed Feb 05, 2014 9:42 am    Post subject: Cj6 engine run in Reply with quote
Hi Guys
I have replaced my cj engine with a new overhauled engine. Any advise on doing the run in on the engine?
rmhou(at)yahoo.com
PostPosted: Wed Feb 05, 2014 10:55 am    Post subject: Cj6 engine run in Reply with quote
Attached is the engine run-in procedure after replacement of cylinders.
How do you get a newly overhauled engine? Do you mind sharing the current market price for an overhauled engine? 1st, 2nd, 3rd or 4th overhaul?
Robin
To: yak-list(at)matronics.com
Sent: Wednesday, February 5, 2014 9:42 AM
Subject: Cj6 engine run in
--> Yak-List message posted by: "Jacquescj6" <jacobscj6(at)yahoo.com (jacobscj6(at)yahoo.com)>
Hi Guys
http://forums.matronics.com/viewtopic.php?p=418122#418122
<br &nbs===================
Engine_Run-In.pdf
 Filename:  Engine_Run-In.pdf
 Filesize:  260.39 KB
 Downloaded:  605 Time(s)
Jacquescj6
PostPosted: Wed Feb 05, 2014 11:14 am    Post subject: Re: Cj6 engine run in Reply with quote
Hi Rob
Thanks will look at it.
I got this one from the the person that actually imported the aircraft.
I did some investigation could get 1st time overhauled engine's for round about 30 000 uS 2nd 20 000. You can ask Doug Sapp here he was also a big help.
