mau11(at)orange.fr Guest
Posted: Thu Jan 30, 2014 10:40 pm Post subject: Water calorstat installation |
Hello all,
With 912S I have very low temperatures, particulary in winter, oil>60°C
Coolant>60°C and I live in French Alps, When I am in descent from
10000ft or more the coolant is below 50°C. I used a masked tape on the
radiator, but it is not good when I climb > 105 to 120°C in descent > 50°C.
Few month ago I take a decision to install Calorstat.
On the Oil circuit I install the model in the picture. The result is
good temperatures are between 90 and 105°C in all configurations.
For the coolant I have project to install the calorstat showed in the
attached picture.
Does anyone have experience of this type of installation pictures and
comments or others.
Many thanks
Michel AUVRAY
EUA 145 - 500 HF
16.7 KB |
5750 Time(s) |
7.77 KB |
5750 Time(s) |
pete(at)lawless.info Guest
Posted: Fri Jan 31, 2014 2:43 am Post subject: Water calorstat installation |
Hi Michael
I have had both these stats installed on my 912ul classic for the last 2
years. Absolutely transformed the warm up time and the running
temperatures both settle at 80 degrees plus and don't drop during the
decent. The oil stat enabled me to move the oil radiator to its own air
intake under the prop which has really helped to keep the temperature
down in the summer.
Fitting the stats, particularly the water stat was a real struggle with
the classic cowl, not much room under there and even less now.
Pete
On 31/01/14 06:39, Michel AUVRAY wrote:
| Quote: | Hello all,
oil>60°C Coolant>60°C and I live in French Alps, When I am in descent
from 10000ft or more the coolant is below 50°C. I used a masked tape
on the radiator, but it is not good when I climb > 105 to 120°C in
descent > 50°C.
attached picture.
comments or others.
Many thanks
Michel AUVRAY
EUA 145 - 500 HF
alainchabert(at)wanadoo.f Guest
Posted: Fri Jan 31, 2014 7:41 am Post subject: Water calorstat installation |
http://www.norauto.fr/produit/thermostat-valeo-reference-819904_525319.html
Alain CHABERT
Gsm : +33-6-07.71.02.17
e-mail : alainchabert(at)wanadoo.fr (alainchabert(at)wanadoo.fr)
Le 31/01/14 07:39, Michel AUVRAY a écrit :
[quote]Hello all,
With 912S I have very low temperatures, particulary in winter, oil>60°C Coolant>60°C and I live in French Alps, When I am in descent from 10000ft or more the coolant is below 50°C. I used a masked tape on the radiator, but it is not good when I climb > 105 to 120°C in descent > 50°C.
On the Oil circuit I install the model in the picture. The result is good temperatures are between 90 and 105°C in all configurations.
For the coolant I have project to install the calorstat showed in the attached picture.
Does anyone have experience of this type of installation pictures and comments or others.
Many thanks
Michel AUVRAY
EUA 145 - 500 HF
Roland
Posted: Mon Feb 03, 2014 3:12 am Post subject: Re: Water calorstat installation |
I have a water thermostat of Silent Hektik installed (Rotax 914)
http://www.silent-hektik.com/UL_912_Thermo.htm
Works flawless and keeps the water temp up except during very extensive descents in ice cold conditions, when it also drops below 85°C.
Roland
PH-ZTI
XS Trigear 914
