Weight Saving
nigel_graham(at)m-tecque.
PostPosted: Wed Jan 29, 2014 4:44 am    Post subject: Weight Saving Reply with quote
The wheel (mono) carries a little unnecessary weight. You can lighten
the disk without compromising reliability and the cast marks can be
turned off the rims (see attached). Polishing is optional. I can't
really claim that the black "crackle" finish saves weight, but is does
look better than the corroded "white furred" alloy that is frequently
seen Wink
Nigel
On 28/01/2014 14:32, Peter Zutrauen wrote:
on the subject of weight savings, I can't help but notice how heavy
the mono swingarm is. I noticed in Germany one builder had put many
lightening holes in it (among many other mods). I had also wondered
if indeed it was over-designed and could use some strategically placed
holes. Is that the only builder who has lightened it? Has anyone
done any math on that heavy piece?
Cheers & thx,
Pete
A239
Mono_Disk.pdf
 Filename:  Mono_Disk.pdf
 Filesize:  223.67 KB
 Downloaded:  193 Time(s)
