turf runways
Goto page 1, 2  Next
cooprv7(at)yahoo.com
PostPosted: Sun Jan 26, 2014 7:48 pm    Post subject: turf runways Reply with quote
I have steered clear of grass runways in my RV-10 since there is so little clearance below the wheelpants, but I was wondering what experience others have had? Those of you who fly off of grass, what sort of criteria and conditions do you require?
I'm interested in moving to an Airpark (probably TN) in the next few years and not having to limit the search to paved runways would sure open the opportunities.
Marcus
flying-nut(at)cfl.rr.com
PostPosted: Sun Jan 26, 2014 7:58 pm    Post subject: turf runways Reply with quote
We're talking grass here. If the grass is long enough to cause damage
to the pants it's probably long enough to prevent you getting in the air.
The thing that destroys the pants are vibrations from many operations on
a rough runway. Drive a car down the runway .... at 40 MPH or more
you'll feel roughness.
Linn ..... lots of ops on grass strips
Marcus
Checked by AVG - www.avg.com
n223rv(at)wolflakeairport
PostPosted: Mon Jan 27, 2014 2:33 am    Post subject: turf runways Reply with quote
I live on a 2200' grass runway. When I built my -10 I raised the wheel pants a little higher, maybe an extra 3/4-1" is all I could get. I also made the clearance around the wheel approximately 1" all the way around. I've had no issues and no wheel pant damage so far in 3 years and ~270 hours.
-Mike Kraus
Marcus
johngoodman
PostPosted: Mon Jan 27, 2014 5:10 am    Post subject: Re: turf runways Reply with quote
Go Pantless, like I did.
flysrv10(at)gmail.com
PostPosted: Mon Jan 27, 2014 5:59 am    Post subject: turf runways Reply with quote
The bottom of my wheel pants are left with primer color only due to rubbing against grass. However it is not visible unless you are removing the wheel pants.
Do not archive.
Rob Kermanj
On Jan 26, 2014, at 10:58 PM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
We're talking grass here. If the grass is long enough to cause damage to the pants it's probably long enough to prevent you getting in the air.
The thing that destroys the pants are vibrations from many operations on a rough runway. Drive a car down the runway .... at 40 MPH or more you'll feel roughness.
> Thanks,
> Marcus
> No virus found in this message.
amekler
PostPosted: Mon Jan 27, 2014 6:19 am    Post subject: turf runways Reply with quote
I took my pants off for winter. It costs me about 8 kts but necessary to avoid damage.
Alan
N668G
Do not archive.
Rob Kermanj
>> Thanks,
>> Marcus
tgmeyerster(at)gmail.com
PostPosted: Mon Jan 27, 2014 6:26 am    Post subject: turf runways Reply with quote
Doesn't that get cold without your pants on in winter;-)?
On Monday, January 27, 2014, Alan Mekler <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:
[quote] --> RV10-List message posted by: Alan Mekler <[url=javascript:;]amekler(at)metrocast.net[/url]>
Alan
N668G
> On Jan 27, 2014, at 8:58 AM, Rob Kermanj <[url=javascript:;]flysrv10(at)gmail.com[/url]> wrote:
> --> RV10-List message posted by: Rob Kermanj <[url=javascript:;]flysrv10(at)gmail.com[/url]>
> Do not archive.
> Rob Kermanj
> Sent from my iPhone
>> On Jan 26, 2014, at 10:58 PM, Linn Walters <[url=javascript:;]flying-nut(at)cfl.rr.com[/url]> wrote:
>> --> RV10-List message posted by: Linn Walters <[url=javascript:;]flying-nut(at)cfl.rr.com[/url]>
>>> --> RV10-List message posted by: Cooprv7 <[url=javascript:;]cooprv7(at)yahoo.com[/url]>
>>> Thanks,
>>> Marcus
http://forums.matronics.com
le, List Admin.
PostPosted: Mon Jan 27, 2014 6:35 am    Post subject: turf runways Reply with quote
I thought about that but just can't do it. 7 years with pants on has me used to them.
On Jan 27, 2014, at 8:10 AM, "johngoodman" <johngoodman(at)earthlink.net> wrote:
#40572 Phase One complete and flying.
http://forums.matronics.com/viewtopic.php?p=417667#417667
PostPosted: Mon Jan 27, 2014 6:38 am    Post subject: turf runways Reply with quote
Thanks for all of the replies, seems like I've been overly cautious and will give it a try given favorable conditions.
Thanks again,
Marcus
Do not archive.
Rob Kermanj
>> Thanks,
>> Marcus
Kellym
PostPosted: Mon Jan 27, 2014 6:39 am    Post subject: turf runways Reply with quote
What might seem counter-intuitive, in the desert Southwest, pants are
needed for engine cooling.
The added drag and lower airspeed reduces air over the engine, resulting
in hotter temps.
I've forgotten how much Deems said his temps came down after he added
wheel pants, and I seem to recall the speed penalty was over 10 kts
without the pants. Currently planning on doing pants during phase 1, and
not before first flight.
Kelly McMullen
KCHD
speckter(at)comcast.net
PostPosted: Mon Jan 27, 2014 6:48 am    Post subject: turf runways Reply with quote
I operate almost exclusively off of grass. I have had some issues with vibration causing the mounting hardware to shake loose. I solved that with Sean's spacer for the mains. The only other thing I notice is a very slow erosion of paint on the bottoms. You need to watch out for ant mounds and gopher holes though. The 10 works great on grass.
Gary Specketer
Sent: Sunday, January 26, 2014 10:48:03 PM
Subject: turf runways
--> RV10-List message posted by: Cooprv7 <cooprv7(at)yahoo.com>
I'm interested in moving to an Airpark (probably TN) in the next few years and not having to limit the search to paved runways would sure open the opportunitie &nbs========================
partner14
PostPosted: Mon Jan 27, 2014 6:49 am    Post subject: turf runways Reply with quote
Just make sure you can get your fingers between the tire and the pants all the way around (and make sure that is STILL the case when you replace the tires).  Also, when landing on grass increase the inflation by 5 or so pounds, you'll be just fine. Landed at Cedar Mill TX 3 times, Johnson Creek ID about 12 times, and Smiley Creek ID twice.... neither I, or any of the RV'rs in the group have ever had a wheel pant issue.
On Monday, January 27, 2014 8:39 AM, Timothy Meyer <tgmeyerster(at)gmail.com> wrote:
[quote] --> RV10-List message posted by: Alan Mekler <[url=]amekler(at)metrocast.net[/url]>
Alan
N668G
> On Jan 27, 2014, at 8:58 AM, Rob Kermanj <[url=]flysrv10(at)gmail.com[/url]> wrote:
> --> RV10-List message posted by: Rob Kermanj <[url=]flysrv10(at)gmail.com[/url]>
> Do not archive.
> Rob Kermanj
> Sent from my iPhone
>> On Jan 26, 2014, at 10:58 PM, Linn Walters <[url=]flying-nut(at)cfl.rr.com[/url]> wrote:
>> --> RV10-List message posted by: Linn Walters <[url=]flying-nut(at)cfl.rr.com[/url]>
>>> --> RV10-List message posted by: Cooprv7 <[url=]cooprv7(at)yahoo.com[/url]>
>>> Thanks,
>>> Marcus
le, List Admin.
http://www.matronics.c==================
Don A. McDonald
40636
dmasys
PostPosted: Mon Jan 27, 2014 10:38 am    Post subject: turf runways Reply with quote
I operate my RV-10 in and out of a turf runway at my residential airpark on
a regular basis (WN29 - see
http://www.blueribbonfarmsassociation.com/airstrip.shtml ) and it is a fine
performer. Occasionally the wheel pants get a little ding on the bottom,
but it is not from the grass but rather crossing ruts made by others. The
RV-10 has such a luxurious amount of power that even soft turf runways are
not a problem unless you combine that with high altitude, short field, and
obstacles that would make a Maule driver have second thoughts.
And if you EVER DRIVE A CAR down our turf runway, especially at high speed,
there is going to be an angry mob taking photos and chasing you out of town.
Don't do it unless it is your privately owned turf runway.
-Dan Masys
RV10 N104LD - 660 hrs
RV12 N122LD - 180 hrs
Time: 07:58:39 PM PST US
Subject: Re: turf runways
johngoodman
PostPosted: Mon Jan 27, 2014 10:54 am    Post subject: Re: turf runways Reply with quote
No chance of damaging these pants... Wink
John
 Filesize:  57.83 KB
 Viewed:  20376 Time(s)
jchang10
PostPosted: Mon Jan 27, 2014 11:39 am    Post subject: turf runways Reply with quote
Looks nice. Normally, the gear fairing is held in place by the lower
pant. How did you keep the gear fairings in place without the pants?
Jae
On 1/27/2014 10:54 AM, johngoodman wrote:
No chance of damaging these pants... [Wink]
John
http://forums.matronics.com/viewtopic.php?p=417689#417689
http://forums.matronics.com//files/img_1936_134.jpg
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
#40533 RV-10
rv10flyer
PostPosted: Mon Jan 27, 2014 5:33 pm    Post subject: Re: turf runways Reply with quote
I have flown into SC00 Triple Tree SC twice. We sat watching everyones pants shake like crazy and that runway is supposedly golf course smooth. If I lived on a grass strip I would beef up wheel pant mounts(switch to stainless) and fiberglass or just remove them.
Maybe we will hear from Bill "Living the life in an airpark with turf" Watson. He might have to put some snow skis on this week.
Wayne G.
johngoodman
PostPosted: Mon Jan 27, 2014 5:59 pm    Post subject: Re: turf runways Reply with quote
Jae
They actually stay on just fine. They are attached at the top, and the only thing I did different is taper them down as far as I could. They actually stay in place without any special work on the bottom. The nose strut is even easier, it already has screws to hold it in place. I did have to change the piano hinge set up on the mains - a pin to go up, and a pin to go down.
Without the pant brackets, and with hub caps, there's not much drag to worry about.
John
rv10flyer
PostPosted: Mon Jan 27, 2014 6:28 pm    Post subject: Re: turf runways Reply with quote
Jae
John
What you lose in speed/time, guessing...6 kias/15 min per long xc would be nothing compared to time and materials repairing broke pants on a grass strip. I would take my pants off in a heartbeat to save $170/mo hangar rent and walk out to my hangar.
Wayne G.
woxofswa
PostPosted: Thu Jan 30, 2014 12:30 am    Post subject: Re: turf runways Reply with quote
If you go with the Desser Monster retreads you'll sit a bit higher and have more clearance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
Kelly McMullen
PostPosted: Thu Jan 30, 2014 6:25 am    Post subject: turf runways Reply with quote
Well, the Monster retreads do have a bigger diameter, but you can also add diameter without the extra wt of the thicker Monster tread by using 6:00X6 tires instead of the specified 15X^:00X6 tires Vans calls for. Or you could use 6:00X6 Monster retreads for a HiRider version.
On Thu, Jan 30, 2014 at 1:30 AM, woxofswa <woxof(at)aol.com (woxof(at)aol.com)> wrote:
--> RV10-List message posted by: "woxofswa" <woxof(at)aol.com (woxof(at)aol.com)>
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear.  FWF complete.
http://forums.matronics.com/viewtopic.php?p=417867#417867
le, List Admin.
- sent from the microchip implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Goto page 1, 2  Next
Page 1 of 2
