chasb(at)satx.rr.com Guest
Posted: Mon Jan 20, 2014 9:36 pm Post subject: Strobe switches |
Bob, et.al.,
I just replaced my fourth S700-1(or equivalent) strobe switch in about 200 hours of flying time. Both fast on terminals were badly burned as was about an inch of the 18ga. wire attached to the fast on. My first two switches were Carlings from B&C. Based on AeroElectric recommendations made some years back, I ordered a S700-1 equivalent switch from Honeywell - same result. Then I tried a switch from DigiKey, same result. I'm back to a Carling, at least for the short term. I have Carlings for the Nav lights, Landing and Wig Wag lights and instrument lights, and I have had no problem with any of them. The strobe switch is backed up by a 7 amp fuse which is recommended for the strobe system (Whelen) and it has never popped. The run of 18 ga. wire is about ten feet. Of all the switches, only the strobe switch gets real hot after only a few minutes of use.
I was searching B&C for a relay I could use to reroute the strobe heavy current wire, and discovered that B&C now advertises a MilSpec single pole switch (MS35058-22) that is the equivalent of the S700-1. The dimensions appear the same, with screw type connections rather than fast ons. It ain't cheap, but it would be worth it to avoid having to frequently replace a burnt out standard switch. Would this MilSpec switch be a viable solution to the strobe switch problem?
Charlie Brame
RV-6A, N11CB
San Antonio
fvalarm(at)rapidnet.net Guest
Posted: Mon Jan 20, 2014 11:20 pm Post subject: Strobe switches |
What about using a relay to switch the strobe current? Use the carling
switch to control the relay.
Bevan
Posted: Tue Jan 21, 2014 8:24 am Post subject: Strobe switches |
| Quote: | | The strobe switch is backed up by a 7 amp fuse which is recommended for the strobe system (Whelen) and it has never popped. The run of 18 ga. wire is about ten feet. Of all the switches, only the strobe switch gets real hot after only a few minutes of use. |
Can you tell where it's getting hot? We've
had this (and similar) discussions on strobe
controls over the years. I am mystified as
to how the burning of switches and terminal
crimps seems to be concentrated on the strobe
systems . . . driven by relatively light
protection (7A fuse).
| Quote: | | I was searching B&C for a relay I could use to reroute the strobe heavy current wire, and discovered that B&C now advertises a MilSpec single pole switch (MS35058-22) that is the equivalent of the S700-1. The dimensions appear the same, with screw type connections rather than fast ons. It ain't cheap, but it would be worth it to avoid having to frequently replace a burnt out standard switch. Would this MilSpec switch be a viable solution to the strobe switch problem? |
Your question raises some interesting points.
There seems to be something 'different' about
the strobe system current draw profile that
stresses the centers of highest-resistance
in the power path. In the past, we've seen
failures at the rivet joints on the switches,
contacts within the switches, switch rockers,
and less-than-idea crimps on terminals, etc.
Yet the RMS or average current remains so
low that a relatively fast protective device
like a fuse doesn't complain. I would REALLY
like to see the current profile on a strobe
system that has repeatedly damaged its switch.
There's got to be a characteristic unique to
strobe supplies (perhaps just this model
of supply) that's especially antagonistic
to components in the power feeder.
Getting to your specific questions. A
relay would certainly transfer the stresses
away from the switch . . . but any connecting
devices in the power path (like crimps)
would still see the 'abuse'.
It might well be that a switch with molded
terminal supports . . .
[img]cid:.0[/img]
. . . would not offer the weaknesses of
riveted joints . . . but crimps, threaded
fasteners and internal contacts of the
switch would still be getting 'hammered'.
I do have a proof-of-concept, solid state
relay that I'd be pleased to send you. I've
like to get it into service on an often-flown
airplane and perhaps yours is the best
candidate. It appears that the strobes feeder
in your airplane would be a good location to
try the relay while potentially addressing
your specific failure mode.
Do you have access to any test equipment
that might measure and record the current
waveform impressed on the strobe switch
in your airplane?
I'm mulling over ideas for getting data
of your airplane and then perhaps expanding
the investigation to other airplanes to
see if we can identify the controlling
physics.
There are tens of thousands of airplanes
flying Carling switches in the strobe
power feed path . . . the fact that a
few folks here on the List have experienced
serial failures of these switches is
curious to say the least.
50.42 KB |
12408 Time(s) |
Posted: Tue Jan 21, 2014 9:28 am Post subject: Strobe switches |
I experienced a burned out fast-on connector at my fuse panel on the
16AWG strobe power lead between the fuse panel and the switch. My
strobe unit was a CreativAir Avi-Pak 60 watt, 4 outlet strobe power
suppy intended for experimental aircraft use. Three strobes were
connected. There was a 15amp fuse on the unit and a 15amp fuse on the
fuse panel. This was on an RV10 and there was somewhere between 10 and
20 feet of 16AWG wire in the switched power circuit.
I had difficulty identifying the burned out fast-on connector. The
circuit remained intact despite it's inability to carry the required
load. In the course of problem determination, I decided to replace the
unit. (I later determined that the unit works just fine)
The CreativAir units are no longer available so I installed a unit from
Nova Electronics - XPAK604X 60 watt, 4 outlet strobe power suppy. It is
also referred to as a SUPERPAK604X. This unit seems to be intended for
emergency vehicle use but is very similar to the CreativAir product, it
looks like it is from the same manufacturer with the same dimensions and
mounting hardware.
However, it can be powered by an unswitched line directly from the power
circuit. It is operated thru a separate control circuit. In the RV10
this allowed me to reduce the power circuit from over 10 feet to less
than 3 feet. Where the old circuit was warm/hot to the touch,
everything is now cool.
The XPAK604X was cheaper, had more strobe pattern options and used a
control circuit which would seem to accomplish what a relay would do.
Bevan
Posted: Wed Jan 22, 2014 7:13 am Post subject: Strobe switches |
the fuse panel. This was on an RV10 and there was somewhere between
10 and 20 feet of 16AWG wire in the switched power circuit.
the unit. (I later determined that the unit works just fine)
Do you still have this 'problem' system?
Interesting. I wonder if they 'discovered' the
features in their power demands that were so
abusive of otherwise perfectly good switches . . .
I'm gathering the hardware together to craft a
mailable data acquisition system together that
I can ship to a willing List member to gather
some definitive data on their strobe systems.
I'd like to acquire a library of data both
from systems that have suffered failures in
the power wiring . . . and some that didn't.
"When you can measure what you are speaking about,
and express it in numbers, you know something about
it, when you cannot express it in numbers, your knowledge
is of a meager and unsatisfactory kind; it may be
the beginning of knowledge, but you have scarcely,
in your thoughts advanced to the stage of science."
---- Lord Kelvin ----
We've been watching these rare but significant
events for some years . . . ignorant of the
root cause. I'm thinking it's time to get some
good numbers.
Posted: Wed Jan 22, 2014 7:16 am Post subject: Strobe switches |
At 11:32 PM 1/20/2014, you wrote:
--> AeroElectric-List message posted by: Charles Brame <chasb(at)satx.rr.com>
Bob, et.al.,
Charlie, do you want to try the solid state
relay? If you do install this relay . . .
[img]cid:7.1.0.9.0.20140122091114.01120aa8(at)aeroelectric.com.0[/img]
. . . it will offer a plug-n-play port through which
we can gather some good numbers when the DAS system
goodies I've ordered get here . . .
95.03 KB |
12394 Time(s) |
Posted: Wed Jan 22, 2014 8:56 am Post subject: Strobe switches |
Bob,
Thanks for the response. See my answers to your questions in red below.
Charlie Brame
RV-6A N11CB
San Antonio
Time: 08:24:54 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: Re: Strobe switches
| Quote: | The strobe switch is backed up by a 7 amp fuse which is
With this latest switch failure the hot spots were the fast on connectors at the switch, and I did not notice the switch itself getting hot. The switch fast on tabs are externally riveted and became very loose. There is no signs of burning of the switch itself, though something caused the fast on tabs to become loose on the switch body. And both of the connectors (power in and power out) were burned. In one of the previous Carling failures, the switch was fried on the inside, and the switch itself got hot, including the bat handle. The power connector at the power pack is a Molex type pin plug and does not show any heat related distress. The power supply fast on at the fuse panel has also never shown any signs of heating. With a new switch installed, there is no evidence of any hot spots. However, after a period of time, the problem reoccurs.
We've had this (and similar) discussions on strobe
| Quote: | I discovered that B&C now advertises a MilSpec single pole switch (MS35058-22) that is the equivalent of the
S700-1. Would this MilSpec switch be a viable solution to the strobe switch problem? |
Emacs!
I would be pleased to try your new solid state relay. However, I don't have any test equipment and am not sure I'm smart enough to use it if I had access. But I am open to ideas and suggestions.
in your airplane?
physics.
In reading some of the other responses, I'd like to clarify the following: My system is a Whelen three light system with a single power pack. There have been no changes or additions to the system as it was received from the manufacturer. All bulbs and flash sequences were factory set and the cables from the power pack to the lights are factory supplied. The system is grounded at the power pack and the ground appears secure. I have seen no evidence of any other over voltage, over amperage damage to any other switches or devices. The regulator (a generic Ford regulator) seems to work as advertised. The strobe system is left on at all times and begins to operate when the master switch is turned on. In other words, the switch is rarely cycled on or off.
Posted: Wed Jan 22, 2014 11:48 am Post subject: Strobe switches |
At 10:55 AM 1/22/2014, you wrote:
Bob,
Charlie Brame
RV-6A N11CB
San Antonio
Good data. Thanks.
Understand. Were your airplane sitting at Medicine Lodge
Intergalactic Airport, there are a number of whippy
tools on my shelf that would get us the data. I've
been considering ways to craft a DAS that could be
mailed at cheap priority mail rates and be relatively
simple to operate. I think I'm close to realizing
that goal . . . you can be the first 'victim' . . .
It will let us get data from YOUR installation,
on the ground and in just a few seconds. It's
basically a 1000 samples/second storage
'oscilloscope' that records to a hard drive.
cycled on or off.
Also excellent data points.
We'll move ahead as if we know what we're
doing. Some of the goodies are coming from
overseas but I can get the relay out to
you this weekend. Shoot me your mailing
address.
As soon as you and I figure that we're doing
a good thing, we'll bicycle the rig around
and get data from as many other airplanes
as we have willing participants.
Posted: Wed Jan 22, 2014 11:52 am Post subject: Strobe switches |
Speaking of strobe switch failures, there was
a series of exchanges here on the list a few
years back where the Lister had experienced
a rash of failures . . . which produced an
understandable bad taste in his mouth for the
Carling switches.
Is that individual still on the List or does
anyone recall who it was? I would be interesting
to know how the problem resolved.
Posted: Wed Jan 22, 2014 5:39 pm Post subject: Strobe switches |
Yes I still have the problem system and would be happy to send to you.
Just let me know the address and it's on it's way. No return required.
On 1/22/2014 10:10 AM, Robert L. Nuckolls, III wrote:
<Mauledriver(at)nc.rr.com>
good numbers.
Checked by AVG - www.avg.com
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Thu Jan 23, 2014 5:57 am Post subject: Re: Strobe switches |
I am very reluctant to throw in my two cents here, as there are much greater minds than mine on this list. I figger’ that strobe power pack current characteristics may be causing switch arcing; slowly damaging the switch contact material, increasing contact resistance to the point where local heating and a snowball type failure occurs. There are quite a few different materials used for switch contacts. Depending on switch requirements and UL ratings; all contacts have their own characteristics and ability survive differing harsh environments. Ol’ tungsten lamps are similarly known for their high initial current inrush characteristics and switches require a “T” rating from UL, but these are AC switches and any arc is self extinguishing at the zero crossing point of the AC wave. DC switches are a different animal. DC switches require a quick snap action which is independent of operator manipulation.
One trick for switch survival in such instances is to use a double pole switch with both sets of contacts wired in series to double arc distance and contact separation speed. (Thank you Mr. Tibolla, wherever you are).
Again, if I were to guess, I would first suspect the initial current draw of the large strobe capacitor would be the cause. Any contact ‘bounce’ on switch closing would definitely aggravate things and hasten failure. I too would want to check the current / voltage profile of that strobe. Carling generally makes darned good switches.
_________________ Jerry King |
rene(at)felker.com Guest
Posted: Thu Jan 23, 2014 6:29 am Post subject: Strobe switches |
Jerry, thanks for your input. I learned a lot. I do not have this problem in my airplane, but a better understanding of this failure mode will help me with future projects.
Rene' Felker
N423CF
801-721-6080
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Thu Jan 23, 2014 7:07 am Post subject: Re: Strobe switches |
Here's my guess:
The only key difference in strobe supplies is their really big capacitors. When caps are flat (perhaps after long storage), their current demand is gigantic for a short time. Good design would put a peak current limiter like a CL-11 surge suppressor in the input circuit.
An O-scope would show this, but maybe only on the first start after long storage. Furthermore the test design for this is tricky because the current you are trying to capture is very high and very short.
A solid state relay, or any other relay, probably isn't the solution to the problem.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Thu Jan 23, 2014 7:44 am Post subject: Strobe switches |
I agree that some stress of this nature is in
play. A stress that seems to be unique to a
sub-set of the family of strobe products. I can't
speak to the contact style of switches pre-Carling-
rockers on the Cessnas. Without a doubt,
the mechanical features of these switches went
un-changed for decades and, perhaps, persist
to this day. Here's a breakdown of the electron-
pathway through a fast-on-tabbed Carling switch . . .
http://tinyurl.com/qcmyt4e
Keep in mind that we've seen failures across
the entire spectrum of metal-to-metal interfaces.
http://tinyurl.com/96yqmg
http://tinyurl.com/8zzkfbb
Failures of terminals are almost always a
failure to achieve gas-tight joining. Failure
of the rivet joints are probably precipitated by
degradation of the plastic housing material that
relieves mate-up pressures between the tab and
the contact-rivet. Degradation rooted in elevated
temperatures at a slowly failing junction.
Carling's demonstrated service history has
offered no incentives for folks in the airplane
business to boot them off the airplanes. At
the same time, tens of thousands of these
same switches have endured the test of time
as controls for strobe lighting systems.
Some years ago, a company that employed
my services banned a particular brand of
relay from the fleet of products . . . they
purged stock and replaced with Brand-M
based on anecdotal information that Brand-M
demonstrated a 'longer service life' in the
same abusive slot on the airplane. Brand-M
STILL stuck but only 1/3rd as often.
It took several years of P&P (play and ponder)
to finally deduce root cause . . . an effect
that was not covered in any of the relay engineering
manuals but repeated demonstrated on my workbench.
The 'fixes' I recommended based on findings
were never implemented. The failure rate had
dropped down enough to fall off the ten-worst-
problems list and the bean-counters lost
interest.
Observations of anecdotes here on the List
suggest that what ever differences
exist across the family of strobe
lighting systems, there IS a
characteristic that will bring out the
worst joint in any bus-voltage pathway to the
strobe supply. The 'worst' has manifested
mostly in failures in and around the strobe
switch. But Listers have told us that the
fast-on terminal to their fuse-block has
proven to be the weak-link that succumbed
to the ravages of whatever weapon their
strobe brought to the fight.
I think we've observed and analyzed enough
history to suggest that an investigation
into weaponry is in order. Hence my decision
to acquire tools of investigation which,
with the help of others here on the List,
may peel back the layers of the onion
and make all secrets known.
Our work here on the strobe switch failure
mystery has little to zero chance
of causing anyone to change their designs.
The best we can hope for is to identify
root cause and craft tools to identify its
recurrence so that some brands of strobes
can be avoided.
Ever hear of "too-little, too-late"? By the
time we figure this out, xenon strobes may
be on their way out of the marketplace and
the 'problem' will simply go away. But there
are simple-ideas and science to be identified
that will give foundation for any future investigation
into mysterious failures of perfectly good
switches and terminals.
Posted: Thu Jan 23, 2014 7:45 am Post subject: Strobe switches |
At 07:38 PM 1/22/2014, you wrote:
Sure.
P.O. Box 130, Medicine Lodge, Ks, 67104-0130
Thanks!
Posted: Thu Jan 23, 2014 8:06 am Post subject: Strobe switches |
At 09:07 AM 1/23/2014, you wrote:
Here's my guess:
But we've seen failures in switches that are
always left on. Initial inrush events, while
most severe, occur only at turn-on . . . what
we're seeing appears to be a manifestation of
persistent RMS heating . . . i.e. a recurring
condition during operation.
Actually, no worse that for getting
a 100w landing light lit up from a cold
start. Such inrush currents are generally
limited by ship's wiring. Here's an exemplar
plot for starting a 55W lamp.
http://tinyurl.com/mvugala
Cold resistance of the lamp was measured
at 150 mOhm, wiring added another 165
mOhm for a total of 315 mOhm and a predictable
inrush on the order of 14/.315 or 44A. If
the bulb had a monster capacitor across it
then the absolute max inrush would still
be limited by a/c wiring to 14/.165 or
84A.
This is in the ballpark for expected tungsten
lamp inrush values cited when switches are
rated in the lab. Ratings that assume the
system integrator expects a service life in
the thousands of cycles.
We're witnessing failures in under 1000
cycles . . . perhaps as few as 200 cycles.
The failures include devices that don't have
to switch . . . only carry the load.
It may be that initial inrush is a factor
but I'm guessing it's not the dominate
effect. The fact that many strobe systems
do not exhibit the problem while one
system can duplicate the problem several
times suggests that root cause can be
chased down by comparing problem children
with well behaved children . . .
to the problem.
A solid state relay will eliminate the failures
with roots in contact resistance . . . but there
are other metal-to-metal joints at risk. You're right,
there's more going on here than can be explained
by failure to observe switch ratings from the
catalogs.
Posted: Tue Jan 28, 2014 5:03 am Post subject: Strobe switches |
At 09:44 AM 1/23/2014, you wrote:
Sure.
I received Bill's strobe supply and began
to research its pedigree. Seems to be a custom
device designed for Creativair (now defunct)
and manufactured by Nova.
The nameplate says 10-30 volts input
which speaks to a modern, switchmode
power supply topology. It also says
70 watts in, 60 watts out and input
current of 5.5A.
Of course, that 5.5A figure is accurate
only at the bus voltage where 70 watts
of demand is satisfied or 70/5.5=12.7
volts. At a bus voltage of 14 volts or
more, input current would be expected to
fall to about 5A. IN a 28v airplane, the
current would be about half that.
Bill says he supplied this device through
a 7A fuse which held solid while other
devices in the supply line were less
happy about the nature of demands on
their capabilities.
We would probably do well to compile
a listing of switch/terminal failures
in strobe systems.
Bill, would you repeat your narrative
of what items in your strobe supply path
failed . . . along with your best guess
as to the epicenter of the failures?
How many instances did you experience
before you replaced the power supply?
FisherPaulA(at)johndeere. Guest
Posted: Tue Jan 28, 2014 5:59 am Post subject: Strobe switches |
If this is the "AVI-PAK" sold by CreativAir, then I have one too. Mine has been in service for about 3.5 years (300+ flight hours) and I haven't noticed any problems... so far! Last inspection was in July, and as soon as it warms up a little, I'll inspect all of the connections again just to be sure nothing is sneaking up on me.
I'd be very interested in any analysis of this device and what, if anything, we can do to prevent re-occurrence of this issue.
Paul A. Fisher
RV-7A N18PF
Posted: Tue Jan 28, 2014 8:35 am Post subject: Strobe switches |
At 07:58 AM 1/28/2014, you wrote:
<FisherPaulA(at)johndeere.com>
sneaking up on me.
Good idea. I'd also like to 'bicycle' the DAS
system to you and get some data off your
as-installed system.
Posted: Tue Jan 28, 2014 8:55 am Post subject: Strobe switches |
Absolutely. Happy to help.
- Paul
Do not archive.
