Flat tire on landing
Dan Wilde
PostPosted: Mon Jan 20, 2014 2:21 pm    Post subject: Flat tire on landing Reply with quote
Yesterday I went for a pleasant flight and landed at two airports before
heading home to my dirt/grass strip. I landed fine and continued
taxiing to my shop. The longer I taxied the more power I needed. I
knew right away that the tire must have gone flat but since it was only
a few feet to my shop I finished moving it before stopping. The tire
was totally flat but I think that if I had needed to, I could have taken
off and landed safely on the flat tire. Has anyone had to do this?
Because I have had trouble in the past removing the tire from the wheel,
I went to Harbor Fright and purchased a bead breaker for $49.99. This
was one of the best investments I have ever made. The tire was off the
rim if less than 5 minutes. In the past using just hand tools, I had
struggled for 3 hours to get the tire off the rim. Typically the
quality of tools from there is marginal but since I will only use this
once in a great while, it should last and at this price I could not resist.
Dan
randy(at)rjhebertassoc.co
PostPosted: Mon Jan 20, 2014 2:36 pm    Post subject: Flat tire on landing Reply with quote
Dan I too bought the bead breaker from HF. It came in very handy since my
local repair shop charged $25 to fix the first flat.
I did the second one and it is working fine.
I haven't tried to T.O. or land with the flat.
Do you have tubes or tubeless?
I had two flats with the tubes that came with the wheels from Zenith.
My shop ordered two new tubes for me and they seem to be much better. The
next time I get a flat I will convert to tubeless though.
Randall J. Hebert
N7701P
frank goodnight
PostPosted: Mon Jan 20, 2014 2:37 pm    Post subject: Flat tire on landing Reply with quote
Dan
Never did it in my 701, but landed
With a flat tire 2 times in my kolb, both times I din't even know the tire was flat
Until I had slowed down to almost
Walking speed. However once stoped
I could not get started again,had to fix
It where it set.don't know if you could
Get a 701 moving again
Frank
On Jan 20, 2014, at 4:20 PM, Dan Wilde <stolpilot.wilde(at)gmail.com> wrote:
Yesterday I went for a pleasant flight and landed at two airports before heading home to my dirt/grass strip. I landed fine and continued taxiing to my shop. The longer I taxied the more power I needed. I knew right away that the tire must have gone flat but since it was only a few feet to my shop I finished moving it before stopping. The tire was totally flat but I think that if I had needed to, I could have taken off and landed safely on the flat tire. Has anyone had to do this?
Because I have had trouble in the past removing the tire from the wheel, I went to Harbor Fright and purchased a bead breaker for $49.99. This was one of the best investments I have ever made. The tire was off the rim if less than 5 minutes. In the past using just hand tools, I had struggled for 3 hours to get the tire off the rim. Typically the quality of tools from there is marginal but since I will only use this once in a great while, it should last and at this price I could not resist.
Dan
Dan Wilde
PostPosted: Mon Jan 20, 2014 2:47 pm    Post subject: Flat tire on landing Reply with quote
Randall J. Hebert
N7701P
I am running tubeless.
Dan
frank goodnight
PostPosted: Mon Jan 20, 2014 2:49 pm    Post subject: Flat tire on landing Reply with quote
Randel,
I have the tubeless tires that came
With my 701 kit-- pretty but I have to air them up about every 2 or 3 weeks.
Not much of a problem but i plan to put tubes in them the weather gets better.
Frank
On Jan 20, 2014, at 4:36 PM, "Randall Hebert" <randy(at)rjhebertassoc.com> wrote:
Randall J. Hebert
N7701P
dougsnash
PostPosted: Mon Jan 20, 2014 3:32 pm    Post subject: Flat tire on landing Reply with quote
For those who are having trouble with the Matco tubeless tires leaking air at the split rim, I have found that if you coat the o-ring at the split in the rim with spray lithium grease the leaks go away. Might be worth spraying the o-rings the next time you have you wheels apart.
When I first installed the nose wheel on my 701 I had a slow leak which flattened the tire over the course of a couple of weeks. The spray grease on the o-ring fixed it right up. After greasing all of my wheel o-rings I might put a little air in my tires once a year (three frigid Canadian winters later).
Doug M
CH 701 in NW Ontario, Canada
On Monday, January 20, 2014 4:54:13 PM, Frank <frank.goodnight(at)att.net> wrote:
--> Zenith701801-List message posted by: Frank <frank.goodnight(at)att.net (frank.goodnight(at)att.net)>
Randel,
Frank
On Jan 20, 2014, at 4:36 PM, "Randall Hebert" <randy(at)rjhebertassoc.com (randy(at)rjhebertassoc.com)> wrote:
[quote] --> Zenith701801-List message posted by: "Randall Hebert" <randy(at)rjhebertassoc.com (randy(at)rjhebertassoc.com)>
Randall J. Hebert
N7701P
frank goodnight
PostPosted: Mon Jan 20, 2014 3:37 pm    Post subject: Flat tire on landing Reply with quote
Thanks for the info Doug.
I'll try it. Saves weight and money
Frank
On Jan 20, 2014, at 5:32 PM, MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)> wrote:
[quote]For those who are having trouble with the Matco tubeless tires leaking air at the split rim, I have found that if you coat the o-ring at the split in the rim with spray lithium grease the leaks go away. Might be worth spraying the o-rings the next time you have you wheels apart.
Doug M
On Monday, January 20, 2014 4:54:13 PM, Frank <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
Randel,
Frank
Randall J. Hebert
N7701P
akkeystone@gmail.com
PostPosted: Tue Jan 21, 2014 8:03 am    Post subject: Flat tire on landing Reply with quote
I too had a flat tire on landing.  I had just switched from the 800 tires that came with the kit to 850's.  I was landing on a short gravel bar in "Hells Hole", named by boaters who got in trouble there.  I ended up in the creek because I could not keep the plane straight even with the other wheel was skidding.  The creek was only 1' deep.  I had a heck of a time getting the plane back up on to the gravel bar!  I stuffed the tire full of sea weed but still had lots of trouble (full power,one person pushing and heavy stuff tied to the other tie down ring.  I could not get the plane high enough to get above high tide.  The wheels and breaks got wet that night.  The next day a friend flew in a new tube.  In a couple of hours I was back home.  Shortly thereafter I got rid of the tubes with the funky stems that came out the center and installed regular tubes through a new hole in the side of the rim.  No problems since and that was 5 or 6 years ago.
Bill Wilcox
Soldotna AK summer
Casa Grande AZ winter
N801BW
800 hrs
In the hanger for the witner
