LeastDrag93066(at)aol.com Guest
Posted: Thu Jun 22, 2006 9:47 am Post subject: Are Coax (RG ?) really sheilded? |
Hi All,
Someone on this list must know the real answer to this question.
Is a coax cable a shielded cable?
My thinking:
A twisted pair of conductors inside a braided shield grounded at one end
would be a reasonable definition for a shielded cable.
A coax cable is a center conductor (power/signal) with an outer braided
conductor grounded at both ends.
The outer braid would provide some shielding of the inner conductor.
However, it seems to me that the outer braided conductor would couple with
any AC power source and induce this into the ground side of the signal.
I seem to remember good things to do.
Like running the coax by itself.
And always crossing a coax at right angles across other wire runs.
But I'm still learning, so please help me.
Jim Ayers
Posted: Thu Jun 22, 2006 10:17 am Post subject: Are Coax (RG ?) really sheilded? |
LeastDrag93066(at)aol.com wrote:
Hi All,
Is this a trick question??? 'coax' is short for co-axial, meaning that
one conductor surrounds the other with a dielectric medium to keep them
separated. You COULD think of coax as being a single shielded wire, but
certainly coax is more than that.
| Quote: | My thinking:
My thinking too. The twisting is done to 'cancel' induced signals from
one conductor to the other. Take my word for it. It's too complicated
for me to explain ..... even if I really did remember it all!!!
| Quote: | A coax cable is a center conductor (power/signal) with an outer braided
Only if YOU ground the braid. Sometimes the braid is 'floating', or
ungrounded, grounded at one end only (prevents current flow in ground
loops) or grounded at both ends. It all depends on the application.
| Quote: | The outer braid would provide some shielding of the inner conductor.
This is a typical application for coax. The shield keeps the
'offensive' signal (doesn't have to be AC, it can still be pulsed or
varying DC etc.) from being inductively coupled to the inner conductor.
It also keeps the signals on the inner conductor from being inductively
coupled to their neighbor.
| Quote: | I seem to remember good things to do.
In a theroetical world, those are two good things. However, in the real
world (well, depending on the application, of course) these aren't
always practical solutions. The signal levels we're going to encounter
aren't usually high enough to cause major problems ...... as long as
everything stays normal.
The reason I said that, it's possible for alternator whine (that's AC on
the battery + buss caused by failing diodes in the alternator) to be
coupled into the audio inputs, or even into the internal amplifier
circuitry, be amplified and appear in your headsets and in your
transmitted audio. Same is true of ignition noise.
| Quote: | But I'm still learning, so please help me.
Ah, aren't we all????
Linn
Jim Ayers
Erich_Weaver(at)URSCorp.c Guest
Posted: Thu Jun 22, 2006 2:56 pm Post subject: Are Coax (RG ?) really sheilded? |
yes, coax is shielded. Contrary to common opinion however, shielding is of
no use for preventing interference from inductive coupling. High current
in a wire adjacent to coax can still present a problem. Coax IS good at
preventing electrostatic interference. Venture over to the aero-electric
list or get a copy of the Aero-Electric Connection from Bob Nuckols to get
the full skinny.
Erich Weaver
n320wt(at)yahoo.com Guest
Posted: Thu Jun 22, 2006 4:29 pm Post subject: Are Coax (RG ?) really sheilded? |
Jim, It's simple enough to understand as it applies to aircraft construction. Coax is used for RF connections to carry radio signals between radios and antennas. Shielded wire is for any thing that could create noise like the alternator or power to a strobe power supply. Shielded twisted pair is for signaling sources where data is being used such as communication for an EFIS installion. I also use twisted 2 and 3 conductor for the headphone and mike jack wiring. I was a comm/nav systems specialist on C-130-H for the WVANG in a former life.Hope this helps.
BRIAN ALLEY (N320WT)
CARBON FIBER COMPOSITES
101 Caroline Circle
Hurricane, WV 25526
www.carbonfibercomposites.net
304-562-6800 home
304-395-4932 cell
How are you going to win by a nose if you don't stick out your neck?
