thexporter
Posted: Sat Mar 21, 2009 3:49 pm Post subject: Center of Gravity - CG |
Afternoon Everyone:
We are at a point on our restoration efforts of an L-29 to weight it and calculate the CG.
I have a major problem, I can not find in any of my manuals a CG chart or datum.
Any advise or info would be very appreciated.
Dennis Mitchell
Houston Texas
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
delfin(at)mail.pf Guest
Posted: Sat Mar 21, 2009 5:35 pm Post subject: Center of Gravity - CG |
You have something in L29 Maintenance Handbook, weighting procedures ([url=http://www.l-29.org/6.htm)]http://www.l-29.org/6.htm)[/url]I have also this documents if it can help
Jean de Roubin
[img]cid:DA1C7150-A69F-4D89-A90E-95391A077DAC[/img][img]cid:D8206D7D-0723-416E-B071-E090D0381230[/img]
Le 21 mars 09 à 13:49, thexporter a écrit :
| Quote: | --> L29-List message posted by: "thexporter" <thexporter(at)earthlink.net (thexporter(at)earthlink.net)>
Afternoon Everyone:
Dennis Mitchell
Houston Texas
http://forums.matronics.com/viewtopic.php?p=235557#235557
- The L29-List --> &n========================<b - &nbs --> ========================
389.04 KB |
21837 Time(s) |
278.39 KB |
21837 Time(s) |
thexporter
Posted: Sun Mar 22, 2009 4:22 am Post subject: Re: Center of Gravity - CG |
Dear Mr. Jean de Roubin
Thank you very much for the diagram, my French is very lacking but with the Internet I can translate what I need very easily and solve the mystery.
I really appreciate you taking the time to post this information for me.
Respectfully,
Dennis
Posted: Sun Mar 22, 2009 12:02 pm Post subject: Center of Gravity - CG |
My pleasure !
So long !
Jean
Le 22 mars 09 à 02:22, thexporter a écrit :
<thexporter(at)earthlink.net>
the mystery.
me.
Respectfully,
Dennis
http://forums.matronics.com/viewtopic.php?p 35608#235608
SD737(at)aol.com Guest
Posted: Sun Mar 22, 2009 3:47 pm Post subject: Center of Gravity - CG |
Anyone out there need a complete set of L-29 Manuals? Aircraft and flight....
If so contact me directly (offline)
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
thexporter
Posted: Tue Mar 31, 2009 4:43 pm Post subject: Re: Center of Gravity - CG |
Everyone can get a free copy of the manuals via;
http://www.l-29.org/6.html
Thanks to there efforts to support the L-29 group.
BUT, if your offering a better quality English version of the manuals in a .PDF format or paper I'm interested.
My Engine manual (M701) is very difficult to read.
ershire
Posted: Thu Jan 16, 2014 1:54 pm Post subject: Re: Center of Gravity - CG |
What is the typical ballast required if any in the nose?
delfin29(at)me.com Guest
Posted: Thu Jan 16, 2014 2:07 pm Post subject: Center of Gravity - CG |
If you means weight in the nose, typically nothing. Maybe, if the IFF in out, same weight as the IFF.
I have a air compressor at place of IFF on my L29, so it have the same weight, plus or minus.
Jean de Roubin
Dawg
Posted: Thu Jan 16, 2014 2:45 pm Post subject: Center of Gravity - CG |
What have you removed from the airplane? I removed 400+ pounds of junk so I added 103 pounds in the nose.
On Jan 16, 2014, at 16:07, delfin29(at)me.com wrote:
Jean de Roubin
> http://forums.matronics.com/viewtopic.php?p=417032#417032
_________________ Dawg |
ershire
Posted: Thu Jan 16, 2014 3:02 pm Post subject: Center of Gravity - CG |
Exactly, I too have 103lbs in the nose. My empty weight is 5193. How does that compare? On Jan 16, 2014 5:46 PM, "Bill Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote] --> L29-List message posted by: Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
On Jan 16, 2014, at 16:07, delfin29(at)me.com (delfin29(at)me.com) wrote:
> --> L29-List message posted by: delfin29(at)me.com (delfin29(at)me.com)
> Jean de Roubin
> Le 16 janv. 2014 à 21:54, ershire <jonairway(at)gmail.com (jonairway(at)gmail.com)> a écrit :
>> --> L29-List message posted by: "ershire" <jonairway(at)gmail.com (jonairway(at)gmail.com)>
rget="_blank">http://www.matronics.com/Navigator?L29-List
le, List Admin.
tr.9(at)westnet.com.au Guest
Posted: Thu Jan 16, 2014 3:07 pm Post subject: Center of Gravity - CG |
There are some weights in the tail too isn't there Bill?
BTW, have you had your tail section off lately?
Frank
On Jan 16, 2014, at 2:48 PM, Bill Geipel <l129bs(at)gmail.com> wrote:
> Jean de Roubin
ershire
Posted: Thu Jan 16, 2014 3:14 pm Post subject: Center of Gravity - CG |
The weights are out of the tail and the tail was off in September for annual. On Jan 16, 2014 6:08 PM, "Frank Deeth" <tr.9(at)westnet.com.au (tr.9(at)westnet.com.au)> wrote:[quote] --> L29-List message posted by: Frank Deeth <tr.9(at)westnet.com.au (tr.9(at)westnet.com.au)>
Frank
On Jan 16, 2014, at 2:48 PM, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
>> Jean de Roubin
>>> Read this topic online here:
le, List Admin.
Posted: Thu Jan 16, 2014 3:48 pm Post subject: Center of Gravity - CG |
About how much weight was in the tail?
Frank
On 16 Jan 2014, at 3:02 pm, Jon S <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:
Exactly, I too have 103lbs in the nose. My empty weight is 5193. How does that compare? On Jan 16, 2014 5:46 PM, "Bill Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote: | Quote: | --> L29-List message posted by: Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
> Jean de Roubin
le, List Admin.
ist"">http://www.matronics.com/Navigator?L29-List
Posted: Thu Jan 16, 2014 4:53 pm Post subject: Center of Gravity - CG |
All radios and nav (radiocompass) were removed. Modern ones instead. As most is in the middle, it does not affect much center of gravity. As I have an air compressor in the nose right, place of IFF, my plane was weighted and is well balanced without any weight in the nose or in the the tail.
My empty weight is 5193 lbs with 28,85 % MAC.
Center of gravity should be beetween 20,5% and 25,5% MAC in flight (flight manual 5.
It flies like this from many years and goes out of stalls and spins without any problems.
Jean de Roubin
Le 16 janv. 2014 à 22:48, Bill Geipel <l129bs(at)gmail.com> a écrit :
> Jean de Roubin
Dawg
Posted: Thu Jan 16, 2014 5:24 pm Post subject: Center of Gravity - CG |
4995 empty weight.
On Jan 16, 2014, at 17:02, Jon S <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:
> Jean de Roubin
le, List Admin.
cs.com
Dawg
Posted: Thu Jan 16, 2014 5:25 pm Post subject: Center of Gravity - CG |
17 pounds in the tail. Steel plates.
Actually haven't even seen my jet since July and then only in passing.
Hang in there.
On Jan 16, 2014, at 17:07, Frank Deeth <tr.9(at)westnet.com.au> wrote:
Frank
>> Jean de Roubin
jorgen.nielsen(at)mweb.co Guest
Posted: Thu Jan 16, 2014 10:24 pm Post subject: Center of Gravity - CG |
Hi Bill
Does yours not have the viper motor?
Hang in there.
> Cheers,
> Frank
> Sent from my iPad
>>> Jean de Roubin
Dawg
Posted: Fri Jan 17, 2014 5:23 pm Post subject: Center of Gravity - CG |
It does. Before I put the viper in, I removed 453 pounds and put in the 105 of weight in the nose.
The viper weights the same but sits about 15" aft of the 501. But since I've gained weight in my old age it still flys nice.
On Jan 17, 2014, at 0:23, Jorgen Nielsen <jorgen.nielsen(at)mweb.co.za> wrote:
Hi Bill
> Hang in there.
> Bill
>> Cheers,
>> Frank
>> Sent from my iPad
>>>> Jean de Roubin
ershire
Posted: Fri Jan 17, 2014 5:37 pm Post subject: Center of Gravity - CG |
My jet is not slow, just overweight. On Jan 17, 2014 8:24 PM, "Bill Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote] --> L29-List message posted by: Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
On Jan 17, 2014, at 0:23, Jorgen Nielsen <jorgen.nielsen(at)mweb.co.za (jorgen.nielsen(at)mweb.co.za)> wrote:
> --> L29-List message posted by: Jorgen Nielsen <jorgen.nielsen(at)mweb.co.za (jorgen.nielsen(at)mweb.co.za)>
> Hi Bill
> Sent from my iPad
>> On 17 Jan 2014, at 3:28, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
>> Hang in there.
>> Bill
>>> On Jan 16, 2014, at 17:07, Frank Deeth <tr.9(at)westnet.com.au (tr.9(at)westnet.com.au)> wrote:
>>> Cheers,
>>> Frank
>>> Sent from my iPad
>>>>> Jean de Roubin
le, List Admin.
Dawg
Posted: Fri Jan 17, 2014 5:55 pm Post subject: Center of Gravity - CG |
But still fun.
On Jan 17, 2014, at 19:36, Jon S <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:
My jet is not slow, just overweight. On Jan 17, 2014 8:24 PM, "Bill Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote: | Quote: | --> L29-List message posted by: Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
> Hi Bill
> Sent from my iPad
>> Hang in there.
>> Bill
>>> Cheers,
>>> Frank
>>> Sent from my iPad
>>>>> Jean de Roubin
le, List Admin.
cs.com
