bob88
Posted: Wed Jan 15, 2014 9:48 am Post subject: Placement of phone jacks for back seats |
Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent?
Posted: Wed Jan 15, 2014 9:57 am Post subject: Placement of phone jacks for back seats |
I mounted my headset jacks on the tunnel covers between the seats. The
headsets will hang on my overhead plenum out of the way of people
boarding/exiting the plane. No charging ports though!!!
Linn
On 1/15/2014 12:48 PM, bob88 wrote:
rv10flyer(at)live.com Guest
Posted: Wed Jan 15, 2014 10:02 am Post subject: Placement of phone jacks for back seats |
whats wrong with the back seat vent areas? probably the best in my mind.
I put a aux jack (which I have yet to use) below one of the seats, would do
the same for a USB.
The hot tunnel top would really be the only other area to put headset jacks
and connections for easy access. the side panels below the vents is the best
for routing and connections. If it’s a tripping over them issue, move the
headset onto the seats. I have yet to have an issue with my 5yr old and
older passengers, when I move the headset into the corner and have the
passengers pull the headset from that area. Having it in the center would
cause issues in flight as we are moving things all over that area (food,
books, etc) from back to front and back.
Posted: Wed Jan 15, 2014 10:09 am Post subject: Placement of phone jacks for back seats |
I fabricated a vertical plate below the vent. Not as subject to being
damaged. Allows padded armrest extending along the full horizontal shelf.
I'm going to down to the plane now - I'll try to remember to take a pic
or two.
B
Posted: Wed Jan 15, 2014 10:15 am Post subject: Placement of phone jacks for back seats |
I installed mine on the flap rod covers, each side mounted close to the
tunnel side of each cover, one plug over the other. My thought was to not
have the jacks such that the headphone wires would pass over their laps or
get tangled if they tried to get out with the headphones still on. This is
also an easy place to route the connection wires via the tunnel.
Never had a rear seat passenger needing to charge anything. If on rare
instance I do I'll just have them use the panel jack.
Carl
Tim Olson
Posted: Wed Jan 15, 2014 11:43 am Post subject: Placement of phone jacks for back seats |
You must not carry kids (re the charging)....we use
the back seat charging ports all the time.
Tim
On 1/15/2014 12:15 PM, Carl Froehlich wrote:
Carl
rleffler
Posted: Wed Jan 15, 2014 11:55 am Post subject: Placement of phone jacks for back seats |
Mine are on the rear of the Aerosport Products center arm console.
http://forums.matronics.com/viewtopic.php?p=416944#416944
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
Posted: Wed Jan 15, 2014 11:56 am Post subject: Placement of phone jacks for back seats |
So there was a thread, probably on Aeroelectric, regarding USB ports.
As I recall it was never brought to a conclusion.
What are y'all using for USB charging ports?
I have a cigarette port poorly located but I'd love to install a USB
port or two.
On 1/15/2014 2:40 PM, Tim Olson wrote:
Tim
cooprv7(at)yahoo.com Guest
Posted: Wed Jan 15, 2014 12:45 pm Post subject: Placement of phone jacks for back seats |
Having built my RV-10 long before I recognized the need for a USB port, I just bought a cigarette plug adapter that has two cigarette plugs and two USB ports, one with 2.1 amps for the mighty iPad. Purchased it on Amazon and it works great. Not to helpful for the folks in back though unless you have a long cord or another jack in the back.
Marcus
On Jan 15, 2014, at 2:55 PM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
So there was a thread, probably on Aeroelectric, regarding USB ports. As I recall it was never brought to a conclusion.
I have a cigarette port poorly located but I'd love to install a USB port or two.
Tim
jeff(at)westcottpress.com Guest
Stein sells these...
On Jan 15, 2014, at 11:55 AM, Bill Watson wrote:
> Tim
134.07 KB |
16176 Time(s) |
119.04 KB |
16176 Time(s) |
dave.saylor.aircrafters(a Guest
Posted: Wed Jan 15, 2014 12:54 pm Post subject: Placement of phone jacks for back seats |
Our headset jacks are in a panel below the vent. Â The panel extends from the diagonal brace above it.
FWIW I wired the back seat music input with a 24" wire/1/8" plug (not a jack) so the kids can plug their stuff in and I don't have to keep track of a patch cord. Â It exits from inside a pocket so I just coil it up and leave in there when not in use.
Dave Saylor
[url=tel:831-750-0284]831-750-0284[/url] CL
On Wed, Jan 15, 2014 at 9:48 AM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
[quote] --> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
Posted: Wed Jan 15, 2014 1:20 pm Post subject: Placement of phone jacks for back seats |
Nice, looks like Stein has several USB options.
Marcus
On Jan 15, 2014, at 3:43 PM, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
Stein sells these...<photo.JPG><photo.JPG>
hotwheels
Posted: Wed Jan 15, 2014 2:14 pm Post subject: Re: Placement of phone jacks for back seats |
Mounted mine in the overhead. Seems to be a good location so far.
1.32 MB |
16169 Time(s) |
aerosport1
Posted: Wed Jan 15, 2014 2:38 pm Post subject: Placement of phone jacks for back seats |
If you have a center armrest front inside and the rear passengers on the
back side. It keeps all the wiring
In the center. Also less likely to catch them on their feet when getting out
of the
Airplane. Charge jacks and music inputs work great there as well.
FWIW
Geoff Combs
296.55 KB |
16166 Time(s) |
1.25 MB |
16166 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Dick Sipp
Posted: Wed Jan 15, 2014 7:08 pm Post subject: Placement of phone jacks for back seats |
I put mine (head sets only) on the seat back support. Seems like a bad
place at first but most of the people I have in the back are other than
family so I usually end up assisting them in getting strapped in. All the
cords are out of the way, works good for me.
Dick Sipp
rv10rob(at)gmail.com Guest
Posted: Thu Jan 16, 2014 8:18 am Post subject: Placement of phone jacks for back seats |
+1 on back seat support. Looks like this: http://kochman.smugmug.com/RV-10/Trips/2013-Cross-Country-Trip/i-7DXQJ82/0/M/2013-05-25%2009.44.15-M.jpg. Downside is that I couldn't easily install the cover for the back seat support that came with my Flightline interior. I don't really miss it, though.
On USB charging ports, I'm a big fan of installing cigarette lighter ports if you can, then using a low-profile USB charger that plugs in. That way, if it ever breaks, it's super-easy to replace.
On Wed, Jan 15, 2014 at 7:07 PM, Dick & Vicki Sipp <rsipp(at)earthlink.net (rsipp(at)earthlink.net)> wrote:
[quote]--> RV10-List message posted by: "Dick & Vicki Sipp" <rsipp(at)earthlink.net (rsipp(at)earthlink.net)>
I put mine (head sets only) on the seat back support. Seems like a bad place at first but most of the people I have in the back are other than family so I usually end up assisting them in getting strapped in. All the cords are out of the way, works good for me.
Dick Sipp
