CH-701 Fuel Level Sender
pdelano(at)telus.net
PostPosted: Sun Jan 12, 2014 2:22 pm    Post subject: CH-701 Fuel Level Sender Reply with quote
Hi all,
Is there a reason Zenith changed from putting the fuel sender on top to putting it on the inboard side of the fuel tank. Just want to be sure before I cut that hole.
Perry
dougsnash
PostPosted: Sun Jan 12, 2014 6:42 pm    Post subject: CH-701 Fuel Level Sender Reply with quote
Clearance issues on the top; there would end up being a bulge in the top skin to clear the sending units.
I did my senders on the sides of the tanks on my 701 and have had no issues with leaks. We had some minor issues with the 750 I helped on and it turned out we just needed more thread sealant on the screws. Once we re-coated the screws there have been no more leakage issues.
Generally speaking, the side mounted senders are not a problem if installed according to plans.
Doug M
On Sunday, January 12, 2014 4:27:34 PM, Perry Delano <pdelano(at)telus.net> wrote:
Hi all,
Perry
http://www.matro====================
PostPosted: Sun Jan 12, 2014 8:27 pm    Post subject: CH-701 Fuel Level Sender Reply with quote
Doug,
Thanks.
Perry
Sent wirelessly from my BlackBerry device on the Bell network.
Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de Bell.
