Bulkhead Material
tonyrenshaw268(at)gmail.c
PostPosted: Wed Jan 08, 2014 3:30 am    Post subject: Bulkhead Material Reply with quote
Hi,
Can someone please remind me of the name of a material I can buy from ACS that can be used as a substrate for a small reinforcement bulkhead within a wing fairing? I don't mean foam, if someone with a sense of humour might suggest, but something cloth on both sides will stick to,well,,and ideally is only 1/8-1/4" in thickness. Thanks in anticipation.
Tony Renshaw.
P.S. It's just dawned on me, we have used balsa as such a medium, but I think there is a purpose specific board.
craigb(at)onthenet.com.au
PostPosted: Wed Jan 08, 2014 1:25 pm    Post subject: Bulkhead Material Reply with quote
How about flex core, it’s the stuff used to make the rear bulkhead, as you already said balsa wood will bond well too and you can shape it easily
craig
rlborger(at)mac.com
PostPosted: Wed Jan 08, 2014 7:41 pm    Post subject: Bulkhead Material Reply with quote
Tony,
Polyurethane rigid foam sheet is usually what is used for bulkheads, etc. Probably 1/8 or 1/4 inch thick. It is extremely easy to shape with hand tools (saw, knife, abrasives, etc.), but do not hot-wire as it produces cyanide gas when vaporized.
If you can not get the thickness material you need from ACS, you can try McMaster-Carr. Shipping weight for the material isn’t an issue but packaging bulk is.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Jan 8, 2014, at 5:29 AM, Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)> wrote:
Hi,
Can someone please remind me of the name of a material I can buy from ACS that can be used as a substrate for a small reinforcement bulkhead within a wing fairing? I don't mean foam, if someone with a sense of humour might suggest, but something cloth on both sides will stick to,well,,and ideally is only 1/8-1/4" in thickness.Thanks in anticipation.
Tony Renshaw.
PostPosted: Wed Jan 08, 2014 8:05 pm    Post subject: Bulkhead Material Reply with quote
Thanks for the tips. I’ll try not to poison myself ;-)Tony R
On 9 Jan 2014, at 1:39 pm, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
[quote]Tony,
Hi,
Tony Renshaw.
href="http://www.aeroelectric.com/">www.aeroelectric.com
href="http://www.buildersbooks.com/">www.buildersbooks.com
href="http://www.homebuilthelp.com/">www.homebuilthelp.com
href="http://www.mypilotstore.com/">www.mypilotstore.com
href="http://www.mrrace.com/">www.mrrace.com
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
grahamsingleton(at)btinte
PostPosted: Thu Jan 09, 2014 3:58 am    Post subject: Bulkhead Material Reply with quote
Tony
not sure what you are trying to achieve. I always made the fairings press lightly against the fuselage
so that there was no gap, and made them flexible enough to move with the bending of the wing.
Also filled the fuslage around the edges of the fillets to give a smooth transition from fillet
to fuselage.
Graham
To: europa-list(at)matronics.com; Bob Borger <rlborger(at)mac.com>
Sent: Thursday, 9 January 2014, 4:04
Subject: Re: Bulkhead Material
Tony,
Hi,
Tony Renshaw.
* AeroElectric www.homebui= * Race Consulting http://www.matronics.com/cont-========================f="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.c========================
" target="_blank" href="http://forums.matronics.com/">http://forums.mat===================
 Filesize:  50.5 KB
 Viewed:  2820 Time(s)
asarangan(at)gmail.com
PostPosted: Fri Jan 10, 2014 2:51 pm    Post subject: Bulkhead Material Reply with quote
Tony
Why are you averse to foam? Lastafoam (I believe is polyurethane)
0.2inch thick should work well for this. Aircraftspruce has it for $36
for a big sheet.
On Wed, Jan 8, 2014 at 6:29 AM, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Hi,
Tony Renshaw.
