genie(at)swissmail.org Guest
Posted: Mon Jan 06, 2014 1:22 pm Post subject: MTOW of RV-6 with Lycoming O-320-D3G and 79" Sensenich Fixe |
Does anyone have a Pilot's Operating Handbook which shows the take-off
weights of an RV-6 with a Lycoming O-320-D3G engine and a 79" Sensenich
Fixed Pitch Metal Propeller? I need these to justify to the aviation
administration an increase in the take-off weight of my RV-6. At present
it is rated at 726 kg which is equal to 1600 lbs. Based on my aircraft's
performance at this weight I find that an increase in MTOW would be
appropriate.
Thank you.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
n146wb(at)cfu.net Guest
Posted: Mon Jan 06, 2014 2:38 pm Post subject: MTOW of RV-6 with Lycoming O-320-D3G and 79" Sensenich Fixe |
Van's originally specified 1600 lb gross for the RV-6, increased it to 1650 for the RV-6A. During the inspection of my RV-6 I called Van's and let the DAR talk to them. They said they would approve 1650 so that's what mine is rated for. I haven't followed what's happened with Van's specs since. The above happened in 2007 and it meant the difference between just carrying two people and carrying two people with some luggage.
Warren
Quote: | On Jan 6, 2014, at 3:21 PM, George Nielsen <genie(at)swissmail.org> wrote:
Does anyone have a Pilot's Operating Handbook which shows the take-off weights of an RV-6 with a Lycoming O-320-D3G engine and a 79" Sensenich Fixed Pitch Metal Propeller? I need these to justify to the aviation administration an increase in the take-off weight of my RV-6. At present it is rated at 726 kg which is equal to 1600 lbs. Based on my aircraft's performance at this weight I find that an increase in MTOW would be appropriate.
Thank you.
George Nielsen
RV-6 PH-XGN
