Posted: Sun Jan 05, 2014 10:32 am Post subject: Wiring Verification |
Hi Bob,
I attended one of your seminars in Nashville, TN some years ago as well as purchased a second updated copy of your book which I refer to often. However, not being an electrical engineer, I'd like to verify my wing rewiring plan for my 12 volt all metal Luscombe if possible.
Hi Ron . . . it's been some time! I'm sure we can sort
out your concerns . . .
The wing run is approximately 16 feet to the wing root from the wing tip, 14 feet from the landing light to wing root, and another 6+ feet to the switches on each side from the wing root. I plan to install a disconnect of some sort at each wing root to allow for an uncomplicated removal of the wing. Also, by the way, I will be installing a Plane Power Alternator and a B&C Starter in this rebuild if that should make any difference.
I am wiring an Aeroflash power supply, (1.8 amp-23.4 watts) in each wingtip . . .
Okay, a power wire coming in from each load to join at the
panel switch for STROBES. 4A total load with half carried
by the individual wires. I would recommend 20AWG for these
conductors . . . not so much for electrical capability but
for mechanical robustness. The difference in weight has
no demonstrable down-side . . .
piggybacking onto my 26 watt Whelen position lights,
. . . again, 20AWG conductors to each fixture brought
all the way to the POSITION LTS switch.
and a 100 watt landing light in each wing.
These are about 8A each. Is one adjusted for taxi illumination
with the other directed for landing?
Suggest 16AWG wire to each fixture. Control each with
its own switch.
I plan to switch to LED landing lights in the future but not anytime soon. My plan is to run three wires adjacent to one another up to the landing light where they will divide and separate. They will not run in a conduit but will run bundled only by a periodic small wedge clamp through the wing leading edge. I am utilizing Tefzel 22759 wire.
Use the same wires and switches for the LED fixtures.
There is no sin in having wires that are 'too heavy' . . .
only in having wires that are 'too light'.
I have determined the plan through my mathmatical calculations utilizing your book. To be on the safe side, I expect to be using a 16 gauge wire for my power supply and position lights and a 14 gauge wire for my landing lights. None of these wires are to be shielded at this point. Aeroflash indicated that if the power supply was mounted in the wing tip, it was unnecessary to utilize a shielded wire in the run. I do not know if I need shielding on the landing lights and need your advice.
The 20AWG wire is 10 milliohms per foot. Your proposed
20-foot runs to the nav and strobe lights offers a
.010 x 20 x 2 = .4 volt drop in each segment for
3% in your 14-volt system. Entirely within practical guidelines.
Going the next step larger in wire would only drop your
losses by 40% of 3% to just under 2% . . . an unobservable
difference.
16AWG on the landing lights is more like 0.004 x 20 x
8 for a drop of 0.64 volts or 4.5% . . . again
quite within limits for legacy design goals of 5%
max loss in wiring. Of course, that will become
a non-issue with the LED upgrade.
Let me also indicate that I am in the group who wants to get it correct the first time so I am seeking qualified advice prior to pulling the wire. If possible, please advise your recommendations or if my plan is solid. Also, what sort of disconnect would you install at each wing root?
Do you plan to remove the wings often? The most robust
service connections are knife splices covered in heat-
shrink. Given the small number of wires, I'd personally
go that route.
[img]cid:.0[/img]
I may have other wiring questions and will be happy to pay for this service.
Not necessary. Let's carry out the conversation here
on the List for sharing . . .
Wishing you the very best in 2014 and thanking you in advance for your reply, I remain,
You too my friend! Nice airplane by the way . . . got
a lot of time in a 120+ (electrical system added)
flying Young Eagles. Real blast . . .
80.54 KB |
1839 Time(s) |
Posted: Sun Jan 05, 2014 3:26 pm Post subject: Wiring Verification |
At 03:47 PM 1/5/2014, you wrote:
Bob,
Thanks for your consideration and kind reply.
I was figuring a total of 24 feet of wire run for the wing tip lamps
and power supply to the switch including the disconnect at the wing
root, and a 20 foot run for the landing lights including the
disconnect at the wing root. Perhaps I was vague on this measurement
and did not explain it very well or perhaps the wires don't add
together for the total drop. I confess my knowledge about wiring is
lacking in general although I am attempting to come up to speed with
respect to this task at hand. I neglected to include both runs
together for the total of .8 volt drop. However using the 24 foot
run, I come up with .96 volt or near 1 volt. Divided by a 13 volt
system, I read that as .076 or beyond the 5% legacy. The Aeroflash
documentation suggested the use of an 18 AWG but I'm not aware of
what wire length run was used for the calculation. Luscombes have a
35 foot wingspan. So I figured a 16 gauge would include my margin of error.
If this is a metal airplane, grounding the devices locally
provides a much lower ground path resistance . . . essentially
negligible . . .
I do not plan on removing the wings often, perhaps not at all,
however, I'd like to provide for it now to eliminate a random cutting
when it occurs, because it will occur. In looking at the old
Luscombe documentation, initially some sort of junction block was
located at each wing root but those connections have long ago been
changed when the wings were swapped out.
If you can wire it up without junctions, so much the
better. Just put a service loop of wire at the wing
root . . . 3-4 inches in diameter. This will offer
'slack' from which future splices can be implemented
should it become necessary.
I was thinking of a using a triple Seal-All type conductor for the
disconnect at the wing root but hadn't considered the knife
splices. Actually, to my knowledge, I have never employed a knife
splice in any of my wiring.
The ideal configuration is no connector at all. Once
you break the wires, putting them back together is
pretty much a toss-up. Cessna started using Mate=n=Lok
plastic connectors at the root and other locations
as a production aid back about 1967. The car-guys have
been doing it too for decades. Risks are low no matter
what technology you choose.
This leading edge location is very tight also providing for the
aileron control cables and fuel lines coming in through the leading
edge with a pulley positioned right at the juncture of the leading
edge carrying the control cables. So, I anticipated bringing the
three wires into the fuselage through the leading edge and securing
on the last wing root rib and positioning my disconnect at that
location. The wires would then reconnect through the splice and
continue on through and around the front door upright and down to the
rear of the instrument panel.
You did not mention anything about shielded wiring. Would the
total wire runs as I have listed above adjust your recommendations on
the wire sizing?
None of those wires would benefit from shielding.
When I purchased radios I also purchased a wiring harness to connect
to my buss and fuses or switches as appropriate. Hopefully, that
will be more straight forward but I'm sure I'll have questions there.
No problem . . . that's what we're here for . . .
Thanks again for your reply on this cold winter afternoon in Kansas.
You got that right. It was about 4F when I got up
this morning . . . supposed to get down to 0F
tonight. But looking at the nation-wind chill-indexes,
we've got it easy.
