Most Amazing War-Plane In History !!!
Bob.Steele(at)kzf.com
PostPosted: Mon Feb 10, 2014 12:05 pm    Post subject: Most Amazing War-Plane In History !!! Reply with quote
Subject: FW: Fwd:Most Amazing War-Plane In History !!!
The most amazing airplane in History....For the Airplane Buffs
Built in Russia during the 1930s, it flew 11 times before crashing and
killing 15 people.
The designer, Konstantin Kalinin, wanted to build two more planes but
the project was scrapped.
Later, Stalin had Kalinin executed.
Evidently, it was not good to fail on an expensive project under Stalin
BobsV35B(at)aol.com
PostPosted: Mon Feb 10, 2014 12:48 pm    Post subject: Most Amazing War-Plane In History !!! Reply with quote
Good Afternoon Bob,
I have seen other reports on this airplane, some of which claimed that no flights were made with all of the engines shown installed. It was also said that all of the armament was only for ground photos. Never flew when so equipped. Still a pretty amazing machine!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Downers Grove, IL
Stearman N3977A
In a message dated 2/10/2014 2:06:08 P.M. Central Standard Time, Bob.Steele(at)kzf.com writes:
Built in Russia during the 1930s, it flew 11 times before crashing and killing 15 people.
The designer, Konstantin Kalinin, wanted to build two more planes but the project was scrapped.
Evidently, it was not good to fail on an expensive project under Stalin .
It's got propellers on the back of the wings, too. You can count 12 engines facing front.
The size would be equivalent to the Empire State Building on its side, with cannons.
And you think the 747 was big... not only a bunch of engines but check out the cannons the plane was carrying.
In the 1930s the Russian army was obsessed by the idea of creating huge planes.
At that time they were proposed to have as many propellers as possible to help carrying those huge flying fortresses into the air, jet propulsion has not been implemented yet.
Not many photos were saved from those times because of the high secrecy levels of such projects and because a lot of time has already passed.
Still, on the attached photos you can see one such plane - a heavy bomber K-7.
Can you imagine what it would be like sitting in this plane when those cannons go off?
Looks like something out of a Jules Verne novel.
[img]wlmailhtml:%7bE2141603-8679-4327-8ED7-E6207073CFCD%7dmid://00000034/!cid:1.2088198712(at)web160305.mail.bf1.yahoo.com[/img]
[img]wlmailhtml:%7bE2141603-8679-4327-8ED7-E6207073CFCD%7dmid://00000034/!cid:2.2088198712(at)web160305.mail.bf1.yahoo.com[/img]
[img]wlmailhtml:%7bE2141603-8679-4327-8ED7-E6207073CFCD%7dmid://00000034/!cid:3.2088198712(at)web160305.mail.bf1.yahoo.com[/img]
This e-mail transmission contains information that is confidential and may be privileged. It is intended only for the addressee(s) named above. If you receive this e-mail in error, please do not read, copy or disseminate it in any manner. If you are not the intended recipient, any disclosure, copying, distribution or use of the contents of this information is prohibited. Please reply to the message immediately by informing the sender that the message was misdirected. After replying, please erase it from your computer system. Your assistance in correcting this error is appreciated.
sr14572(at)yahoo.com
PostPosted: Mon Feb 10, 2014 1:02 pm    Post subject: Most Amazing War-Plane In History !!! Reply with quote
I think this is something related to someones imagination. I think its photoshopped.
From: "Steele, Bob" <Bob.Steele(at)kzf.com> To: commander-list(at)matronics.com Sent: Monday, February 10, 2014 3:05 PM Subject: Commander-List: Most Amazing War-Plane In History !!!
#yiv8660113993 #yiv8660113993 -- p.yiv8660113993MsoNormal, #yiv8660113993 li.yiv8660113993MsoNormal, #yiv8660113993 div.yiv8660113993MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;} #yiv8660113993 a:link, #yiv8660113993 span.yiv8660113993MsoHyperlink {color:blue;text-decoration:underline;} #yiv8660113993 a:visited, #yiv8660113993 span.yiv8660113993MsoHyperlinkFollowed {color:blue;text-decoration:underline;} #yiv8660113993 pre {margin:0in;margin-bottom:.0001pt;font-size:10.0pt;} #yiv8660113993 span.yiv8660113993EmailStyle18 {font-family:Arial;color:navy;} #yiv8660113993 filtered {margin:1.0in 1.25in 1.0in 1.25in;} #yiv8660113993 div.yiv8660113993Section1 {} #yiv8660113993
[img]cid:1.2090803368(at)web120301.mail.ne1.yahoo.com[/img][img]cid:2.2090803368(at)web120301.mail.ne1.yahoo.com[/img][img]cid:3.2090803368(at)web120301.mail.ne1.yahoo.com[/img]
 Filesize:  20.99 KB
 Viewed:  2393 Time(s)
 Filesize:  17.22 KB
 Filesize:  22.93 KB
